No kiddiing. We had 30 seconds before the B-26 dove for the the bottom. Here's a description of a 310th B-25 ditching episode on what was expected to be a milk run over an airfield the krauts were just constructing: Joey spent most of the sightseeing tour in the gun turret bubble. Corrie looked out the waist gun window for E-boats, fighters, sharks. He was just beginning to relax when Ed called over the intercom, "Over the target in fifteen. Sam, check the bomb bay after we get off the target to be sure a bomb hasn't hung up." He looked out the window and watched the coast approach. They hit the IP and turned for the bomb run. Suddenly the plane began to shudder. Ack-ack was coming from all directions; black puffs surrounded the plane. Corrie could actually see the red center of the explosions and *hear* them they were so close. Shrapnel was banging through the airplane. He thought, "My God, we can't make it through this!" As he looked back, the first bombs were beginning to explode as they hit the ground. The plane's track through the sky was marked with the black puffs of 88mm. As they cleared the airfield, the ground fire stopped as suddenly as it had started. Ed was pouring on the coal and the crew could feel the old girl accelerate as they banked off in a dive to pick up speed and get the hell out of there. The other five planes in our box were right with us in the turn and dive, the pilots maintaining perfect station. It was time to relax for a boring trip home. Corrie returned to the radio compartment, turned on the transmitter, let down the trail wire antenna. In the engineer's compartment behind the cockpit, Sam was not relaxing. The port engine was rough and hadn't responded well to the advanced throttle setting. Oil pressure was normal. When he made a visual check, he noticed oil dribbling from it. Sam leaned into the pilot's compartment and told Ed, "There's considerable oil streaming from the left engine. Want me to call Corrie and ask him for an escort plane? Ed glanced over at the leaking engine briefly and said, "These old babies will fly half way round the world on one engine. We'll make it OK. "Bull ****," Sam thought to himself, but said nothing. He and Charlie, the co-pilot, glanced at each other and Charlie slipped his parachute over his Mae West. Ed looked at him, hit the intercom button. "Corrie, we have an oil leak in the port engine; get on the key and send SOS and position reports for a Cat every five minutes. Bob, keep Corrie up-to-speed on position." "About fifty miles off target, Bob cut in on the intercom." "Roger." Corrie turned the transmitter to the key and began sending SOSes but could tell by his headset noise that he wasn't putting out a signal. He kept sending. Soon he could hear radio traffic. He tuned the set, turned up the volume and in the clear hammered the key: "SOS. Ed's plane on single engine sixty miles off target." He listened. The channel was almost clear. "Mayday, mayday, Ed's plane on single engine, sixty miles off target." Finally a response came in, from a British unit, who politely asked who "Ed" was. But at least the Corrie knew their plight was known to someone. Up front, Charlie suggested opening the cowls on both engines for maximum cooling and Sam agreed. Charlie referred to their B-25 as an "old tub," wondering how far she would get, and Ed responded that "she is a good single-engine plane and we can throw out a lot of crap. Call Corrie and Joey and have them throw out everything they can lift. We'll make it home. We have to. I have a comic book I haven't read yet." Outside there was brilliant Mediterranean sun, the sea very smooth, little apparent wind. Ed cut power to the bad engine and hit the feather button. The propeller did not feather. Instead, it windmilled and sent heavy vibrations through the plane. Ed yelled to Charlie, "Help me hold the controls!" The plane was about 500 feet high and wracked by violent shuddering. There was real danger an engine or wing might tear loose. "Prepare to ditch!" Ed yelled. "Charlie, call Joey and Corrie!" Ed gave the thumbs down to Sam and Bob (who had crawled up into the engineer's compartment). The vibrations increased in intensity as the plane neared the sea. "Aren't you cutting power?" Charlie yelled at Ed. "No! Pull the escape hatch after we hit!" Both pilots were forcing full right rudder and watching the sea rushing toward them. No one remembered to close the cowl flaps. Ed cut the right engine just as the plane slammed into the water, tail low. There was a thunderous noise and the nose plunged under the surface. Water smashed into the compartment with incredible force. Then there was sudden, absolute silence. The plane was tilted at about a 30 degree angle down, with those forward all well below water. Charlie recovered first and pulled the overhead escape hatch. Ed went out first, followed by Charlie. Sam's Mae West snagged something, trapping him and Bob stayed under to help him clear it, boosted him out of the hatch and then followed. When Charlie called to tell Joey and Corrie to dump everything they could, Joey stripped the two fifties out of the turret, Corrie tossed the IFF and all other radio equipment except the transceiver; he kept using the key. Joey even tossed the life raft through the hatch. Corrie reached a hand out too late to stop him, but still shouted, "Hey, we're going to be needing