Night VFR following highways
Old February 4th 08, 02:44 PM posted to rec.aviation.student,rec.aviation.piloting
Gig 601XL Builder[_2_]
Default Night VFR following highways
Mxsmanic wrote:
From the article above I learned that things like wires and cables
are a real risk if you're very close to the highway, but only a helicopter
would be that low.
Why would you say that?
There are no differences in the allowed altitudes for fixed wing and
rotary wing aircraft. And in a helo, just like in fixed wing, the more
altitude the more options when there is a failure.
Old February 4th 08, 06:51 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Gig 601XL Builder writes:
Helicopters can move more safely at very low altitudes because they are not
obligated to move forward at any minimum speed.
There are big differences in flying over a road at 25 feet and 3 knots, and
flying over a road at 25 feet and 95 knots.
And in a helo, just like in fixed wing, the more altitude the
But at extremely low altitudes, the number of options required is reduced. If
the engine fails in a helicopter at ten feet above the ground, it's not really
a crisis. On a large flat area of ground, this can be true for an airplane,
too, but airplanes have the added danger of rapid forward movement.
Old February 2nd 08, 02:27 AM posted to rec.aviation.student,rec.aviation.piloting
Kyle Boatright
"Ross" wrote in message
Mxsmanic wrote:
Is it a bad idea to fly VFR at night and navigate by following highways?
At
night outside large cities, there doesn't seem to be much else that's
visible.
It seems to me that if you can clearly see the highway, it can guide you
and
you can get a good idea of where you are with respect to terrain, so it
should
work. Are there hidden dangers in this? Do night VFR pilots ever/often
navigate by following highways? What other forms of visual navigation
are
usable at night?
Why would you want to when VORs ang GPSs are available? However, on a
clear night you can see the far away town lights. You just need to be sure
that the lights you see are the town you want. I'll stay with my GPS for
navigation.
Regards, Ross
C-172F 180HP
KSWI
I'm not IFR qualified and have followed known (to me) interstates on murky
nights when I was over the boonies and the murk was sufficient to block out
the moon and stars. In rural areas, headlights on the highways can be your
only visual tell-tale for up vs down on a murky night.
Been there, done that.
KB
Old February 1st 08, 07:27 PM posted to rec.aviation.student,rec.aviation.piloting
Bertie the Bunyip[_25_]
Mxsmanic wrote in
highways? At night outside large cities, there doesn't seem to be
much else that's visible. It seems to me that if you can clearly see
the highway, it can guide you and you can get a good idea of where you
are with respect to terrain, so it should work. Are there hidden
dangers in this? Do night VFR pilots ever/often navigate by following
highways? What other forms of visual navigation are usable at night?
I use the reflection of the table lamp on my monitor screen.
Bertie
Old February 1st 08, 08:22 PM posted to rec.aviation.student,rec.aviation.piloting
Please note that MX is xposting to R.A.S.
Old February 1st 08, 09:00 PM posted to rec.aviation.student,rec.aviation.piloting
gatt[_2_]
"Gig 601XL Builder" wrote in message
He's asking a legitimate question, though. That's useful on R.A.S. (so
far), so I took it at face value.
-c
Old February 1st 08, 08:35 PM posted to rec.aviation.student,rec.aviation.piloting
In rec.aviation.piloting Mxsmanic wrote:
Is it a bad idea to fly VFR at night and navigate by following highways? At
night outside large cities, there doesn't seem to be much else that's visible.
It seems to me that if you can clearly see the highway, it can guide you and
you can get a good idea of where you are with respect to terrain, so it should
navigate by following highways? What other forms of visual navigation are
usable at night?
About the only reason to follow highways (other than it just happens to
go where you want to go) at night is you are guaranteed that there is
nothing directly above the highway (such as a mountain peak), which is
handy for going through things like passes on dark nights and areas
dotted with high peaks.
However, the only way one would know visually that they are really
over most highways at night is from the real lights of real traffic.
Since there is no real traffic on your simulated highways with real
headlights, why would you care?
Jim Pennino
Remove .spam.sux to reply.
Old February 1st 08, 08:45 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
writes:
Actually, the sim does put traffic on the highways.
Old February 1st 08, 09:07 PM posted to rec.aviation.student, rec.aviation.piloting
On Feb 1, 1:51*pm, Bertie the Bunyip wrote:
Mxsmanic wrote :
writes:
No it doesn't. it makes little colored pixtels.
Bertie
Actually, it simulates little colored pixels which simulate cars in a
simulated world so that people with nothing better to do can simulate
living their lives.
Arizona Highways magazine on soaring, flight [email protected] Soaring 0 December 20th 06 03:05 AM
Night Flying. How many PPSEL pilots excersie night priveledges? [email protected] Piloting 42 December 16th 06 04:51 PM
Night lights, night flights, OLC and records Denis Soaring 19 October 9th 06 11:51 PM
Hood and sim work at night loggable as night time? Ron Garret Piloting 12 September 9th 06 02:15 AM
FS2004 scenery which shows roads and highways? John Doe Simulators 9 March 25th 04 08:36 AM
