A Call to Arms from Richard VanGrunsven
Old March 10th 08, 01:39 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Gig 601XL Builder[_2_]
Default A Call to Arms from Richard VanGrunsven
Larry Dighera wrote: One of his stupidest post ever. And that's saying
something.
Larry I have no problem with Kit Built at all. I'm building one myself.
As far as where the US Government gets it's authority to regulate our
airspace I would assume it is from the same place where it gets it
authority to create the Department of Transportation which is probably
the Interstate Commerce clause of the constitution. I really don't have
either the time or desire to look it up.
But just so you know you probably won't find it worded very clearly. The
reason for that is because there was little war in the mid 1800s that
changed the face of what the federal government can an can't do. If you
don't like well either build a time machine and go sign up to fight for
the South.
Old March 9th 08, 07:17 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Fred the Red Shirt
On Mar 7, 12:07 pm, Larry Dighera wrote:
Right. Unless it can be demonstrated that such intrusion is
reasonable and Constitutionally implemented, it's abuse of power, IMO.
Given how hard it would be to make a plane using only intrastate
materials, and how easy it is to fly one accross state borders,
and especially in view of other rulings on what constitutes
'interstate
commerce' there is little doubt that the courts would uphold
jurisdiction
based on the ICC.
That doesn't mean it isn't an abuse of power.
I also agree that the 51% policy seems to contain at least an element of
protectionism for manufacturers.
IIRC before there was a 51% rule, there was a time during which
homebuilts were not allowed at all. The original intent would seem
to have been to protect homebuilding, regardless of what it has
become today.
FF
Old March 10th 08, 03:28 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Highflyer
I guess the real question is why does the FAA feel it's necessary for
a homebuilder to have done 51% of the work? Is it to protect him from
himself, or to protect the public from him, or are there other
reasons? What of the prototypes built by Lockheed or Boeing; 51% of
them aren't constructed by a single individual.
It seems that there is some fundamental assumption that I am
overlooking, because the current FAA 51% mandate seems arbitrary and
unfounded to me.
All aircraft are licensed under one of a limited set of rules before being
allowed to enter our airspace. The only exception to this is a class of
flying machines, called "ultralights" that fall under part 103. These
aircraft are exempted from some of the oversight because they are so
lightweight that they do not present a serious danger to people who are not
committing the unnatural act of flight in one of the contraptions.
All larger and heavier aircraft can endanger people on the ground who have a
right to be protected from fools falling out of the sky into their homes.
Theoretically, anyway.
The 51% rule has applied since the EAA was first founded back in 1953.
Interestingly, building either wings or a fuselage is considered 51% of the
aircraft? The idea was to allow the builder to utilize scrounged aircraft
parts, and to use standard aircraft engines and propellors.
Why is it reasonable? Simple. To license an airplane as Experimental -
Amateur built the amateur in question must build a substantial portion of
the aircraft. Otherwise it is NOT "amateur built" and must be licensed in
some other category, such as Experimental - Exhibition, or Standard Type
Certified or some such.
How can it possibly be "unconstitutional" to restrict aircraft licensed as
"amateur built" to only aircraft that were built by amateurs. By definition
"Professionally Built" does NOT fit into this license category and should be
licensed in one of the other categories. And can be under the existing
rules. All that it requires is compliance with the appropriate regulations
to ensure safe operation and acceptable construction standards.
Highflyer
Flew home and boy are my arms tired! Steve Schneider Owning 11 September 5th 07 12:16 AM
ASW-19 Moment Arms jcarlyle Soaring 9 January 30th 06 10:52 PM
[!] Russian Arms software sale Naval Aviation 0 December 18th 04 05:51 PM
Dick VanGrunsven commutes to aviation Fitzair4 Home Built 2 August 12th 04 11:19 PM
Small arms locker questions Red Naval Aviation 4 July 30th 03 02:10 PM
