Isn't some of the problem with cold starts not necessarily oil related but
related to piston scuffing against the cylinder walls? The aluminum pistons have a greater coefficient of expansion than the steel cylinders and the pistons should become a looser fit at colder temps. I'm not sure how the rings fit into the temperature equation. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel "gpaleo" wrote in message news:1198154485.901022@athprx03... "Matt Whiting" wrote news ![]() Peter R. wrote: On 12/19/2007 12:39:10 PM, "gpaleo" wrote: This is joke post, right???? Yes, it's a joke. You can go back to bed now. No, 6 year-olds should be in school by mid-day, not playing on mommies computer! As a 6 year-old mechanical engineer of some 30 years practice and owner of an IO-540 equiped airplane, I find it somewhat disturbing that the OP was NOT a joke. Anyway, pat on the back - big hug time for the courageous aviator who started his engine at **GASP** 25 F, after careful deliberation on aborting the flight until Summer. Catch my drift?? |
Peter R. wrote:
--- clip clip -- Why is it that here in the Northeast US seemingly no one preheats their automobile engine before start-up in very cold temperatures? Is the long-term damage the same for both autos and aircraft engines? If so, why do you suppose auto owners don't typically do this? Is it because that most auto owners do not keep their cars very long? Here in the north of Europe We'll pre-heat our cars if possible, if the temperature goes below +5 C (whatever it is in F, around 40?). You can force an engine to start even at -30 C, but it means that the poor thing runs some time practically dry of lubrication. -- Tauno Voipio (CPL(A), flying OH-PYM, PA28RT-201T) tauno voipio at iki fi |
Tauno Voipio wrote:
Peter R. wrote: --- clip clip -- Why is it that here in the Northeast US seemingly no one preheats their automobile engine before start-up in very cold temperatures? Is the long-term damage the same for both autos and aircraft engines? If so, why do you suppose auto owners don't typically do this? Is it because that most auto owners do not keep their cars very long? Here in the north of Europe We'll pre-heat our cars if possible, if the temperature goes below +5 C (whatever it is in F, around 40?). You can force an engine to start even at -30 C, but it means that the poor thing runs some time practically dry of lubrication. Really? Where does all of the oil disappear to that was there when the engine was shut down? Matt |
Matt Whiting wrote:
Tauno Voipio wrote: Peter R. wrote: --- clip clip -- Why is it that here in the Northeast US seemingly no one preheats their automobile engine before start-up in very cold temperatures? Is the long-term damage the same for both autos and aircraft engines? If so, why do you suppose auto owners don't typically do this? Is it because that most auto owners do not keep their cars very long? Here in the north of Europe We'll pre-heat our cars if possible, if the temperature goes below +5 C (whatever it is in F, around 40?). You can force an engine to start even at -30 C, but it means that the poor thing runs some time practically dry of lubrication. Really? Where does all of the oil disappear to that was there when the engine was shut down? Matt The lubrication is based on fluid between the metal surfaces. When the oil thickens enough, it will not get to the small spaces between the metal surfaces. -- Tauno Voipio |
![]() "Tauno Voipio" wrote in message ... Matt Whiting wrote: Tauno Voipio wrote: Peter R. wrote: --- clip clip -- Why is it that here in the Northeast US seemingly no one preheats their automobile engine before start-up in very cold temperatures? Is the long-term damage the same for both autos and aircraft engines? If so, why do you suppose auto owners don't typically do this? Is it because that most auto owners do not keep their cars very long? Here in the north of Europe We'll pre-heat our cars if possible, if the temperature goes below +5 C (whatever it is in F, around 40?). You can force an engine to start even at -30 C, but it means that the poor thing runs some time practically dry of lubrication. Really? Where does all of the oil disappear to that was there when the engine was shut down? Matt The lubrication is based on fluid between the metal surfaces. When the oil thickens enough, it will not get to the small spaces between the metal surfaces. -- Tauno Voipio Research will tell you the oil is allready there and being cold and thick it tends to go nowhere and in fact does its job rather well. Many engines are started a far colder temps regularly and suffer no damage and make TBO. Far,far worse to let an engine sit. |
On Thu, 20 Dec 2007 19:39:17 GMT, Tauno Voipio
wrote: Matt Whiting wrote: Tauno Voipio wrote: Peter R. wrote: --- clip clip -- Why is it that here in the Northeast US seemingly no one preheats their automobile engine before start-up in very cold temperatures? Is the long-term damage the same for both autos and aircraft engines? If so, why do you suppose auto owners don't typically do this? Is it because that most auto owners do not keep their cars very long? Here in the north of Europe We'll pre-heat our cars if possible, if the temperature goes below +5 C (whatever it is in F, around 40?). You can force an engine to start even at -30 C, but it means that the poor thing runs some time practically dry of lubrication. Really? Where does all of the oil disappear to that was there when the engine was shut down? Matt The lubrication is based on fluid between the metal surfaces. When the oil thickens enough, it will not get to the small spaces between the metal surfaces. Preheating a car at +5C is just ridiculous if you are using the proper weight of motor oil. I might use a block heater if the temperatures went below -20C, but not higher than that. Try using a good 10W30 oil between +5 and -10, and perhaps a 5W30 below that. You won't damage anything, and your engine will last longer than the body panels on the car! -- Jay (remove dashes for legal email address) |
