Why airplanes taxi
Old February 10th 08, 04:32 PM posted to rec.aviation.piloting
Mxsmanic
Default Why airplanes taxi
writes:
Neither the atmosphere of the Earth nor the universe are infinite.
We don't know if they are infinite or not.
  #92
Old February 10th 08, 04:40 PM posted to rec.aviation.piloting
Mxsmanic
terry writes:
You see the fact that the volume of the atmophere or of space is
infinite is quite irrelvant because nobody wants to know what the
average density of the whole atmophere is ( which of course will
approach zero depending on your definition of where the atmsophere
actually ends).
It is very highly relevant. If you increase the temperature of the
atmosphere, for example, the pressure does not rise, because nothing
constrains the atmosphere--it simply expands. Atmospheric pressure comes from
gravity, which is a constant, and not from any constraints applied to the
volume of air, of which there are none. In the highest portions of the
atmosphere, the temperature rises to several thousand degrees, but the
pressure remains extremely low. At the surface, you might see variations in
absolute temperature of 1/3, but you won't see variations in pressure anywhere
near that magnitude.
  #93
Old February 10th 08, 04:47 PM posted to rec.aviation.piloting
Mxsmanic
WingFlaps writes:
So how do you explain the rather well known lapse rate?
It depends on which lapse rate you have in mind.
Solar heating at the surface produces a static temperature gradient, the
environmental lapse rate. Light to which the atmosphere is transparent is
absorbed at the surface and converted to heat. Part of this is reradiated,
but at lower frequencies that may be reflected or absorbed by the atmosphere,
the rest heats the air at the surface directly by conduction. So, overall,
the air is always warmest at the surface. There are some anomalies higher in
the atmosphere.
Parcels of air that rise in the atmosphere will cool as the pressure in the
atmosphere drops, and this is responsible the adiabatic lapse rate.
In both cases, the correlation is between temperature and altitude, not
temperature and pressure.
  #95
Old February 10th 08, 05:35 PM posted to rec.aviation.piloting
Mxsmanic wrote:
terry writes:
actually ends).
Nope.
The ideal gas law doesn't apply over the entire Earth's atmosphere
because the entire atmosphere isn't in equilibrium.
It does apply locally where equilibrium can be approximated.
In the highest portions of the atmosphere, the ideal gas law has
significant error because the molecular size becomes significant,
in which case one must use something like the van der Waals equation.
Jim Pennino
Remove .spam.sux to reply.
  #97
Old February 10th 08, 05:45 PM posted to rec.aviation.piloting
Mxsmanic wrote:
WingFlaps writes:
the atmosphere.
Nope.
Air molecules don't have altimeters to tell them the altitude.
Jim Pennino
  #99
Old February 10th 08, 06:04 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Mxsmanic wrote in
news
terry writes:
actually ends).
Wow, a truly magnificent lack of understanding of how weather works to add
to all the other dumb feathers in your tinfoil hat.
Bertie
  #100
Old February 10th 08, 06:05 PM posted to rec.aviation.piloting
Mxsmanic wrote in
WingFlaps writes:
The one which states that as the temperature rises, the two molecules in
your head take a siesta.
Bertie
yrb-49-taxi.jpg [email protected] Aviation Photos 2 September 25th 07 09:50 PM
Hanoi Taxi john smith Piloting 0 April 27th 06 03:48 AM
License To Taxi? SteveT Piloting 29 October 16th 05 04:57 PM
Leaning for taxi Jim Rosinski Piloting 28 September 12th 04 03:53 AM
taxi in reverse? [email protected] Owning 20 February 21st 04 12:26 AM
