Aircraft design tool ?
Old December 22nd 07, 03:27 AM posted to rec.aviation.homebuilt
flash
Default Aircraft design tool ?
My brother, who is into woodworking, pointed this out to me. I wonder if it
is of any use to aircraft designers?
There is a free version and a pay-for-play, but they both seem to be
competent, capable things. Anybody else even seen this??
How about it, VeeDuber?
Flash
Old December 22nd 07, 04:52 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Flash
Something seems to be missing there, flash...
Old December 23rd 07, 12:08 AM posted to rec.aviation.homebuilt
Dear Flash,
There are a number of aircraft design tools available to anyone having
an interest in that area. Some are computer programs, which I suspect
you were referring to (Usenet does not allow attachments) that are
specific to aviation while others are relatively simple structural-
design equation-sets suitable for anything from a railroad bridge to
an airplane's wing.
Others are books and magazine articles devoted to aircraft design.
For the homebuilder, one of the more useful hard-copy sources were the
articles by Raoul Hoffmann, the aeronautical engineer who worked for
Matty Laird, which appeared in 'Popular Flying' magazine during the
1930's. Back when the EAA had an interest in such things they used to
offer a reprint collection of Mr. Hoffmann's articles in a manual
An interesting test of computerized aircraft design tools is run them
backwards and see what you get. That is, enter the parameters of a
proven design such as the Piper 'Cub' and see what the program has to
say with regard to the parameter(s) you've left out, such as weight,
performance or what-have-you. In most cases the software fails to
match the reality of a proven design; good evidence there's a bit more
to it than plugging numbers into a matrix and hitting the button.
Another thing about design tools is that while some will tell you the
required metal thickness and rivet pitch, or the required cross-
sectional area of a wooden spar, they don't tell you HOW to set those
rivets or glue-up such a spar. Which leads to a crude but effective
design tool seldom mentioned by the various 'experts,' which is to
simply make a part and then test it to destruction... once you've
learned HOW to make it
Indeed, the 'Experimental, Amateur-built' license exists not to foster
the sale of kits nor glossy coffee-table magazines, it exists to
foster EDUCATION in aeronautics. And while it is wildly unpopular to
advocate such a thing, by devoting a bit of time to the subject of
aircraft design -- at any level -- you will find that it isn't that
difficult to amass your own kit of fully portable design tools neatly
packaged and always available, between your own ears :-)
-R.S.Hoover
Old December 23rd 07, 03:06 AM posted to rec.aviation.homebuilt
flash
Yeah, something missing, for sure.
http://sketchup.google.com/index.html
Take that, Usenet!
Flash
"flash" wrote in message
it is of any use to aircraft designers?
Flash
Old December 23rd 07, 11:37 AM posted to rec.aviation.homebuilt
Take that, Usenet!
Flash
Flash
Ah, ok. I see waht you are talking about now.
I like this one a lot better.
http://www.imsidesign.com/Products/D...1/Default.aspx
Version 18 3D MAX is at Frys for $69.
It doesn't HAVE to have a really hot computer to run properly.
(But it of course helps - 2Ghz cpu, 2 Gig Ram is nice)
I ran version 2000 on 500 mhz AMD K6 for several years - quite satisfactory.
The deal is, you see, for AIRPLANES (and boats) you really need cubic
spline curves. Without that, you got nothing but houses...
Richard
Some examples?
aircraft:
http://www.home.earthlink.net/~cavelamb/l-one.htm
boats:
http://www.home.earthlink.net/~cavelamb/draft.htm
Old December 23rd 07, 03:38 PM posted to rec.aviation.homebuilt
Scott[_1_]
Heck, you got an RV-3 with a razorback instead of a bubble canopy!
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
cavelamb himself wrote:
Some examples?
aircraft:
Old December 24th 07, 12:22 AM posted to rec.aviation.homebuilt
flash
Now THAT is impressive, especially at the price, and the processor it will
run on. Wowie, just one more toy to occupy my idle mind on winter evenings
when the honey-do's are all done (as if that will ever happen) 8-)
Thanks, really
Flash
"cavelamb himself" wrote in message
Take that, Usenet!
Flash
Flash
satisfactory.
Richard
Some examples?
aircraft:
boats:
Old December 24th 07, 04:04 AM posted to rec.aviation.homebuilt
Some examples?
aircraft:
Scott
A little smaller than an RV-3, but larger than a Hummel.
18 to 20 ft span
70 to 75 sq ft wing.
VW power using 1835 or 2180 cc engines.
Or, for the man with pocket power,
Rotax 912 power and an electric prop!
I think it would be fun.
Old December 24th 07, 10:13 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Sat, 22 Dec 2007 16:08:14 -0800 (PST), "
Dear Flash,
an airplane's wing.
-R.S.Hoover
and the wonderment is that if you actually understand a little of the
history the technology is actually sitting there naked in front of you
at airshows and in museums.
its fascinating!
Stealth Pilot
Old December 24th 07, 02:50 PM posted to rec.aviation.homebuilt
Scott[_1_]
So, have you started bending metal yet???
Scott
18 to 20 ft span
Scott
CAD Tool For Design Tiny Aircraft Le Chaud Lapin Piloting 28 October 14th 07 08:24 PM
CAD Tools For Aircraft Design Le Chaud Lapin Piloting 9 September 26th 07 01:47 PM
Great Aircraft Ownership Tool Jay Honeck Piloting 4 January 20th 06 03:09 PM
X-Plane for aircraft design Ghazan Haider Simulators 1 August 28th 05 09:17 AM
Comments on new design carbon aircraft kit? lifespeed Home Built 2 December 3rd 03 03:22 PM
