On Feb 15, 9:39*am, Michael Ash wrote:
In rec.aviation.student Gig 601XL Builder wrote: WingFlaps wrote: On Feb 15, 12:31 am, "John" wrote: No there are no regulations for climb or descent rates for VFR flight. Err I don't think that's 100% correct but it will do for MX. Please then for my benefit point me to such a regulation. Technically speaking, it is illegal to descend faster than about 25,000fpm (needs to be adjusted based on density, since it's give in terms of indicated airspeed) when below 10,000ft. I doubt too many flights would need to worry about this limitation. You've got it! Also Vne is usually a lot slower than that for most GA. There are other "tricky" examples I can think of. Cheers |
On Feb 14, 2:19*pm, Gig 601XL Builder
wrote: WingFlaps wrote: On Feb 15, 12:31 am, "John" wrote: No there are no regulations for climb or descent rates for VFR flight. Err I don't think that's 100% correct but it will do for MX. Cheers Please then for my benefit point me to such a regulation. Well, what if you exceeded the 250 knot limit going down in class E below 1000? Oh boy, would you be in trouble with the FAA then! ![]() |
On Feb 15, 9:19*am, Gig 601XL Builder
wrote: WingFlaps wrote: On Feb 15, 12:31 am, "John" wrote: No there are no regulations for climb or descent rates for VFR flight. Err I don't think that's 100% correct but it will do for MX. Cheers Please then for my benefit point me to such a regulation. Certainly. Vne is a limit that must not be exceeded (there are others). This sets a limit on how fast you can legally descend (remember pilots must fly within operating limits). You must also not use ascent or descent rate that put you in conflict with ATC unless you have got clearance. When NORDO you cannot ascend or descend into controlled space except as part of a flight plan. The descent rate at or below 500' must be zero or negative except at an aerodrome or within a LFZ. You can probably now see other examples. Pilots should think outside the box ;-) Cheers |
WingFlaps wrote in
: On Feb 15, 9:19*am, Gig 601XL Builder wrote: WingFlaps wrote: On Feb 15, 12:31 am, "John" wrote: No there are no regulations for climb or descent rates for VFR flight. Err I don't think that's 100% correct but it will do for MX. Cheers Please then for my benefit point me to such a regulation. Certainly. Vne is a limit that must not be exceeded (there are others). Actuall, that's "should not" There are airplanes in which it's permissable to go to Vd in an emergency, though they might have Vmo instead of Vne now I think about it. I'm not even sure if I've flown one or not... Never mind! Bertie |
On 02/15/08 01:53, WingFlaps wrote:
On Feb 15, 9:19�am, Gig 601XL Builder wrote: WingFlaps wrote: On Feb 15, 12:31 am, "John" wrote: No there are no regulations for climb or descent rates for VFR flight. Err I don't think that's 100% correct but it will do for MX. Cheers Please then for my benefit point me to such a regulation. Certainly. Vne is a limit that must not be exceeded (there are others). This sets a limit on how fast you can legally descend (remember pilots must fly within operating limits). You must also not use ascent or descent rate that put you in conflict with ATC unless you have got clearance. When NORDO you cannot ascend or descend into controlled space except as part of a flight plan. What? You believe that an aircraft with no radio is not allowed to enter controlled airspace without being on a flight plan? Can you please provide a reference to that regulation? The descent rate at or below 500' must be zero or negative except at an aerodrome or within a LFZ. You can probably now see other examples. Pilots should think outside the box ;-) Cheers -- Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot Cal Aggie Flying Farmers Sacramento, CA |
![]() "WingFlaps" wrote in message ... When NORDO you cannot ascend or descend into controlled space except as part of a flight plan. Where? |
Not to get into the whole parsing argument but for the subset of flight
known as VFR, there are no climb and descent rules that apply only to VFR flight. The rules about airspace and operating limits apply to both VFR and IFR flights. "WingFlaps" wrote in message ... On Feb 15, 12:31 am, "John" wrote: No there are no regulations for climb or descent rates for VFR flight. Err I don't think that's 100% correct but it will do for MX. Cheers |
![]() "John" wrote in message news:Ar1tj.6237$CX2.4572@trndny09... Not to get into the whole parsing argument but for the subset of flight known as VFR, there are no climb and descent rules that apply only to VFR flight. The rules about airspace and operating limits apply to both VFR and IFR flights. That's how I viewed the question. The airspace/limits don't specifically refer to VFR cruise, although cruising under VFR would still make you subject to broader airspace and operating limits. -c |
gatt writes:
That's how I viewed the question. The airspace/limits don't specifically refer to VFR cruise, although cruising under VFR would still make you subject to broader airspace and operating limits. So are there general limits for climb and descent rates that apply to VFR? I know there are constraints for climbs and descents directed by ATC, but for climbs and descents initiated by the pilot on his own (which would usually apply only to VFR, although there are some IFR examples, too), I can't find a specific maximum or (especially) minimum. |
Descent below MDA -- what would you do? | Roy Smith | Instrument Flight Rules | 50 | August 29th 05 12:39 AM |
ANR squeal on descent | Juan Jimenez | General Aviation | 13 | August 19th 05 10:39 PM |
descent below minimums | hsm | Instrument Flight Rules | 82 | January 11th 05 06:33 PM |
BRS and descent rate | Roger Long | Piloting | 21 | May 7th 04 05:34 PM |
Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 03:22 PM |