proper weight of motor oil. I might use a block heater if the temperatures went below -20C, but not higher than that. Try using a good 10W30 oil between +5 and -10, and perhaps a 5W30 below that. You won't damage anything, and your engine will last longer than the body panels on the car! I use 5W30 year-round in my '01 Chevy. Runs just fine, and it's what the manufacturer recommends for our climate. The tolerances in these auto engines are now so small that anything heavier is not only a waste of time but could be really bad in the cold. Aircraft engines have much larger tolerances, mostly because they're air-cooled and get a lot hotter, with clearances between things like aluminum pistons and steel cylinders getting pretty tight at high temps. Aluminum expands at twice the rate of steel, and while some pistons have steel inserts cast into them to control that expansion, they still expand a lot. Liquid-cooled engines can be built much tighter. And auto engines have much smaller cylinders than aircraft engines of the same HP and so the overall expansion is less. Rings are either chomed steel or cast iron and will expand at around the same rate as the cylinder, but they'll still get tighter from the heat draining off the piston through them. They have a bit of difficulty getting rid of that heat through the microscopic oil film on the cylinder wall. With larger tolerances, more oil escapes. With larger tolerances, the arc of contact area is shorter. With larger tolerances, things tend to strike each other harder. So heavier oils are necessary to slow the oil's escape from bearings and so on, heavier to lubricate the shorter contact arcs, heavier to dampen the shocks of parts banging into other parts. Piston scuffing often happens when an engine is driven to full power too soon. Pistons get hot and cylinders are still cool, clearances disappear. Scuffing can happen if the oil isn't reaching the cylinders, and since it's usually thrown off the rods (some engines have a squirt hole in the rod opposite), a really low idle might leave the cylinders dry. Some two-strokes like the aircooled Rotaxes must be warmed up thoroughly or they'll seize soon after takeoff. Local guy learned that the hard way. Seized it twice before someone clued him in. Best things for folks who fly infrequently include installing a preoiler and don't make short flights. The preoiler will fill all the oil galleries and pressure will come up even before start. The short flights leave water in the oil the eat the engine. The folks who "run it up once in a while to keep it healthy" without flying it are doing the worst damage by far. Dan |
Tauno Voipio wrote:
Matt Whiting wrote: Tauno Voipio wrote: Peter R. wrote: --- clip clip -- Why is it that here in the Northeast US seemingly no one preheats their automobile engine before start-up in very cold temperatures? Is the long-term damage the same for both autos and aircraft engines? If so, why do you suppose auto owners don't typically do this? Is it because that most auto owners do not keep their cars very long? Here in the north of Europe We'll pre-heat our cars if possible, if the temperature goes below +5 C (whatever it is in F, around 40?). You can force an engine to start even at -30 C, but it means that the poor thing runs some time practically dry of lubrication. Really? Where does all of the oil disappear to that was there when the engine was shut down? Matt The lubrication is based on fluid between the metal surfaces. When the oil thickens enough, it will not get to the small spaces between the metal surfaces. There was oil in those spaces when the engine was shut down and it doesn't magically disappear. Most engines will run for some time with no oil pressure and without damage. Matt |
Peter R. wrote:
Given any other day, I would have plugged the aircraft back in and scrapped the flight but in this case I had an Angel Flight patient waiting in another city for my arrival and I was already late. Thus I made the painful decision to start up the aircraft and allow it to low idle until the oil heated thoroughly. A small consolation is that the engine had been recently filled with fresh Exxon Elite oil. To my relief the aircraft started right up. I think you made the right judgment call. The engine life is more dependent on your long- term level of care than for a single instance of pressing the limits. BTW, a simple overhand knot in the power cord where the heater plug and the extension cord mate will prevent someone from inadvertently unplugging them. I know what I did has negative long term repercussions on my engine's health and I have already derived a tool to lock the two cords and prevent this accidental unplugging from happening again. However, this leads me to question the differences between aircraft engines and auto engines: Why is it that here in the Northeast US seemingly no one preheats their automobile engine before start-up in very cold temperatures? Is the long-term damage the same for both autos and aircraft engines? If so, why do you suppose auto owners don't typically do this? Is it because that most auto owners do not keep their cars very long? |
On 12/19/2007 1:09:15 PM, Jim Stewart wrote:
BTW, a simple overhand knot in the power cord where the heater plug and the extension cord mate will prevent someone from inadvertently unplugging them. Unfortunately no room for an overhand knot. There is no slack at all in the Tanis heater-side plug, as it is secured right at the plug to the (IIRC) support that also holds the fuel lines. -- Peter |
Differences between automotive & airplane engines | Chris Wells | Home Built | 105 | February 18th 06 11:00 PM |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
LOM engines | buckey | Home Built | 14 | October 30th 03 05:22 PM |
automotive parts on airplane engines | Wallace Berry | Home Built | 15 | September 28th 03 02:55 AM |
Barnyard--- Auto engines | Jerry Springer | Home Built | 10 | August 8th 03 06:38 PM |
