You've gotten some good advice so far. You should all join the AOPA
and take advantage of their legal plan, then sit down with a lawyer to set up a non profit corporation. The capt's reply about this was very accurate. It gets sticky when you want you're initial money back..... If you plan on doing all this and then selling the plane at the end, I think renting is the way to go. If you are setting up a long term situation, take the time to form a club, and do it right. Doing it the wrong way, or with the wrong people will guarantee a costly and bad experience. FWIW, and no offense intended, as students you will be beating up your "own" plane. Hard landings etc. It might be better to rent until you are landing without having the CFI questioning their choice of vocation. Doug |
Dave wrote in
: I know 3 guys who are doing this now, and saving a pile... (by their own numbers) It is a Cherokee 140.. Yes, the wing IS in the right place.. Yes, it WILL haul 4 people (in a pinch, WITH a pinch!) And it is a good trainer, Nope, worst trainer ever. Well, after the Ercoupe, maybe. People without legs are alowed to fly them. they cover a multitude of sins whilst training And is tough and inexpensive. True. They are tough. And parts are reasonable, and available.. And it is a simple to maintain plane.. Also true. Ald although not a "fast" plane, has decent cross country speed... Did I mention that the wing is in the right place? A Cessna 150 is great trainer, but not much else.. It is slow, light, cramped, no payload.. You're comparing apples and oranges. the 150 has less than 2/3rds the burn for instance. Bertie |
On Mon, 17 Dec 2007 00:42:45 +0000 (UTC), Bertie the Bunyip
wrote: Dave wrote in : I know 3 guys who are doing this now, and saving a pile... (by their own numbers) It is a Cherokee 140.. Yes, the wing IS in the right place.. Yes, it WILL haul 4 people (in a pinch, WITH a pinch!) And it is a good trainer, Nope, worst trainer ever. Many say the Cherokee family is just too docile to be a trainer. You can put the 180 into a full stall and still use the ailerons to make turns while in the stall. In some planes if you touch the ailerons in a stall it'll roll over and/or go into a spin. In the 180 it just sets there with the stabilator vibrating a bit and a high rate of descent. Do that in my Deb and it takes concentration and some timely control inputs to keep the greasy side down. Roger (K8RI) |
"Roger (K8RI)" wrote in
: On Mon, 17 Dec 2007 00:42:45 +0000 (UTC), Bertie the Bunyip wrote: Dave wrote in m: I know 3 guys who are doing this now, and saving a pile... (by their own numbers) It is a Cherokee 140.. Yes, the wing IS in the right place.. Yes, it WILL haul 4 people (in a pinch, WITH a pinch!) And it is a good trainer, Nope, worst trainer ever. Many say the Cherokee family is just too docile to be a trainer. You can put the 180 into a full stall and still use the ailerons to make turns while in the stall. In some planes if you touch the ailerons in a stall it'll roll over and/or go into a spin. In the 180 it just sets there with the stabilator vibrating a bit and a high rate of descent. Do that in my Deb and it takes concentration and some timely control inputs to keep the greasy side down. Well, exactly, it teaches you little,. Good pickup truck, rotten trainer. Bertie |
Thanks for the unexpectedly large response. I could use a few more
recommendations about which models of aircraft are particularly well suited to being used as a trainer. Also, I could really use tips on buying and potential sources of good used aircraft. Thanks! Craig |
On Dec 20, 7:52 am, wrote:
Thanks for the unexpectedly large response. I could use a few more recommendations about which models of aircraft are particularly well suited to being used as a trainer. Also, I could really use tips on buying and potential sources of good used aircraft. Thanks! Craig Craig, Strange as it may sound, there aren't 100's of models to chose from regarding a trainer. You've ruled out the C 150, 172..so that kind of leaves the Cherokee and possible one or two others. As for where to find one, you've got Aerotrader, Ebay, the local FBO corkboard and I suggest doing a Google for Used Planes. Not to rain on your parade, but you might want to get a few lessons in some different planes before you go spending the kind of cash you guys will need to part with. Speaking of, have you added up all the costs you will be faced with ie a tie down, insurance, club set up fees, any immediate repairs your plane will need, headsets etc...... Doug |
"gliderguynj" wrote in message
... On Dec 20, 7:52 am, wrote: Thanks for the unexpectedly large response. I could use a few more recommendations about which models of aircraft are particularly well suited to being used as a trainer. Also, I could really use tips on buying and potential sources of good used aircraft. Thanks! Craig Craig, Strange as it may sound, there aren't 100's of models to chose from regarding a trainer. You've ruled out the C 150, 172..so that kind of leaves the Cherokee and possible one or two others. As for where to I don't know that I would agree - Champs and Cubs are good basic aircraft - you could "upgrade" to a Citabria... I learned in a Cessna 120. The Yankee was designed as a trainer. What about a Stinson? Maul? Luscombe? Lots of LSA's out there you could use for training. What about homebuilts? No reason you have to use a certified aircraft for training if you own it yourself - my brother's son learned to fly in a T-18 (probably not considered by most to be a "trainer" but his first hour of official "dual instruction" was in a Pitts S2). Wouldn't it be a blast to learn to fly in a Stearman (insurance might be a problem, eh?)? Look beyond the ramp of the local FBO - consider what you might want to fly after you get the ticket (my dad learned to fly in a Navion) - if your "trainer" turns out to be a real nice running sweatheart, some of you might want to hang on to it - if not, unload it. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
On Dec 20, 7:15 pm, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way
d0t com wrote: I don't know that I would agree - Champs and Cubs are good basic aircraft - you could "upgrade" to a Citabria... Good points Capt. but IIRC Craig also asked about it being a 4 seater so his buddies could perhaps fly along with the instructor and learn from watching... that would rule out most of your suggestions. Doug |
... On Dec 20, 7:15 pm, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote: I don't know that I would agree - Champs and Cubs are good basic aircraft - you could "upgrade" to a Citabria... Good points Capt. but IIRC Craig also asked about it being a 4 seater so his buddies could perhaps fly along with the instructor and learn from watching... that would rule out most of your suggestions. OK, I didn't recall that part (must be getting senile(er)). I saw "trainer" - which tends towards two seats. But I did mention the Stinson and the Navion, didn't I? See, I was right all along ;-) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Saw President Bush's plane (response to "Saw J.T.'s Plane") | Ricky | Piloting | 60 | September 1st 07 09:25 PM |
Have you created anything "home-made" for your plane? (or a low cost alternative?) | Andy | Piloting | 69 | April 29th 06 03:25 PM |
Have you created anything "home-made" for your plane? (or a low cost alternative?) | Andy | Owning | 61 | April 29th 06 03:25 PM |
Does anyone have any experience with "Lets Fly".org? | [email protected] | Piloting | 1 | March 14th 06 09:03 AM |