that!" He kept sending but was unable to reach 310th ground station; they were probably too low. When the plane began to shudder, Corrie told Joey to sit with his back to the bomb bay bulkhead and protect his head with his parachute. Corrie reeled in the trailing wire antenna, shut off the tranceiver and joined Joey. They were already in position when Charlie called "Prepare to ditch." Joey muttered, "No kidding, buster." When the plane hit they experienced first one crash, a short glide, and then a second, harder smash. No one up front had noticed anything but one solid smash. Then all was silence except for the sound of water dripping and waves lapping against the side of the plane. Corrie reached above the radio compartment and pulled on the life raft release. It did not move. He called Joey to help but despite the efforts of both, it would not budge. Water began to fill the compartment through the lower escape hatch. Joey, who announced at this juncture that he couldn't swim, refused to dive through it and get out. Corrie dove through, swam to the surface, and climbed to the top of the fuselage to release the raft using the exterior handle. Sam climbed up to help. The handle wouldn't budge, then snapped off clean. As the rear compartment filled with water, Joey inflated his Mae West, thus trapping himself completely. Hearing his cries for help, Bob dove under the plane, up through the escape hatch, deflated his vest and steered him back out the escape hatch. The crew gathered and swam away from the plane. About two minutes had passed. They watched the tail slowly elevate to the vertical then slide with scarcely a ripple under the waves. The crew was alone on the wide, wide sea, no life raft, the one guy who couldn't swim with a deflated life vest. Ed had a bad cut across the bridge of his nose and forehead. Moral sank fast, until Charlie quipped, "Anyone got a knife. I don't want Ed to be the only one to get a Purple Heart!" Each Mae West had a dye packet. After floating in silence for some minutes, Bob said, "I think I'll open a dye packet. When he tried to tear it off, his vest ripped and everyone could hear the air hiss out. The vest was ruined. It was at this point that Charlie thought to asked Corrie if he had made contact with a Cat and Corrie answered no, only with some Brit. There was no further conversation. Just the sound of waves lapping. After an hour, the sound of engines were heard. A flight of B-25s passed to the north. They continued unwaveringly. Then engines again, another flight, almost directly overhead. Everyone--carefully--remove his dye packet and spilled it into the sea, then began splashing wildly as the planes thundered overhead. They passed by, then one peeled off and circled the crew, who all yelled their heads off. The B-25 waggled its wings before flying off. A few minutes later a flight of P-47s appeared and took station over the crew. After about half an hour from low out of the West a PBY lumbered into view, circled and landed with matronly aplomb, taxied up to the crew. The blue navy duds of the crewman who leaned out the bubbled and one-armedly hoisted each of them aboard looked beautiful. The Cat trundled into the air while the crew sipped Navy coffee and dripped sea water. Three hours after ditching they were back on dry land. Forty hours later they were flying another mission. Chris Mark |
"Steven P. McNicoll" wrote:
I would think the operator would have better information on the ditching behavior than would the manufacturer. Glad to see you finally coming around Steven. There's no substitute for experience but when I asked you how many hours you have in a certain type your non sequitur response was "irrelevant." |
![]() "Mike Marron" wrote in message ... Glad to see you finally coming around Steven. There's no substitute for experience but when I asked you how many hours you have in a certain type your non sequitur response was "irrelevant." Your message makes no sense whatsoever. |
"Mike Marron" wrote: Glad to see you finally coming around Steven. There's no substitute for experience but when I asked you how many hours you have in a certain type your non sequitur response was "irrelevant." Your message makes no sense whatsoever. You must have a short memory: I said: "Please post your number of hours logged in experimental trikes right here --____________" You responded: "Zero, and irrelevant." In any event, now that you've acknowledged the priceless value of experience, when it comes to ditching an Avenger I would agree with you and give the nod to those whom have actual experience successfully ditching the airplane in real world situations over what the book says. Of course, like many things in aviation it's not quite as cut and dried as that and perhaps a combination of the book technique and my fellow squadron mate's technique would be best. But having ditched an aircraft myself, I still can't say for sure if I'd use the same technique again in the event I find myself in the same situation once again. |
![]() "Mike Marron" wrote in message ... "Steven P. McNicoll" wrote: "Mike Marron" wrote: Glad to see you finally coming around Steven. There's no substitute for experience but when I asked you how many hours you have in a certain type your non sequitur response was "irrelevant." Your message makes no sense whatsoever. You must have a short memory: Non-sequitur. |
