Jose wrote in
: If the wings and fuel are cold soaked enough any moisture contacting the wing may form frozen contamination. This forms on the upper surfaces after landing especially if you have alot of fuel remaining. What would prevent this from happening in flight? (n.b. in my case the ambient flight temps were just below freezing - radiative cooling may have lowered the wing temp =some= more, but a =lot= more?) Well, nothng if it's wet enough outside, but it's unlikely you're going to get a low altitude airplane and it's fuel cold enough to do it in flight. It happens often on airliners if they've been at altitude for extended periods and they get th efuel down to low temps and then descend into moisture. Bertie |
On Dec 24, 8:28 am, Jose wrote:
Which got me thinking - maybe the FAA isn't so crazy after all. If frost can form while the plane is just sitting there, why could it not form while the plane is flying? (yeah, there's some frictional heating, but we could lower the temp a bit more, no?) And if frost isn't such a good thing to have on takeoff, it's probably not so good in flight either. The frost on your wings was most certainly formed after your landed. It happened to me a few times on some very clear cold days. I fly a low wing Grumman and I could see the frost started to form as I slowly taxi back to the ramp. If you depart in such condition, it would be a good idea to spray propylene glycol (RV antifreeze, not the automobile antifreeze) on your wings and horizontal stablizers before taxi out, after you clear out all the frost. |
I've iced up to the ailerons in a Warrier, cold fuel can play a part
here too. Bush On Mon, 24 Dec 2007 16:28:33 GMT, Jose wrote: The other day I went flying, pretty close to the shortest day of the year, to preserve night currency. I took advantage of a day that wasn't brutally cold - in fact it was above freezing, so I didn't need preheat or thermal underwear. It was good to get in the air after several months of not flying hardly at all (we had the longest, most beautiful fall but I was stuck indoors doing two shows at the same time). I had to taxi over a bit of an ice berm in front of the wheels, but it wasn't a problem, and the pavement was wet from the melting ice (we had several inches of ice storm a week or so ago which is still around). By the time I got in the air, I was happy and all was well with the world. After doing some night full stop landings, I followed I-84 up to Beacon and back just to "go somewhere" and then came home. By now temperatures were just below freezing, but it was clear and so I didn't give it much consideration. Landed without incident, braking was good (and was also reported good by aircraft before me), and I taxiied to the ramp, a relatively unfamiliar part of the airport since we moved the airplanes. The airplane seemed to be sliding a bit, as if there was ice on the pavement. Well, of course there was; the wet pavement had frozen in the interim. I was afraid of that, and this meant that putting the plane away would not be as easy as taking it out. After a struggle I did manage to get it pushed back over the ice berms (pulling up on the wing while pushing back helped, as did pulling with the tiedown ropes when I got close enough). But when I was pretty much done, I noticed there was frost on the wings, which hadn't been there before. Which got me thinking - maybe the FAA isn't so crazy after all. If frost can form while the plane is just sitting there, why could it not form while the plane is flying? (yeah, there's some frictional heating, but we could lower the temp a bit more, no?) And if frost isn't such a good thing to have on takeoff, it's probably not so good in flight either. Any thoughts? Have you seen this before? Jose |
On 12/24/2007 11:28:36 AM, Jose wrote:
But when I was pretty much done, I noticed there was frost on the wings, which hadn't been there before. I have experienced this a few times. Two memorable times were once after landing at Niagara Falls airport and once after landing in Plattsburgh, NY. In these two cases it was after dark, the sky was clear, and the temperatures were very cold (perhaps around 0 to -10 degrees F). In each situation the aircraft's wings and horizontal stabilizer frosted over within minutes of landing. -- Peter |
Books on Military Rotary Wing to Civilian Fixed Wing Transition? | Greg Copeland | Piloting | 5 | May 2nd 07 03:23 AM |
Winter Flying, pt 2 - Frost Kingdom.jpg (1/1) | Mitchell Holman[_2_] | Aviation Photos | 0 | January 31st 07 12:45 PM |
Triangle shaped ice/frost on the wing - anyone seen this? | Nathan Young | Piloting | 9 | December 7th 05 10:15 PM |
Frost on wings | C J Campbell | Piloting | 14 | January 13th 05 03:56 PM |
the frost is out of the ground! | Cub Driver | Piloting | 6 | April 6th 04 10:49 PM |
