http://uk.youtube.com/watch?v=9KhZws...eature=related
The beginning of the vid looks so unreal, but apparently it is real. Wil |
On Jan 5, 3:12*pm, Bertie the Bunyip wrote:
William Hung wrote in news:4a5c2933-0efd-4acc-be6a- : http://uk.youtube.com/watch?v=9KhZws...eature=related The beginning of the vid looks so unreal, but apparently it is real. Yeah, it's real. Herons, I think . Bertie Looks like they took awhile to shut off the fuel to #2 engine. Wil |
On Jan 5, 3:39*pm, Bertie the Bunyip wrote:
William Hung wrote in news:f03d3e7c-260e-40d5-9b36- : On Jan 5, 3:12*pm, Bertie the Bunyip wrote: William Hung wrote in news:4a5c2933-0efd-4acc- be6a- : http://uk.youtube.com/watch?v=9KhZws...eature=related The beginning of the vid looks so unreal, but apparently it is real. Yeah, it's real. Herons, I think . Bertie Looks like they took awhile to shut off the fuel to #2 engine. Yeah, it's not a priority, really. the engine is on fire all the time and from the look of it it was still producing thrust anyway. The procedure is this ( though it varies form airline to airline) The takeoff was more than likely done at rduced thrust in the first place. Looks like the ingestion happend just after rotation so it was "go" without any question about it. First thing is the non handling pilot calls out the nature of the failure. in this case, he probably just said "engine failure, right engine" and nothing else is done except to raise the gear at positive rate and cancel any aural warnings. the next is to select full thrust on the live engine. If they had RR engines, they would have firewalled them, if it was Pratts, thye would have set max TO thrust. they were probably passing about 200 feet when all this happened. Note, the full thrust thing is not required, just nice to do. Next, after they were stablised in the climb, they handling pilot would have asked to confirm the nature of the problem. the NH would have spelled out what he thinks it is in detail and the non handling would ask for the engine fire checklist (this is used by most boeing operators these days for all engine probs whether or not the engne is actually burning) The NH woudl initiate it using the memory items startinf with the autothrottle switch to off, the thrust lever affected engine to idle, the start switch ( fuel) to off and th efire switch to pull and then if there is a fire, to rotate to fire first one bottle of extinguishant then the second after 30 seconds. At each item, the handling pilot must confirm that he has the correct thrust lever, switch, whatever, so as to minimise the chance of screwing up and shutting down the wrong one. By the time al this is done, you're easily at 1,000' and it's time to level off and accelerate, cleaning up. If you're coing straight back though, it;s probably best to leave the flaps where they are and get into the remeaining checklists in order to tidy the airplane up for landing. Bertie- Hide quoted text - - Show quoted text - Wow, great explanation. Thank you Bertie. Wil |
William Hung wrote in news:7ffac1f4-97e1-4fa3-8378-
: On Jan 5, 3:39*pm, Bertie the Bunyip wrote: William Hung wrote in news:f03d3e7c-260e-40d5- 9b36- : On Jan 5, 3:12*pm, Bertie the Bunyip wrote: William Hung wrote in news:4a5c2933-0efd-4acc- be6a- : http://uk.youtube.com/watch?v=9KhZws...eature=related The beginning of the vid looks so unreal, but apparently it is real. Yeah, it's real. Herons, I think . Bertie Looks like they took awhile to shut off the fuel to #2 engine. Yeah, it's not a priority, really. the engine is on fire all the time and from the look of it it was still producing thrust anyway. The procedure is this ( though it varies form airline to airline) The takeoff was more than likely done at rduced thrust in the first place. Looks like the ingestion happend just after rotation so it was "go" without any question about it. First thing is the non handling pilot calls out the nature of the failure. in this case, he probably just said "engine failure, right engine" and nothing else is done except to raise the gear at positive rate and cancel any aural warnings. the next is to select full thrust on the live engine. If they had RR engines, they would have firewalled them, if it was Pratts, thye would have set max TO thrust. they were probably passing about 200 feet when all this happened. Note, the full thrust thing is not required, just nice to do. Next, after they were stablised in the climb, they handling pilot would have asked to confirm the nature of the problem. the NH would have spelled out what he thinks it is in detail and the non handling would ask for the engine fire checklist (this is used by most boeing operators these days for all engine probs whether or not the engne is actually burning) The NH woudl initiate it using the memory items startinf with the autothrottle switch to off, the thrust lever affected engine to idle, the