![]() So, logically, spacecraft in the frictionless environment of outer space should immediately accelerate to the speed of light. Some haphazard math here.. if space is indeed entirely frictionless, which I highly doubt, then to accelerate a body of weight 1kg (2.2 lbs) to the speed of light (using a constant force of 1N (or 1 m/sec2 acceleration) would require a distance of 4.5*(10^16) meters or about 45000000000000 km which is about 300 billion miles. The work done/ energy needed would be about 450 trillion joules. The time needed to achieve this feat would be about 9.5 yrs.. so no its not instantaneous ![]() |
It would take infinite amount of energy to accelerate any non-zero
mass to the speed of light. On Feb 9, 12:37*am, wrote: So, logically, spacecraft in the frictionless environment of outer space should immediately accelerate to the speed of light. Some haphazard math here.. if space is indeed entirely frictionless, which I highly doubt, then to accelerate a body of weight 1kg (2.2 lbs) to the speed of light (using a constant force of 1N (or 1 m/sec2 acceleration) would require a distance of 4.5*(10^16) meters or about 45000000000000 km which is about 300 billion miles. The work done/ energy needed would be about 450 trillion joules. The time needed to achieve this feat would be about 9.5 yrs.. so no its not instantaneous ![]() |
On Feb 10, 4:36*pm, Tina wrote:
It would take infinite amount of energy to accelerate any non-zero mass to the speed of light. Ah an oft stated idea but why? Is E not 0.5MC^2 ? Where's the Ken when we need it? Cheers |
WingFlaps wrote: It would take infinite amount of energy to accelerate any non-zero mass to the speed of light. Ah an oft stated idea but why? Is E not 0.5MC^2 ? reaching way way Way WAY back into college physics let's see if I remember this correctly... because mass increases with velocity. If pressed, I may even be able to find the formula in my quantum text. -- Bob Noel (goodness, please trim replies!!!) |
![]() It would take infinite amount of energy to accelerate any non-zero mass to the speed of light. True, I just wanted to stay within the realms of Newtonian mechanics for simplicity because the poster seemed to imply that a body will reach a velocity of c if there is no friction instantaneously.. |
On Feb 6, 10:19*am, wrote:
Fixed-wing aircraft taxi because their wheels reduce friction as they move forward on the ground. Wrong. Wrong. Wrong. Fixed-wing aircraft can only achieve a stable taxi by keeping the CG between the forward and aft wheel points(WPs). This is why it is so important in aircraft design that the WPs be placed correctly. In the early days of aviation some designers placed all the wheels to one side of the CG, with the result that the aircraft was dynamically unstable in taxi. Sadly, many lives were lost before this phenomenon was understood. If the CG is placed correctly in relation to the WPs, the aircraft establishes taxi by moving the Earth beneath it. Turns are achieved by rotating the Earth. Flight is achieved by dropping the Earth down, and a landing is made by lifting it back up. Aerobatics involve combinations of lifting, dropping, and rotating. I hope this clears things up for everyone. Phil |
Phil, to support your theory, I can tell you the earth weighs 130
pounds in my gravitional field (that's before breakfast. It gains a little after that.). On Feb 6, 1:58*pm, Phil J wrote: On Feb 6, 10:19*am, wrote: Fixed-wing aircraft taxi because their wheels reduce friction as they move forward on the ground. Wrong. *Wrong. *Wrong. Fixed-wing aircraft can only achieve a stable taxi by keeping the CG between the forward and aft wheel points(WPs). * This is why it is so important in aircraft design that the WPs be placed correctly. * In the early days of aviation some designers placed all the wheels to one side of the CG, with the result that the aircraft was dynamically unstable in taxi. *Sadly, many lives were lost before this phenomenon was understood. If the CG is placed correctly in relation to the WPs, the aircraft establishes taxi by moving the Earth beneath it. *Turns are achieved by rotating the Earth. *Flight is achieved by dropping the Earth down, and a landing is made by lifting it back up. *Aerobatics involve combinations of lifting, dropping, and rotating. I hope this clears things up for everyone. Phil |
On Feb 6, 1:09*pm, Tina wrote:
Phil, to support your theory, I can tell you the earth weighs 130 pounds in my gravitional field (that's before breakfast. It gains a little after that.). I have been noticing that the Earth is getting heavier and heavier as the years go by. I think something needs to be done about this Global Bloating. Phil |
"Phil J" wrote
... Wrong. Wrong. Wrong. Fixed-wing aircraft can only achieve a stable taxi by keeping the CG between the forward and aft wheel points(WPs). This is why it is so important in aircraft design that the WPs be placed correctly. In the early days of aviation some designers placed all the wheels to one side of the CG, with the result that the aircraft was dynamically unstable in taxi. Sadly, many lives were lost before this phenomenon was understood. If the CG is placed correctly in relation to the WPs, the aircraft establishes taxi by moving the Earth beneath it. Turns are achieved by rotating the Earth. Flight is achieved by dropping the Earth down, and a landing is made by lifting it back up. Aerobatics involve combinations of lifting, dropping, and rotating. I hope this clears things up for everyone. Phil Hah...hah.... This is called the pilot's perspective: (s)he sits in the cockpit and the earth performs the requisite manoevers. |
yrb-49-taxi.jpg | [email protected] | Aviation Photos | 2 | September 25th 07 09:50 PM |
Hanoi Taxi | john smith | Piloting | 0 | April 27th 06 03:48 AM |
License To Taxi? | SteveT | Piloting | 29 | October 16th 05 04:57 PM |
Leaning for taxi | Jim Rosinski | Piloting | 28 | September 12th 04 03:53 AM |
taxi in reverse? | [email protected] | Owning | 20 | February 21st 04 12:26 AM |
