Japanese AA Weapon?
Old October 31st 03, 12:20 AM
Gernot Hassenpflug
"Keith Willshaw" writes:
From
http://www.warships1.com/Weapons/WNJAP_18-45_t94.htm
"As were most Japanese warships, the Yamato and Musashi were provided with a
special anti-aircraft incendiary shrapnel shell officially designated as
"Type 3 Common" but nicknamed "San Shiki" (The Beehive). This round weighed
Correction to the quoted part: `san shiki' is merely Japanese for Type
3, the short form of the name of the shell. I could't find out what
the nickname was in Japanese, but beehive is `mitsuhachi no su', not
very catchy. In the past, `beehive' was also known as `hankyujo'
(lit. 'hemisphere-shape'), which sounds a lot more likely. Anyone
else know for sure ?
G Hassenpflug * IJN & JMSDF equipment/history fan
Old October 31st 03, 10:51 AM
Cub Driver
Adopted in the year 2603 of the Japanese throne.
As a means of identifying military gear, year-adopted is one of the
most confusing, especially with the pace of adoption in the war years.
The most famous example of this system, and the only one that has made
it into English, is the A6M "Zero" -- adopted in, you got it, 2600.
This was actually considered to be the *long* system. (The full &
proper name is Type Zero Carrier Fighter.) A6M is the short system,
and was adopted from the U.S. Navy: purpose - sequence number -
manufacturer.
www.warbirdforum.com/zero.htm
all the best -- Dan Ford
email:
see the Warbird's Forum at
and the Piper Cub Forum at www.pipercubforum.com
Old October 31st 03, 05:45 AM
robert arndt
"Keith Willshaw" wrote in message ...
"Kenneth Williams" wrote in message
Did the Japanese battleship Yamato ever fire an AA salvo during WW2?
A visiting friend of mine in the Navy told me the Japanese had a
battery-fired AA weapon that was actually fired in battle.
I guess it didn't work as the ship was sunk!
Anyone know what this weapon was?
From
2,998 lbs. (1,360 kg) and was filled with 900 incendiary tubes made out of
rubber thermite and 600 steel stays. A time fuze was used to set the
desired exploding distance, usually about 1,000 meters (1,100 yards). These
projectiles were designed to burst in a 20 degree cone extending towards the
oncoming aircraft with the projectile shell itself being destroyed by a
bursting charge to increase the quantity of steel splinters. The incendiary
tubes ignited about half a second later and burned for five seconds at 3,000
degrees C, producing a flame about 5 meters (16 feet) long. "
Keith
As noted in the link Keith provided the Musashi ruined one of her 18
inch guns the very first time she fired the Sankaiden ammo. The AA
rounds weren't bore safe and Musashi's detonated prematurely.
It should also be noted that Sankaiden ammo was not just for use by
the Japanese big battleships. The ammo was introduced in 1942 starting
with 8 inch guns and moving up to the big 18s of Yamato and Musashi.
They were, however, not effective in any caliber and most damaged the
ship's guns that fired them.
Rob
Old October 31st 03, 10:43 AM
Cub Driver
Sounds a bit more sophisticated than putting up waterspouts!
As I recall, Yamato did sortie, so presumably it did fire some guns,
though that is hardly certain. It could have been a species of
proactive scuttling.
Keith
email:
Old October 31st 03, 04:36 PM
Gernot Hassenpflug
Cub Driver writes:
Japanese accounts that I have read mention that the weather was so
poor, with low cloud, that the attacking aircraft could not be seen
until they were already far too close to be engaged by the main
battery. The overwhelming importance of radar for ships against
aircraft....
Old November 1st 03, 04:27 AM
WaltBJ
The book "A Glorious Way To Die" has the tale of Yamato's last sortie.
It was truly a one-way ride - the ship didn't have enough fuel to get
back home and the end game was to beach it at Okinawa and use it as an
artillery emplacement.
Walt BJ
russia vs. japan in 1941 [WAS: 50% of NAZI oil..] Military Aviation 136 December 6th 03 10:40 PM
OT- north korean nuke weapon plutonium - source? patrick mitchel Military Aviation 11 August 31st 03 04:01 AM
AIRCRAFT MUNITIONS - THE COBALT BOMB Garrison Hilliard Military Aviation 1 August 29th 03 09:22 AM
Japanese Army Navy Keith Willshaw Military Aviation 35 July 29th 03 03:22 AM
Rapists and Robbers have a New Weapon Bumper7 Aerobatics 0 July 17th 03 09:37 AM
