Weak link - single or reserve?
Old January 18th 08, 10:29 PM posted to rec.aviation.soaring
Malcolm Austin
Default Weak link - single or reserve?
Andreas,
I agree that would seem to be a problem for that location.
But I
have not seen it arise for the main winch rope. We do use a 15 metre length
of stiffer and thicker rope after the main winch rope which also might help
counteract that.
The cost and wear properties on our grass strip, plus the almost complete
lack of winch failures is a real plus. Even nicer is the handling side for
the winch man. It's 100% safer and we get no cut fingers. A repair
(splice) can be carried out in a few minutes with a pen knife and some tape
to cover the 3 ends of the rope. The section closest to the winch suffers
most wear, but this is easily and quickly replaced and minimal cost.Also
the guide rolls on the winch after about 8 months of use show zero wear.
I drive the winch every few weeks and after the 18 months of so of usage I
would hate to go back to steel. And as said before the amount of weak link
failures is virtually nil now.
Cheers,
Malcolm...
"Andreas Maurer" wrote in message
On Fri, 18 Jan 2008 16:16:22 GMT, "Malcolm Austin"
At our club (Denbigh GC, UK) we changed the steel wire for a type of
polypropylene
rope. The shock absorbing properties of this have reduced the incidence
of
weak link
breaks to almost zero.
I know of a club that also used a polypropylene rope between aircraft
and weak link.
They stopped using that after this rope got entangled within the gear
of an ASK-21, leading to a severe ground loop immediately prior to
lift-off.
The stiffness of the steel wire prevents such an event.
Bye
Andreas
Old January 19th 08, 12:23 AM posted to rec.aviation.soaring
Z Goudie
At 15:48 18 January 2008, Andreas Maurer wrote:
- weak links that impact tarmac after release are more
prone to fail
Install weak links within an equivalent length of narrow
steel channel (with a hole at one end and a slot at
the other) as protection from wear/impact damage.
Old January 19th 08, 01:13 AM posted to rec.aviation.soaring
Cats
At our club (Denbigh GC, UK) *we changed the steel wire for a type of
polypropylene
rope. *The shock absorbing properties of this have reduced the incidence of
weak link
and weak link.
lift-off.
That's partly why the strops our weak links are attached are inside
some kind of plastic tube. I have a feeling the BGA recommends this
but I can never find stuff on their website, so don't know if I'm
imagining that.
Old January 19th 08, 01:30 AM posted to rec.aviation.soaring
Andreas Maurer[_1_]
On Fri, 18 Jan 2008 16:13:36 -0800 (PST), Cats
imagining that.
If you need some written arguments: The German SBO explicitly demands
a stiffened rope between glider and weak link.
See here (if you speak German):
http://www.daec.de/se/downfiles/sbo.pdf
Bye
Andreas
Old January 19th 08, 04:46 AM posted to rec.aviation.soaring
nimbusgb
imagining that.
http://www.gliding.co.uk/forms/clubm...t/winchops.pdf
and
http://www.gliding.co.uk/bgainfo/doc...chguidance.pdf
Finding stuff on the site is a pain, especially since the search
facility is useless!
Ian M
Old January 19th 08, 10:14 AM posted to rec.aviation.soaring
Cats
some kind of plastic tube. *I have a feeling the BGA recommends this
imagining that.
andhttp://www.gliding.co.uk/bgainfo/documents/safewinchguidance.pdf
Thanks. I knew it was in there somewhere!
Old January 19th 08, 10:16 AM posted to rec.aviation.soaring
Gavin Short
are inside
recommends this
know if I'm
imagining that.
From the BGA website
http://www.gliding.co.uk/forms/lawsandrules.pdf
Page 52, RP (Recommended Practice) 7
Gavin
Std Cirrus, CNN now G-SCNN, #173
Old January 19th 08, 11:31 AM posted to rec.aviation.soaring
Ian
On 18 Jan, 23:23, Z Goudie
prone to fail
I thought that was part of the standard Tost kit.
Ian
Old January 19th 08, 07:29 PM posted to rec.aviation.soaring
Tom Nau
On Jan 18, 8:40*am, "Jesper Thomsen" wrote:
"Tom Nau" wrote in message
Hi All,
Our commercial operation (more like a club) is starting to do winch
launches. *I just bought a Tost weak link for my glider from W&W. *Are
most people using a "single" weak link or a "single and a reserve"
weak link? * Thanks.
Tom Nau
In Denmark where winch launching is about 90% of all starts, we also used
backup weak links for a while, but they've almost all disappeared again.
Experience shows that the second weak link is not strong enough to stand up
to the forces that appear when the primary weak link breaks (for whatever
reason). The Net result is that you break two weak links instead of just
one, and you don't get any added security or resilience for the price of the
second weak link.
Plus you add the unnecessary complexity of having to check that the two weak
links are different and that either didn't break during the last launch,
plus you're dragging two weak links through stones, dust, mud, grass etc.
instead of just one.
/J
Thank you, everyone, for your input.
Tom Nau
San Antonio, Texas
Old January 19th 08, 08:25 PM posted to rec.aviation.soaring
Z Goudie
Use a SERIOUS piece of steel channel!
OLC - 2008 - DO NOT USE 2007 URL LINK, or current ssa.org link [email protected] Soaring 1 October 25th 07 05:37 PM
IFR w/pax under Single-Pilot/Single Aircraft 135 Bravo8500 Owning 20 March 9th 05 10:37 PM
Weak link for PW-5 Nyal Williams Soaring 4 June 1st 04 08:46 AM
Weak link for winch launch - 1-26E??? Mark Zivley Soaring 4 April 29th 04 11:38 PM
Blanik Weak Link for Winch Launch??? Gary Emerson Soaring 6 February 24th 04 09:08 PM
