#11
Those ARE BNC, Robert. What the OP was asking was whether or not the way
the cable was attached to the connector could be one of the kind where you simply strip the outer sheath back an inch or so, strip the center insulator back a quarter of an inch, put a threaded ferrule over the outer shield of the connector, slide the inner insulator into the body of the connector and then thread the ferrule into a mating thread on the connector. No crimp, no solder. The consensus, and I heartily agree, that those "twist on" BNC connectors aren't worth powdered bat **** as an RF connector, much less an aircraft RF connector. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford "Robert M. Gary" wrote in message ... On Jan 14, 4:48 pm, John Smith wrote: In article , Jim Stewart wrote: Are they acceptable for avionics use? I wouldn't recommend them. Maybe as a temporary emergency repair, but not for something you want to depend on. I always thought that the half turn connectors that are the standard in avionics were called BNC. If not, what are they called? -Robert |
Ron Wanttaja wrote:
Me, I just go to the local computer store and buy some of the pre-made RG-58 cables with BNC connectors already attached..... Done that lately, Ron? BNC is used with 10Base2 ethernet cables. 10Base2 has been obsolete for almost a decade. Maybe you shop in a better computer store than I do, but I know all the ones I frequent wouldn't even know what a coax network cable was. -- Frank Stutzman Bonanza N494B "Hula Girl" Boise, ID |
On Sat, 19 Jan 2008 16:04:59 +0000 (UTC), Frank Stutzman
wrote: Ron Wanttaja wrote: Me, I just go to the local computer store and buy some of the pre-made RG-58 cables with BNC connectors already attached..... Done that lately, Ron? BNC is used with 10Base2 ethernet cables. 10Base2 has been obsolete for almost a decade. Maybe you shop in a better computer store than I do, but I know all the ones I frequent wouldn't even know what a coax network cable was. I bought some cables when I installed the handheld in the panel, about two-three years ago. I called the place a "computer store" because I bought my VIC-20 from them about twenty-five years ago, and old habits die hard. :-) But they haven't sold actual computers for about fifteen years, switching to electronics parts and test equipment for the local hobbyists and repairmen. Ron Wanttaja |
RST Engineering wrote:
Those ARE BNC, Robert. What the OP was asking was whether or not the way the cable was attached to the connector could be one of the kind where you simply strip the outer sheath back an inch or so, strip the center insulator back a quarter of an inch, put a threaded ferrule over the outer shield of the connector, slide the inner insulator into the body of the connector and then thread the ferrule into a mating thread on the connector. No crimp, no solder. The consensus, and I heartily agree, that those "twist on" BNC connectors aren't worth powdered bat **** as an RF connector, much less an aircraft RF connector. I dunno about that, Jim. Prices seem to be going up. https://www.stealthhydroponics.com/s...FQiaPAodZU-LIA |
LLC ownership of airplane -- another twist | xyzzy | Owning | 10 | June 16th 07 04:34 PM |
SR-22 Crash, with a twist | john smith | Piloting | 47 | March 20th 07 11:49 PM |
Battery Connectors | Paul Remde | Soaring | 9 | April 9th 06 06:39 PM |
A new twist on complaints | Roger | Piloting | 37 | November 11th 05 08:50 AM |
Solid joystick (X-45 or HOTAS quality) with a *twist*? | Zenin | Simulators | 3 | January 26th 04 06:30 AM |
