Q: PBY
Old February 26th 08, 01:14 PM posted to rec.aviation.piloting,rec.aviation.military
Rolf Blom
Default Q: PBY
On 2008-02-26 05:59, John Keeney wrote:
On Feb 25, 10:56 pm, Dale wrote:
Peter Twydell wrote:
In message
Hawkeye writes
On Feb 25, 4:24 pm, Cubdriver usenet AT danford DOT net wrote:
Here is a photo on Wiki that shows how the outer wing floats
(pontoons) can swing up, so that the pontoon becomes the wingtip.
http://upload.wikimedia.org/wikipedi...K_RNZAF_Catali...
That has got to be the case with your photo. A larger question is:
where's the tail wheel? Blue skies! -- Dan Ford
On Mon, 18 Feb 2008 18:30:54 -0800 (PST), William Hung
http://www.sa-transport.co.za/aircra...by-5a_ra98.JPG
OK, I've seen pictures of PBYs with;
1. All three gears down and the outer potoons down,
2. All gears down, potoons up,
3. Gears up, potoons down,
4. and now the above picture with only the main gears down, but nose
wheel still tucked in and pontoons still up or maybe no pontoons.
My question are; are the gears controlled individually, are the
pontoons controlled separately, are the font and main gears controlled
separately also? If so, why?
Wil
Claire Chennault and His American Volunteers, 1941-1942
new from HarperCollinswww.FlyingTigersBook.com
It is a tricycle geared aircraft Dan...the question is...where is the
nose gear!
No, it isn't. It's a PBY-5, not a PBY-5A. The wheels alongside the
fuselage are beaching gear, not landing gear. No mainwheels, no nose
gear.
Comparisons he
http://www.catalina.org.nz/what%20is%20a%20PBY.htm
The photo of the PBY-2 shows the beaching gear.
Looks like a 5a to me, you can see the outline of the still closed
nosewheel door.- Hide quoted text -
- Show quoted text -
Peter's right, Dale. There's no place to retract those "main wheels"
and it is sitting tail heavy on a stand.
Not to mention the older style tail.
Interesting thread, I always liked the PBY.
I see that the catalina.org.nz states: "all surviving operational
aircraft are amphibians".
I think I found a likely reference to the OP's plane in a PBY survivors
list at the Catalina society;
http://www.catalina.org.uk/catalina-...2_articleid/23
C/n 1656 from that list, matches the one in the photo, but with slightly
different registration: N9521C
(the Photo text has N952ZIC - that may simply be a misspelling)
In any case with that C/n, the plane is listed as a PBY5a, just as the
photo says, so it's an amphibian, owned by 'Training Services Inc TA',
based at Virginia Beach.
Anyone living nearby & so inclined could perhaps go and ask about the
nose gear?
/Rolf
Old February 27th 08, 05:47 AM posted to rec.aviation.piloting,rec.aviation.military
John Keeney
Default Q: PBY
*Peter Twydell wrote:
In message
Hawkeye writes
(pontoons) can swing up, so that *the pontoon becomes the wingtip.
where's the tail wheel? *Blue skies! -- Dan Ford
separately also? *If so, why?
Wil
nose gear!
gear.
Comparisons he
list at the Catalina society;http://www.catalina.org.uk/catalina-...2_articleid/23
nose gear?
/Rolf- Hide quoted text -
Maybe we're looking at different pictures. There's been more than one
posted here.
Which URL are you referring to?
Old February 27th 08, 01:03 PM posted to rec.aviation.piloting,rec.aviation.military
Jim Wilkins
Default Q: PBY
The owner of a restored ex-houseboat PBY told me that its landing gear
was added after the war. Maybe the various installations reflect
whatever surplus equipment was available.
Old February 26th 08, 12:11 PM posted to rec.aviation.piloting,rec.aviation.military
William Hung[_2_]
Default Q: PBY
Wil
new from HarperCollinswww.FlyingTigersBook.com- Hide quoted text -
Well, since you have posted this picture and Peter Twydell has pointed
out that what we are looking at is a beaching gear and nt a landing
gear(tail heavy and no accomadation for retraction), I've learned a
lot about the PBY.
To answer your question, the two little wheels about five feet south
of the two gentleman's legs would be the "tail wheels(for beaching)"
Now, only if I can hit the big one. The PBY would definitely be my
flying ATV.
Wil
Old February 27th 08, 05:58 PM posted to rec.aviation.piloting,rec.aviation.military
Hawkeye[_2_]
Default Q: PBY
I doubt that it would be possible for a Catalina to be able to take
off with the beaching wheels, They were not made for that kind of
speed on land. In fact, in the water you'd never get up enough speed
either, it would be like dragging two anchors.
Even the information on the picture states it is a -5A and can be
confirmed by running the registration number through the FAA database.
The shadow on the picture obscures the outline of the wheel well on
the side of the aircraft, the wheel was exposed when retracted, only
the strut was covered by doors, much the same as other aircraft such
as the Goose and Albatross.
The reason for the creation of an amphibian seaplane was that being
strictly a seaplane meant limiting its areas of operations. Many
locations in the world do not have or would it be feasible to create
beaching facilities. Having to haul the beaching gear and crews was
also unpractical. The amphibian could use inland runways to stop for/
deliver fuel/supplies. Remember the more time spent in salt water the
greater risk for corrosion which adds to operational maintenance. Its
nice to be able to land on water when needed but it has its drawbacks
too.
When Kermit Weeks brought his Sunderland from the UK to the US, he had
to provide for the logistics of landing on bodies of water large
enough which also had good water surface conditions plus access to
refueling facilities capable of supporting such a large aircraft at
each stop of the journey. Had he had an emergency, he might not been
able to find a spot with suitable water conditions...ever been in a
small boat in rough water. Its harder in an airplane!
Fortunately the Sunderland made the trek stopping and over wintering
in Oshkosh until the pond/lake at his new Florida facility was ready
for its arrival. They installed the beaching gear and parked it at a
boat storage area in a local marina.
Old February 28th 08, 07:50 AM posted to rec.aviation.piloting,rec.aviation.military
William Hung[_2_]
Default Q: PBY
too.
Cool... Yeah amphibian would be the way to go.
Wil
