Why airplanes taxi
Old February 11th 08, 09:00 PM posted to rec.aviation.piloting
Benjamin Dover
Default Why airplanes taxi
Bertie the Bunyip wrote in
Mxsmanic wrote in
WingFlaps writes:
So how do you explain the rather well known lapse rate?
It depends on which lapse rate you have in mind.
The one which states that as the temperature rises, the two molecules in
your head take a siesta.
Bertie
When did his intelligence double to two molecules?
Old February 14th 08, 01:20 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Benjamin Dover wrote in
Mxsmanic wrote in
WingFlaps writes:
in your head take a siesta.
Bertie
Same way he reproduces. Mytosis.
Bertie
Old February 14th 08, 01:12 PM posted to rec.aviation.piloting
On Feb 10, 12:05 pm, Bertie the Bunyip wrote:
Mxsmanic wrote :
WingFlaps writes:
Bertie
Those two molecules you so gaily mock, are the only things separating
the universe from an implosion of matter and anti-matter. (See
previous thread of Star Trek engine noises).
"Dogs and cats sleeping together. MASS HYSTERIA!"
Mxsmaniac is a 30-foot twinkie.
Old February 14th 08, 01:29 PM posted to rec.aviation.piloting
On Feb 14, 7:18 am, Bertie the Bunyip wrote:
Mxsmanic wrote
WingFlaps writes:
Bertie
You don't think that Anthony's are the two particles that theyy're going to
try to rip a hole in space/time with in that Larg Hadron Collider this
year?
I know this reference form somewhere, but can;'t place it. It could only be
KV2, though.
Bertie
I think he's already got a ripped hole. Yeah, curious to see if the
universe turns inside out. There was a decent sci-fi novel based on
this experiment a few years ago but can't remember the name.
The quotes are from Ghostbusters. "She barks, she drools, she sleeps
above the covers....four FEET above the covers".
Old February 10th 08, 06:31 PM posted to rec.aviation.piloting
WingFlaps
On Feb 11, 5:47*am, Mxsmanic wrote:
WingFlaps writes:
In both cases, the correlation is between temperature and altitude, not
temperature and pressure.
Are you saying the air knows how high it is? That's amazing 'cos I use
a sensitive pressure meter to tell me my altitude!
Sounds like you are BS'ing to cover a mistake to me.
Cheers
Old February 10th 08, 07:55 PM posted to rec.aviation.piloting
Mxsmanic
WingFlaps writes:
No.
Old February 10th 08, 08:28 PM posted to rec.aviation.piloting
Mxsmanic wrote in
WingFlaps writes:
No.
Wrong/
Bertie
Old February 11th 08, 07:37 PM posted to rec.aviation.piloting
On Feb 10, 9:47 am, Mxsmanic wrote:
So, overall,
the air is always warmest at the surface. There are some anomalies higher in
the atmosphere.
Not always. Not at all always. We frequently get inversions where the
air 1000' feet up is much warmer than that on the surface. Inversions
are very common here, and I would imagine they're common most anywhere
away from the equator. We've had days here, in the winter, where we've
left the ground where the temp is -20°C, and found -18°C at 3000' agl.
Often I find the winds howling at 25 or 30 knots just 200 feet above
the surface, while the wind on the ground is zilch and the temp is 25
degrees colder.
"Always" just doesn't deal with reality. Works on a sim, I
suppose.
Parcels of air that rise in the atmosphere will cool as the pressure in the
atmosphere drops, and this is responsible the adiabatic lapse rate.
If you'd ever studied meteorology (Commercial Pilot
groundschool) you'd know that the temp falls with altitude until we
reach the tropopause. Then it starts rising until we reach the
stratopause, where it starts to fall again through the mesosphere, and
once we reach the thermosphere it rises again and keeps on rising,
though the density is so low that the actual heat content is minimal.
See this:
http://www.ux1.eiu.edu/~cfjps/1400/FIG01_019.JPG
If pressure rises, so does temperature. The air coming down
off the Rockies here rises in temperature as its pressure rises in the
descent. This is part of the chinook phenomenon's equation. The rest
of that equation has to do with condensation of the vapor on the west
side of the mountains, which releases the heat of evaporation back to
the atmosphere so that the air's temperature fall is minimal as the
air is forced upward by the terrain. So when it gets to 3000' on this
side, it's MUCH warmer and drier than it was at 3000' on the west
side. The snow evaporates (sublimates) in that warm, dry air. It
doesn't have a chance to melt.
The atmosphere is much more complex than you think.
Dan
yrb-49-taxi.jpg [email protected] Aviation Photos 2 September 25th 07 09:50 PM
Hanoi Taxi john smith Piloting 0 April 27th 06 03:48 AM
License To Taxi? SteveT Piloting 29 October 16th 05 04:57 PM
Leaning for taxi Jim Rosinski Piloting 28 September 12th 04 03:53 AM
taxi in reverse? [email protected] Owning 20 February 21st 04 12:26 AM