start switch ( fuel) to off and th efire switch to pull and then if there is a fire, to rotate to fire first one bottle of extinguishant then the second after 30 seconds. At each item, the handling pilot must confirm that he has the correct thrust lever, switch, whatever, so as to minimise the chance of screwing up and shutting down the wrong one. By the time al this is done, you're easily at 1,000' and it's time to level off and accelerate, cleaning up. If you're coing straight back though, it;s probably best to leave the flaps where they are and get into the remeaining checklists in order to tidy the airplane up for landing. Bertie- Hide quoted text - - Show quoted text - Wow, great explanation. Thank you Bertie. No prob! It's easy. I have to make that explanation every time I fly. Bertie |
"Bertie the Bunyip" wrote in message ... William Hung wrote in news:f03d3e7c-260e-40d5-9b36- : On Jan 5, 3:12 pm, Bertie the Bunyip wrote: William Hung wrote in news:4a5c2933-0efd-4acc- be6a- : http://uk.youtube.com/watch?v=9KhZws...eature=related The beginning of the vid looks so unreal, but apparently it is real. Yeah, it's real. Herons, I think . Bertie Looks like they took awhile to shut off the fuel to #2 engine. Yeah, it's not a priority, really. the engine is on fire all the time and from the look of it it was still producing thrust anyway. The procedure is this ( though it varies form airline to airline) The takeoff was more than likely done at rduced thrust in the first place. Looks like the ingestion happend just after rotation so it was "go" without any question about it. First thing is the non handling pilot calls out the nature of the failure. in this case, he probably just said "engine failure, right engine" and nothing else is done except to raise the gear at positive rate and cancel any aural warnings. the next is to select full thrust on the live engine. If they had RR engines, they would have firewalled them, if it was Pratts, thye would have set max TO thrust. they were probably passing about 200 feet when all this happened. Note, the full thrust thing is not required, just nice to do. Next, after they were stablised in the climb, they handling pilot would have asked to confirm the nature of the problem. the NH would have spelled out what he thinks it is in detail and the non handling would ask for the engine fire checklist (this is used by most boeing operators these days for all engine probs whether or not the engne is actually burning) The NH woudl initiate it using the memory items startinf with the autothrottle switch to off, the thrust lever affected engine to idle, the start switch ( fuel) to off and th efire switch to pull and then if there is a fire, to rotate to fire first one bottle of extinguishant then the second after 30 seconds. At each item, the handling pilot must confirm that he has the correct thrust lever, switch, whatever, so as to minimise the chance of screwing up and shutting down the wrong one. By the time al this is done, you're easily at 1,000' and it's time to level off and accelerate, cleaning up. If you're coing straight back though, it;s probably best to leave the flaps where they are and get into the remeaining checklists in order to tidy the airplane up for landing. You left Anthony in the dust at "non-handling pilot". Here's another thought experiment for him: You are the NHP in a real cockpit and incur a bird-strike flameout right after rotation. 1. Which will you do first: #1 in your pants, or #2 in your pants? 2. What will be your last words on the CVR, "Oh, ****!" or "Merde!"? 3. Who inherits the rice cooker? |
"John Mazor" wrote in
news:n1Ufj.2328$qV.1876@trnddc03: "Bertie the Bunyip" wrote in message ... William Hung wrote in news:f03d3e7c-260e-40d5-9b36- : On Jan 5, 3:12 pm, Bertie the Bunyip wrote: William Hung wrote in news:4a5c2933-0efd-4acc- be6a- : http://uk.youtube.com/watch?v=9KhZws...eature=related The beginning of the vid looks so unreal, but apparently it is real. Yeah, it's real. Herons, I think . Bertie Looks like they took awhile to shut off the fuel to #2 engine. Yeah, it's not a priority, really. the engine is on fire all the time and from the look of it it was still producing thrust anyway. The procedure is this ( though it varies form airline to airline) The takeoff was more than likely done at rduced thrust in the first place. Looks like the ingestion happend just after rotation so it was "go" without any question about it. First thing is the non handling pilot calls out the nature of the failure. in this case, he probably just said "engine failure, right engine" and nothing else is done except to raise the gear at positive rate and cancel any aural warnings. the next is to select full thrust on the live engine. If they had RR engines, they would have firewalled them, if it was Pratts, thye would have set max TO thrust. they were probably passing about 