Does anyone have any experience with one of these devices?
PCAS XRX $1795 PCAS MRX $549 Is there enough value in XRX's ability to show direction? Last year I flew a plane from NH to PA. I had a Garmin 430 with traffic. I was at 8,000 feet and about 80 nm west of New York City when the instrument warned me about a potential collision with a fast moving aircraft. I had to dive to avoid collision and with my family on board it was not a good experience. The worst part was that I was assigned a transponder code and I used flight following. It seems our ATC is quite broken these days. Anyway, I am looking for traffic warning device for my glider. If XRX is worth the price I will buy it, but in a glider I am not sure it makes a difference, especially while circling. Please share your experience. AK |
Search the archives and you should find quite a few favorable mentions
of the MRX. I'm not sure how practical the XRX would be in a sailplane. It is relatively large/cumbersome - where would you put it? has a cooling fan etc. and draws considerably more power than the MRX. With the MRX warning induced scanning for traffic sees to work well, false positives are not an issue. Darryl On Jan 22, 7:02 pm, AK wrote: Does anyone have any experience with one of these devices? PCAS XRX $1795 PCAS MRX $549 Is there enough value in XRX's ability to show direction? Last year I flew a plane from NH to PA. I had a Garmin 430 with traffic. I was at 8,000 feet and about 80 nm west of New York City when the instrument warned me about a potential collision with a fast moving aircraft. I had to dive to avoid collision and with my family on board it was not a good experience. The worst part was that I was assigned a transponder code and I used flight following. It seems our ATC is quite broken these days. Anyway, I am looking for traffic warning device for my glider. If XRX is worth the price I will buy it, but in a glider I am not sure it makes a difference, especially while circling. Please share your experience. AK |
AK,
I have been using the PCAS MRX for almost 2 years and am really pleased with this product. Since I purchased my MRX, I have had to send it back because it had stopped working (Bad Filter??). I had it fixed/replace within a weeks time. Two members have also purchased this item and have not had any problems. Randy N304RS www.tulsasoaring.com |
We have installed several MRX devices in gliders, and I have one top center on my Duo instrument panel. They really work! Understand they only detect other aircraft with a working transponder, however these fast movers are the aircraft I am most concerned about. Many aircraft also have devices to detect other aircraft with transponders, so my Duo also has a transponder. Tom Knauff Knauff & Grove Soaring Supplies www.eglider.org |
I have been using the MRX for over a year now.
Yes it has been a good equipment to have. My only gripe however, is about the rate it finds a traffic. There has been a few times where I saw a target well before the MRX picked it up. Also, I found the altitude where it shows the traffic not entirely reliable. But then, it must be because of the target's transponder, which could differ by a few hundred feet itself, and also the rate of climb or descent you get while circling. For example, if the unit tells you that a traffic is 300 feet above you, you better start scanning +-200 feet from that. I also used it in airplanes in busy areas like in the Los Angeles basin and Phoenix airspace, and it is nearly useless, as it picks up too many targets!...:-) However, it is largely compensated by the fact that it did pick up traffics when I had no clue they were there, 98% of the time. Richard Depinay Phoenix, AZ |
On Jan 22, 8:02*pm, AK wrote:
Does anyone have any experience with one of these devices? PCAS XRX $1795 PCAS MRX $549 I use the MRX in my PA28-180 and in my sailplane. I am pleased with the performance of the MRX and would not hesitate to recommend it. The only issue I am aware of with using the MRX in a sailplane is that it will continuously alarm if you thermal with a transponder equipped glider. This means you have no protection from other traffic. Zaon was requested to add intelligent muting capability but says the processor is not powerful enough to implement that. I would not consider an XRX for sailplane use. It's too big. To answer jeplane's comment - I also fly in the Phoenix area (DVT based) and, with the alerting volume set small, I find it very useful. Andy |
If you are going to the SSA Convention, join us at 4PM on Wed, 2/13 for a
session on FLARM / ADS-B and Collision Avoidance. Mike Schumann "AK" wrote in message ... Does anyone have any experience with one of these devices? PCAS XRX $1795 PCAS MRX $549 Is there enough value in XRX's ability to show direction? Last year I flew a plane from NH to PA. I had a Garmin 430 with traffic. I was at 8,000 feet and about 80 nm west of New York City when the instrument warned me about a potential collision with a fast moving aircraft. I had to dive to avoid collision and with my family on board it was not a good experience. The worst part was that I was assigned a transponder code and I used flight following. It seems our ATC is quite broken these days. Anyway, I am looking for traffic warning device for my glider. If XRX is worth the price I will buy it, but in a glider I am not sure it makes a difference, especially while circling. Please share your experience. AK -- Posted via a free Usenet account from http://www.teranews.com |
"AK" wrote in message ... Does anyone have any experience with one of these devices? PCAS XRX $1795 PCAS MRX $549 Thanks for bringing up this subject. I see that they have finally added an audio output jack/headset cable to the MRX. Without that feature, I considered the MRX to be useless for any powered aircraft. Now I guess I have to spend my money. Vaughn |
On Jan 23, 3:51*pm, "Vaughn Simon"
wrote: "AK" wrote in message ... Does anyone have any experience with one of these devices? PCAS XRX $1795 PCAS MRX $549 * *Thanks for bringing up this subject. *I see that they have finally added an audio output jack/headset cable to the MRX. *Without that feature, I considered the MRX to be useless for any powered aircraft. *Now I guess I have to spend my money. Vaughn I fly a Bonanza with Bose NR headsets and can hear the MRX alerts with it mounted on the glareshield (without a headset cable). Tom |
On Jan 23, 2:51*pm, "Vaughn Simon"
wrote: *I see that they have finally added an audio output jack/headset cable to the MRX. *Without that feature, I considered the MRX to be useless for any powered aircraft. * The alarm is easily audible in my PA-28 when wearing my passive DC 13.4S headset. ANR headsets typical have no active cancelling in the higher fequencies so I think it would also be easily audible wearing ANRs. Having said that, mine is going in for a firmware update this week and I decided to pay to add the audio jack in case I need it in the future. I'm not sure it would be loud enough in a Husky for example. Andy |
| Thread Tools | |
| Display Modes | |
| Floatation Devices | Mike 'Flyin'8' | Piloting | 7 | February 27th 05 11:21 PM |
| Traffic Warning | skybug | Aviation Marketplace | 0 | November 19th 04 07:33 AM |
| Traffic 2004 vs Ultimate Traffic | Tlewis95 | Simulators | 3 | August 13th 04 06:39 AM |
| Devices for avoiding VNE? | John Galloway | Soaring | 100 | April 12th 04 09:53 PM |
| New traffic warning device | Loran | Products | 26 | February 18th 04 01:14 AM |
