By God Kevin your idea may not be the best, but it is certainly the first
time I've heard that one. One problem tho I have to carry those wheels by hand and at my advancing age, it may exceed my capacity. Would the wheels weigh more than a 6 pack? Stu "The OTHER Kevin in San Diego" skiddz "AT" adelphia "DOT" net wrote in message ... On Mon, 28 Jan 2008 10:21:11 -0800, "Stuart & Kathryn Fields" wrote: I recently tried a pair of Marathon flat free wheelbarrow tires to replace my pneumatic tires that had developed the habit of slowly leaking out the air. @#$%^ The rolling resistance was so great I couldn't move the helicopter by myself. In fact even with my wife's help it was very hard to get the helicopter moved on concrete with the flat free tires. Looking at the contact patch, there was approximately a 3" long contact area. Replacing the flat free with the pneumatics, I was again able to relatively easily move the helicopter. Weight of the helicopter was slightly less than the reported capacity of the flat free tires. Any suggestions? Pneumatics filled with concrete. ![]() |
The wheels for my 269A were aluminum and the tires were inflated to
70psi. The aluminum wheels meant that I could take them along if needed and if the tires were kept at approximately 70 it was an easy push (on a level hard surface). An acquaintance of mine had similar tires for his 500 filled with some sort of rigid foam (for tractor tires, I believe). This gave a airless tire that was about as stiff as the one with 70psi. Gary Stuart & Kathryn Fields wrote: By God Kevin your idea may not be the best, but it is certainly the first time I've heard that one. One problem tho I have to carry those wheels by hand and at my advancing age, it may exceed my capacity. Would the wheels weigh more than a 6 pack? Stu "The OTHER Kevin in San Diego" skiddz "AT" adelphia "DOT" net wrote in message ... On Mon, 28 Jan 2008 10:21:11 -0800, "Stuart & Kathryn Fields" wrote: I recently tried a pair of Marathon flat free wheelbarrow tires to replace my pneumatic tires that had developed the habit of slowly leaking out the air. @#$%^ The rolling resistance was so great I couldn't move the helicopter by myself. In fact even with my wife's help it was very hard to get the helicopter moved on concrete with the flat free tires. Looking at the contact patch, there was approximately a 3" long contact area. Replacing the flat free with the pneumatics, I was again able to relatively easily move the helicopter. Weight of the helicopter was slightly less than the reported capacity of the flat free tires. Any suggestions? Pneumatics filled with concrete. ![]() |
Gary: Thanks. You don't know where the rigid foam came from do you?
Stu "gk" wrote in message ... The wheels for my 269A were aluminum and the tires were inflated to 70psi. The aluminum wheels meant that I could take them along if needed and if the tires were kept at approximately 70 it was an easy push (on a level hard surface). An acquaintance of mine had similar tires for his 500 filled with some sort of rigid foam (for tractor tires, I believe). This gave a airless tire that was about as stiff as the one with 70psi. Gary Stuart & Kathryn Fields wrote: By God Kevin your idea may not be the best, but it is certainly the first time I've heard that one. One problem tho I have to carry those wheels by hand and at my advancing age, it may exceed my capacity. Would the wheels weigh more than a 6 pack? Stu "The OTHER Kevin in San Diego" skiddz "AT" adelphia "DOT" net wrote in message ... On Mon, 28 Jan 2008 10:21:11 -0800, "Stuart & Kathryn Fields" wrote: I recently tried a pair of Marathon flat free wheelbarrow tires to replace my pneumatic tires that had developed the habit of slowly leaking out the air. @#$%^ The rolling resistance was so great I couldn't move the helicopter by myself. In fact even with my wife's help it was very hard to get the helicopter moved on concrete with the flat free tires. Looking at the contact patch, there was approximately a 3" long contact area. Replacing the flat free with the pneumatics, I was again able to relatively easily move the helicopter. Weight of the helicopter was slightly less than the reported capacity of the flat free tires. Any suggestions? Pneumatics filled with concrete. ![]() |
Gary: Thanks. You don't know where the rigid foam came from do you? Stu "gk" wrote in message ... The wheels for my 269A were aluminum and the tires were inflated to 70psi. The aluminum wheels meant that I could take them along if needed and if the tires were kept at approximately 70 it was an easy push (on a level hard surface). An acquaintance of mine had similar tires for his 500 filled with some sort of rigid foam (for tractor tires, I believe). This gave a airless tire that was about as stiff as the one with 70psi. Michelin makes foam "tubes" for motorcycles, maybe for other applications as well. I've heard they're an ordeal to install or remove. Google "Bib Mousse" |
I'll carry the beer if you carry the wheels.
Stu "The OTHER Kevin in San Diego" skiddz "AT" adelphia "DOT" net wrote in message ... On Tue, 29 Jan 2008 12:44:28 -0800, "Stuart & Kathryn Fields" wrote: By God Kevin your idea may not be the best, but it is certainly the first time I've heard that one. One problem tho I have to carry those wheels by hand and at my advancing age, it may exceed my capacity. Would the wheels weigh more than a 6 pack? Depends on the 6-pack I guess... I've seen six packs of 44 oz bottle before... That's 264 fl. oz. Figure if water is 8lbs gallon, beer (I'm sssuming we're talking beer here) has alcohol in it so let's guess at 6lbs/gallon for weight. 1 Gallon is 128 fl. oz and we've got 2.0625 gallons of beer. That's 12lbs 6 oz. (12.375 oz for the decimally inclined) of beer... So now, I guess it depends on the size of the wheel/tire combo.. ![]() |
"Clark" wrote in message
... The OTHER Kevin in San Diego skiddz "AT" adelphia "DOT" net wrote in : On 31 Jan 2008 06:24:36 GMT, Clark wrote: If it's American beer then it's nearly water... Depends on the American beer. Bud, Coors, Miller etc.. Yeah, pretty much water.. And the rest of the American beers are poorly disguised soda pop... Hey, watch it! There's no reason to be insulting soda pop like that....... ;-) |
Yeah, Yeah, Yeah. If I announce a free beer bust, I'll bet the only
questions I hear are Where? The beer brand will be discussed after the mugs are filled. Stu "Steve R." wrote in message ... "Clark" wrote in message ... The OTHER Kevin in San Diego skiddz "AT" adelphia "DOT" net wrote in : On 31 Jan 2008 06:24:36 GMT, Clark wrote: If it's American beer then it's nearly water... Depends on the American beer. Bud, Coors, Miller etc.. Yeah, pretty much water.. And the rest of the American beers are poorly disguised soda pop... Hey, watch it! There's no reason to be insulting soda pop like that....... ;-) |
| Thread Tools | |
| Display Modes | |
| There I was, flat on my back... | Kyle Boatright | Home Built | 5 | August 16th 07 06:34 AM |
| Flat tire | Viperdoc[_4_] | Piloting | 11 | June 4th 07 03:57 PM |
| Seeking S-H ground handling accessories (V2C) | [email protected] | Soaring | 2 | September 14th 06 02:03 AM |
| Ford Tri-Motor ground handling in FS2004 is ridiculous. | Bass | Simulators | 3 | December 19th 04 09:37 PM |
| NEEDED: Aircraft Ground Handling Information | Jarry Clausing | Products | 0 | August 9th 03 04:24 PM |
