The Relief Band for Nausea Relief
Old December 29th 07, 03:35 AM posted to rec.aviation.soaring
Ian
Default Scopalamine and piloting
On 27 Dec, 18:54, danlj wrote:
On Dec 27, 12:33 pm, Ian wrote:
On 26 Dec, 19:36, Wayne Hoover wrote:
Scopolamine not only causes tiredness it can also cause blurred vision
and dilates the the pupils which are also reasons not to use it while
flying.
Indeed - if one is so affected. If one is not so affected, no problem.
As a physician and aviation medical examiner I wish to demur as
clearly as possible from any recommendation to use scopalamine for
motion sickness while flying.
You go right ahead, and welcome.
I never have felt the need to use a patch while flying because,
although I am plagued by sea-sickness, I have never had any
significant problems in the air. If I did start to suffer air-
sickness, however, I would cheerfully consider using Scopaderm TTS
patches. They are available in the UK as an over-the-counter medicine,
and the relevant warning simply says (and I quote) "This medication
causes drowsiness which may continue the next day. If affected do not
drive or operate machinery. Avoid alcoholic drink."
Note that "if affected". As I wrote before, I have spent months of my
life wearing these patches and have noticed no side effects at all,
save a slightly dry mouth which is useful reassurance that the patch
is active.
I'm not a doctor (well, not your sort). I'm not making any
recommendations. I am, however an experienced user of Scopaderm, and I
have a healthy desire to preserve my own life.
Best wishes,
Ian
Old December 29th 07, 08:16 AM posted to rec.aviation.soaring
Cats
On Dec 29, 3:35*am, Ian wrote:
snip
is active.
snip
Who is going to judge if you are affected? Judging ourselves is the
hardest thing to do.
Old December 29th 07, 11:55 AM posted to rec.aviation.soaring
Doug Hoffman[_2_]
Cats wrote:
If affected do not drive or operate machinery.
The same person that judges if you are fit to fly based on all factors:
Had enough sleep? Backache? Headache? Leg(s)/Arm(s) ache?
Emotionally fit? The list is endless. If you are in doubt about being
able to judge if you are fit to fly, then don't fly.
Regards,
-Doug
Old December 29th 07, 06:38 PM posted to rec.aviation.soaring
Cats
On Dec 29, 11:55*am, Doug Hoffman no.spam wrote:
Who is going to judge if you are affected? *Judging ourselves is the
Had enough sleep? *Backache? *Headache? *Leg(s)/Arm(s) ache?
Emotionally fit? *The list is endless. *If you are in doubt about being
The problem as I understand it with this drug is that what it impairs
in those affected are the faculties we use to decide if we are
impaired...
Old December 29th 07, 11:53 AM posted to rec.aviation.soaring
Ian
is active.
That's a very good question. Can I stress that I would only consider
wearing the patches while flying as a last resort. As for effects,
there are two categories. First, drowsiness. I have worn them enough
to be confident that FOR ME there is no problem with drowsiness. It's
only a potential side effect - some people are strongly affected and
some not at all. Second, other impairments. I have not seen anything
in the literature - I read this up quite carefully, as a lay person,
before using the patches whilst sailing single-handed - to back up the
suggestion that Scopolamine generally or even commonly has similar
effects to alcohol. If I did decide to try it then I would certainly
fly with an instructor and ask for a really tricky check flight. Any
problems and of course I wouldn't fly solo.
Ian
Hurricane relief Gary Drescher Owning 67 September 13th 05 06:09 AM
Hurricane relief Montblack Piloting 0 September 6th 05 06:53 AM
Hurricane relief Dan Luke Instrument Flight Rules 16 September 5th 05 05:20 PM
Hurricane relief [email protected] Owning 2 September 5th 05 09:14 AM
Hurricane relief [email protected] Piloting 0 September 5th 05 01:02 AM
