This discussion brings to mind an episode I had relatively early in my
soaring life. After licensing at Tehachepi in a 2-33, I went to Crystal to transition to glass in their Grob 103's. After being cleared to solo I was flying along the San Gabriel's in an area that had been shown to me. The lift was sketchy and I was flying long passes through bands of weak lift, not very close to the mountain, (I was and still am quite cowardly). After hitting a strengthening patch of lift through two passes, I had the brilliant idea to try circling. I made two circles just like it was any other thermal I had flown and then, between heartbeats, It all went to schist. I heard a loud bang and instantly i was no longer flying. the car keys in my shirt pocket were pinned against the canopy and all the gravel and dust on the floor was floating in front of me. my angle of bank entering into this was shallow and I think both wings hit at the same time. If it had been one wing only, I would have been vertical or inverted faster than I could have moved the controls to react. Luckily I was pointed away from the mountain, and recovery was to simply nose down and pull out. My own personal recovery took considerably longer. There is no skill in the world that could tame that kind of sharp edged shear while rock polishing, in my estimation. Mark Jardini |
Sadly, we lost Stew Kissel shortly after I wrote "Don't Smack the
Mountain-101", so we need to add yet another name to the list of "Mysterious high energy impacts on the side of a mountain". I live by the rules I stated and so far (35 years & 5000 hours in the Sierras & Whites) they have kept me from impacting the mountain. JJ |
I remember reading an article, I thought it was Henry Combs, but not
sure, about a technique of rolling inverted deliberately and moving away from the mountain inverted, when encountering such a gust. It made sense to me, if you roll authority is less than the strength of the gust, then don't fight it and even reverse input and let yourself go inverted. You can then turn away inverted, or at least not into the mountain. Sounds like a Judo move to me. Does anyone remember this article or concur with this technique? |
Mark Jardini wrote:
This discussion brings to mind an episode I had relatively early in my soaring life. After licensing at Tehachepi in a 2-33, I went to Crystal to transition to glass in their Grob 103's. After being cleared to solo I was flying along the San Gabriel's in an area that had been shown to me. The lift was sketchy and I was flying long passes through bands of weak lift, not very close to the mountain, (I was and still am quite cowardly). After hitting a strengthening patch of lift through two passes, I had the brilliant idea to try circling. I made two circles just like it was any other thermal I had flown and then, between heartbeats, It all went to schist. "Going to schist" When rock polishing goes bad. Yeah, yeah, I know what your thinking "How gneiss." ;-) Shawn |
On Feb 15, 12:39 pm, Shawn wrote:
Mark Jardini wrote: This discussion brings to mind an episode I had relatively early in my soaring life. After licensing at Tehachepi in a 2-33, I went to Crystal to transition to glass in their Grob 103's. After being cleared to solo I was flying along the San Gabriel's in an area that had been shown to me. The lift was sketchy and I was flying long passes through bands of weak lift, not very close to the mountain, (I was and still am quite cowardly). After hitting a strengthening patch of lift through two passes, I had the brilliant idea to try circling. I made two circles just like it was any other thermal I had flown and then, between heartbeats, It all went to schist. "Going to schist" When rock polishing goes bad. Yeah, yeah, I know what your thinking "How gneiss." ;-) Shawn Oh, that's just marbelous. |
On Feb 14, 2:06*pm, wrote:
In the Henry Combs article, what did happen to Chet Lymon? He survived and so did/does he confirm his roll control authority was overpowered? I checked with my friend who knew Combs and gave me the article, but so far he hasn't been able to provide an answer to the above question. I did do a search of the NTSB database and found the report attached below which says he encountered wind shear. The longer report lists the wind as 270@13, so I suspect they really meant a thermally induced wind shear. If that was the case, it wasn't quite the same mechanism that Combs described but the point is still there. Anytime we fly close to terrain, life is much more dangerous since there's less time (no time sometimes) to recover from an anomaly -- be it a wing lifted (as Combs describes), wind shear that causes a stall, etc. Hope this helps. Martin NTSB Identification: LAX84FA315 . The docket is stored on NTSB microfiche number 25291. 14 CFR Part 91: General Aviation Accident occurred Saturday, May 26, 1984 in LLANO, CA Aircraft: Bölkow PHOEBUS A-1, registration: N7700 Injuries: 1 Serious. CIRCLING IN LIFT NEAR A HIGH RIDGE THE SAILPLANE ENCOUNTERED WHAT THE PLT REFERRED TO AS WIND SHEAR. LOSING CONTROL, THE SAILPLANE COLLIDED WITH A TREE BEFORE IMPACTING THE GROUND. The National Transportation Safety Board determines the probable cause(s) of this accident as follows: WEATHER CONDITION..WINDSHEAR AIRSPEED(VS)..NOT MAINTAINED..PILOT IN COMMAND |
Any chance of getting a link to the source of these
numbers. I just got the official statistics of Germany for 2007. 20 fatal accidents with German gliders involved (compared to 10 in 2006). 15 of them abroad, 12 in the French Alps. ------------------ Daniel Scopel Silent 2 Targa C-GODY serial 2027 Volez souvent et soyez prudent. http://pages. videotron. com/dscopel/ |
On 16 Feb 2008 12:59:45 GMT, Dan Silent
wrote: Any chance of getting a link to the source of these numbers. As far as I know they are not on the web yet, unfortunately - I got them during an CFI training one week ago on paper only directly from one of the German fligt safety commisioners. They are going to be published on bfu-web.de - please send me a reminder if you cannot find them there within a couple of weeks (the site is in German only). Bye Andreas |
At 16:24 16 February 2008, Jj Sinclair wrote:
I actually saw Tom Madigan hit the Whites just east of Bishop. I dont think anyone has discussed airspeed in this thread. My glider has crap airelon authority at 50kts but at Va it is very good. Isn't safety near rocks a factor of speed? If you are belting along at a Va would you not be able to pull up / fly away from the cliff if you needed to? Jim |
On Feb 16, 9:04*am, Jim White
wrote: At 16:24 16 February 2008, Jj Sinclair wrote: I actually saw Tom Madigan hit the Whites just east of Bishop. I dont think anyone has discussed airspeed in this thread. My glider has crap airelon authority at 50kts but at Va it is very good. Isn't safety near rocks a factor of speed? If you are belting along at a Va would you not be able to pull up / fly away from the cliff if you needed to? Jim Sure Jim, but these guys were trying to climb and flying fairly slow in weak slope lift ond/or trying to work weak thermals. You bring up a good point though, I never slow down below 65 knots on my first pass across a piece of ridge that I haven't made at least one pass by to check for squirrely air. JJ |
USA / The Soaring Safety Foundation (SSF) Safety Seminars 2008 | [email protected] | Soaring | 0 | November 8th 07 11:15 PM |
The Soaring Safety Foundation (SSF) Safety Seminars Hit The Road in the USA | [email protected] | Soaring | 0 | September 11th 06 03:48 AM |
Soaring Safety programs at the SSA Convention | Burt Compton - Marfa | Soaring | 0 | January 21st 06 03:40 AM |
Soaring Safety Seminar - SSA Convention | Burt Compton | Soaring | 0 | January 26th 04 03:57 PM |
Soaring Safety Foundation invitation | Burt Compton | Soaring | 0 | January 18th 04 02:51 PM |