200 feet when all this happened. Note, the full thrust thing is not required, just nice to do. Next, after they were stablised in the climb, they handling pilot would have asked to confirm the nature of the problem. the NH would have spelled out what he thinks it is in detail and the non handling would ask for the engine fire checklist (this is used by most boeing operators these days for all engine probs whether or not the engne is actually burning) The NH woudl initiate it using the memory items startinf with the autothrottle switch to off, the thrust lever affected engine to idle, the start switch ( fuel) to off and th efire switch to pull and then if there is a fire, to rotate to fire first one bottle of extinguishant then the second after 30 seconds. At each item, the handling pilot must confirm that he has the correct thrust lever, switch, whatever, so as to minimise the chance of screwing up and shutting down the wrong one. By the time al this is done, you're easily at 1,000' and it's time to level off and accelerate, cleaning up. If you're coing straight back though, it;s probably best to leave the flaps where they are and get into the remeaining checklists in order to tidy the airplane up for landing. You left Anthony in the dust at "non-handling pilot". Well, the non handling part should be right up his street. Here's another thought experiment for him: You are the NHP in a real cockpit and incur a bird-strike flameout right after rotation. 1. Which will you do first: #1 in your pants, or #2 in your pants? 2. What will be your last words on the CVR, "Oh, ****!" or "Merde!"? 3. Who inherits the rice cooker? Bwsahwhahwhahwhahwhahwhahwhahwhahwhhahwhahw! Bertie |
On Jan 5, 2:39*pm, Bertie the Bunyip wrote:
William Hung wrote in news:f03d3e7c-260e-40d5-9b36- : On Jan 5, 3:12*pm, Bertie the Bunyip wrote: William Hung wrote in news:4a5c2933-0efd-4acc- be6a- : http://uk.youtube.com/watch?v=9KhZws...eature=related The beginning of the vid looks so unreal, but apparently it is real. Yeah, it's real. Herons, I think . Bertie Looks like they took awhile to shut off the fuel to #2 engine. Yeah, it's not a priority, really. the engine is on fire all the time and from the look of it it was still producing thrust anyway. The procedure is this ( though it varies form airline to airline) The takeoff was more than likely done at rduced thrust in the first place. Looks like the ingestion happend just after rotation so it was "go" without any question about it. First thing is the non handling pilot calls out the nature of the failure. in this case, he probably just said "engine failure, right engine" and nothing else is done except to raise the gear at positive rate and cancel any aural warnings. the next is to select full thrust on the live engine. If they had RR engines, they would have firewalled them, if it was Pratts, thye would have set max TO thrust. they were probably passing about 200 feet when all this happened. Note, the full thrust thing is not required, just nice to do. Next, after they were stablised in the climb, they handling pilot would have asked to confirm the nature of the problem. the NH would have spelled out what he thinks it is in detail and the non handling would ask for the engine fire checklist (this is used by most boeing operators these days for all engine probs whether or not the engne is actually burning) The NH woudl initiate it using the memory items startinf with the autothrottle switch to off, the thrust lever affected engine to idle, the start switch ( fuel) to off and th efire switch to pull and then if there is a fire, to rotate to fire first one bottle of extinguishant then the second after 30 seconds. At each item, the handling pilot must confirm that he has the correct thrust lever, switch, whatever, so as to minimise the chance of screwing up and shutting down the wrong one. By the time al this is done, you're easily at 1,000' and it's time to level off and accelerate, cleaning up. If you're coing straight back though, it;s probably best to leave the flaps where they are and get into the remeaining checklists in order to tidy the airplane up for landing. Bertie- Hide quoted text - I have read that the 737 has a higher takeoff weight than landing weight -- ie you could takeoff heavier than you could land. Is that so? Is it just a recommendation? If this were to happen in a 737 and you need to land right away, is the weight issue blown off? (which leads me to suspect that it can be blown off, ie, it is a recommendation). If not, why would you ever take off heavier than you could successfully land? |
| F-111 bird strike | Don Pyeatt | Aviation Photos | 3 | May 23rd 07 04:28 AM |
| Bird strike | Bob Chilcoat | Piloting | 5 | September 6th 05 08:05 AM |
| Bird strike | Jase Vanover | Piloting | 16 | May 17th 05 12:44 PM |
| AA bird strike | PaulH | Piloting | 0 | October 7th 04 03:20 PM |