![]() "Mike Marron" wrote in message ... You must have a short memory: I have an excellent memory. I said: "Please post your number of hours logged in experimental trikes right here --____________" You responded: "Zero, and irrelevant." In any event, now that you've acknowledged the priceless value of experience, when it comes to ditching an Avenger I would agree with you and give the nod to those whom have actual experience successfully ditching the airplane in real world situations over what the book says. Of course, like many things in aviation it's not quite as cut and dried as that and perhaps a combination of the book technique and my fellow squadron mate's technique would be best. But having ditched an aircraft myself, I still can't say for sure if I'd use the same technique again in the event I find myself in the same situation once again. Different issue. Experience ditching an Avenger obviously provides one with knowledge of the ditching characteristics of an Avenger. But logging hours in experimental trikes does not provide one with knowledge of the FARs, as you so ably demonstrated with your messages last month. |
Different issue. But same principle relating to the importance of experience. Experience ditching an Avenger obviously provides one with knowledge of the ditching characteristics of an Avenger. Er um, exactly what I said. But logging hours in experimental trikes does not provide one with knowledge of the FARs, as you so ably demonstrated with your messages last month. Like I said Stevie, you're living in the land of Oz and are more full of **** than a brontasaurus with no ass if you think that you, with your basic VFR-only private pilot's license (?) and paltry amount of experience is in the same ball park with ANY CFII or A&P mechanic (not just me). Reality check! What, do you think my ultralight trike came out of its shipping crate with an N-number magically stuck on it just for me? Somebody had to educate the feds about these newfangled, tailless flying machines because like you, they didn't have the first clue even what a "trike" is...much less how to go about N-numbering one! And then somebody had to know how to properly fill out FAA Forms 8130-6, and -12, have them notorized and send them off to Oklahoma City. Same goes for AC Form 8050-3, -1 which had to be signed and dated as evidence that I have complied with the registration requirements per FAR Part 47. And who do you suppose had to enclose 3-view drawings complete w/photos of the A/C as required by FAR section 21.193? The Great Oz? And who do you think weighed the A/C to make sure it was within CG limits and sent a copy of that information to the feds in Oklahoma City as well? Santa Claus? What about the all the required placards and markings, who do you s'pose plastered them all over the A/C? Mrs. Claus? Santa's reindeer? Perhaps one of Santa's elves? Only AFTER all these items were done could I even begin to think about logging hours in my experimental trike as you said above. Hell, you didn't even know that experimental trikes EXISTED....much less that I happened to be one of the handful of pilots whose not only knowledgable enough with the FAR's, but motivated enough to take a common ultralight and register it as an experimental so as allow me to operate it just like I would operate a Cessna 210. Perhaps it's time that you grow up and give credit where credit's due Steve. Just because you've wasted all these years arguing on Usenet about whether or not the Wrights were the first to achieve powered flight or Yeager was the first through the mythical "sound barrier," some of us have actually been busy building and flying and accomplishing things. You're a talker, not a doer. BTW, how many experimental A/C have YOU built and N-numbered Steve? Anyone, even my 9-year old nephew, can simply copy and paste the FAR's off the web like you did while attempting to show how knowledgable you *think* you are. |
![]() "Mike Marron" wrote in message news ![]() But same principle relating to the importance of experience. Nope. Like I said Stevie, you're living in the land of Oz and are more full of **** than a brontasaurus with no ass if you think that you, with your basic VFR-only private pilot's license (?) and paltry amount of experience is in the same ball park with ANY CFII or A&P mechanic (not just me). Reality check! You have demonstrated a poor knowledge of the FARs, the inability to think logically, a huge ego, and a lack of maturity. You know nothing of my knowledge and experience level. |
![]() "Mike Marron" wrote in message ... "Steven P. McNicoll" wrote: I would think the operator would have better information on the ditching behavior than would the manufacturer. Glad to see you finally coming around Steven. There's no substitute for experience but when I asked you how many hours you have in a certain type your non sequitur response was "irrelevant." Lune. |
"Tarver Engineering" wrote:
"Mike Marron" wrote: "Steven P. McNicoll" wrote: I would think the operator would have better information on the ditching behavior than would the manufacturer. Glad to see you finally coming around Steven. There's no substitute for experience but when I asked you how many hours you have in a certain type your non sequitur response was "irrelevant." Lune. All great men are dying, and I am rather sick myself. (BTW, you misspelled "loon") |
