Gig 601XL Builder writes:
Wrong, exactly backwards wrong. Rutger was correct. The frame is a painted raster. The image is the complete set of visual data for simultaneous assimilation. |
Roger (K8RI) writes:
I seriously doubt they can. I can discern the flicker in *some* fluorescent lights, but I can not discern 120 cps on a strobe. I think what they are seeing is the "sputter" of a cold lamp or a light that isn't starting correctly. The flicker I see in those lamps is considerably slower than 120 or even 60 cps. Peripheral vision is much more sensitive to flicker than central vision. Some people will perceive an irritating flicker in a lamp or computer monitor each time they turn away from it, and yet the flicker will disappear when they look directly at it. The perception is limited to the impression that the light is flickering; that doesn't mean that they can count the individual flashes. First, for any flicker the phosphor has to be defective ... How can the phosphor be defective? |
![]() "Mxsmanic" wrote in message ... Roger (K8RI) writes: I seriously doubt they can. I can discern the flicker in *some* fluorescent lights, but I can not discern 120 cps on a strobe. I think what they are seeing is the "sputter" of a cold lamp or a light that isn't starting correctly. The flicker I see in those lamps is considerably slower than 120 or even 60 cps. Peripheral vision is much more sensitive to flicker than central vision. Some people will perceive an irritating flicker in a lamp or computer monitor each time they turn away from it, and yet the flicker will disappear when they look directly at it. The perception is limited to the impression that the light is flickering; that doesn't mean that they can count the individual flashes. First, for any flicker the phosphor has to be defective ... How can the phosphor be defective? No, that's just a symptom of the electro shock therapy. |
Mxsmanic wrote in
: Roger (K8RI) writes: I seriously doubt they can. I can discern the flicker in *some* fluorescent lights, but I can not discern 120 cps on a strobe. I think what they are seeing is the "sputter" of a cold lamp or a light that isn't starting correctly. The flicker I see in those lamps is considerably slower than 120 or even 60 cps. Peripheral vision is much more sensitive to flicker than central vision. Some people will perceive an irritating flicker in a lamp or computer monitor each time they turn away from it, A bit like looking at you. Bertie |
Maxwell writes:
Seems I have heard the 16 cps is all that is required for movies to appear continuous. Motion pictures use 24 ips, repeated once, giving 48 fps (24 images shown twice each). The motion is smooth as long as the image isn't too bright, large, or fast-moving. Sometimes a stroboscopic effect can be seen in the latter cases. It can be hidden by allowing image elements to blur. You can see this effect very clearly on TV (30 ips in the U.S.) when sporting events are showing that have been recorded with high shutter rates in the cameras. Each image is sharp and it's easy to see that a succession of individual images is being shown on the screen, even at 30 ips. I think the human eye loosed it around 12 or 13. Higher than that. Twelve images per second tends to look noticeably jerky. Hence the reason an aircraft propeller will appear to be revolving slowly backwards at times. Not when being observed directly. That only happens in movies and video due to the interaction between the imaging rate and the rotation rate of the propeller. |
![]() "Mxsmanic" wrote in message ... Maxwell writes: Seems I have heard the 16 cps is all that is required for movies to appear continuous. Motion pictures use 24 ips, repeated once, giving 48 fps (24 images shown twice each). The motion is smooth as long as the image isn't too bright, large, or fast-moving. Sometimes a stroboscopic effect can be seen in the latter cases. It can be hidden by allowing image elements to blur. You can see this effect very clearly on TV (30 ips in the U.S.) when sporting events are showing that have been recorded with high shutter rates in the cameras. Each image is sharp and it's easy to see that a succession of individual images is being shown on the screen, even at 30 ips. I think the human eye loosed it around 12 or 13. Higher than that. Twelve images per second tends to look noticeably jerky. Hence the reason an aircraft propeller will appear to be revolving slowly backwards at times. Not when being observed directly. That only happens in movies and video due to the interaction between the imaging rate and the rotation rate of the propeller. Wrong again you clueless twit. |
![]() "Airbus" wrote in message ... In article , says... Hence the reason an aircraft propeller will appear to be revolving slowly backwards at times. Not when being observed directly. That only happens in movies and video due to the interaction between the imaging rate and the rotation rate of the propeller. Wrong again you clueless twit. No, he is right this time. No he isn't. |
"Airbus" wrote in message ... In article , says... Hence the reason an aircraft propeller will appear to be revolving slowly backwards at times. Not when being observed directly. That only happens in movies and video due to the interaction between the imaging rate and the rotation rate of the propeller. Wrong again you clueless twit. No, he is right this time. No he isn't. Wellllllllll.............. The world is listening . . . |
Saturday 072807 in Oshkosh Pt 6 - Warbird show pix I forgot to post earlier [10/33] - "Bird Dog.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 10:48 PM |
"British trace missile in copter strike to Iran" | Mike[_7_] | Naval Aviation | 8 | March 10th 07 08:20 PM |
Bird strike(s) | Jay Honeck | Piloting | 45 | November 30th 05 04:39 AM |
Bird strike | Jase Vanover | Piloting | 16 | May 17th 05 11:44 AM |
