Why must night landings be full-stop?
Old March 15th 08, 09:44 PM posted to rec.aviation.piloting
Default Why must night landings be full-stop?
On Mar 15, 9:17 am, Bertie the Bunyip wrote:
Larry Dighera wrote :
On Sat, 15 Mar 2008 06:36:23 -0600, "Neil Gould"
Recently, Ron Garret posted:
Anyone know why landings for night currency have to be to a full
stop?
Possibly because currency for carrying pax also requires full-stop
landings. Getting night currency satisfies both requirements.
Day full-stop landings for passenger carrying currency are only
required for tail-wheel aircraft:
http://ecfr.gpoaccess.gov/cgi/t/text...dx?c=ecfr&sid=
477ffe5f8e7b7b
7fc7d82953c1e69200&rgn=div5&view=text&node=14:2.0. 1.1.2&idno=14
§ 61.57 Recent flight experience: Pilot in command.
(a) General experience. (1) Except as provided in paragraph (e) of
this section, no person may act as a pilot in command of an aircraft
carrying passengers or of an aircraft certificated for more than one
pilot flight crewmember unless that person has made at least three
takeoffs and three landings within the preceding 90 days, and--
(i) The person acted as the sole manipulator of the flight
controls; and
(ii) The required takeoffs and landings were performed in an
aircraft of the same category, class, and type (if a type rating is
required), and, if the aircraft to be flown is an airplane with a
tailwheel, the takeoffs and landings must have been made to a full
stop in an airplane with a tailwheel.
(2) For the purpose of meeting the requirements of paragraph
(a)(1) of this section, a person may act as a pilot in command of an
aircraft under day VFR or day IFR, provided no persons or property are
carried on board the aircraft, other than those necessary for the
conduct of the flight.
(3) The takeoffs and landings required by paragraph (a)(1) of this
section may be accomplished in a flight simulator or flight training
device that is--
(i) Approved by the Administrator for landings; and
(ii) Used in accordance with an approved course conducted by a
training center certificated under part 142 of this chapter.
(b) Night takeoff and landing experience. (1) Except as provided
in paragraph (e) of this section, no person may act as pilot in
command of an aircraft carrying passengers during the period beginning
1 hour after sunset and ending 1 hour before sunrise, unless within
the preceding 90 days that person has made at least three takeoffs and
three landings to a full stop during the period beginning 1 hour after
sunset and ending 1 hour before sunrise, and--
(i) That person acted as sole manipulator of the flight controls;
and
required).
(2) The takeoffs and landings required by paragraph (b)(1) of this
section may be accomplished in a flight simulator that is--
(i) Approved by the Administrator for takeoffs and landings, if
the visual system is adjusted to represent the period described in
paragraph (b)(1) of this section; and
I bet you sit at the airport and check on people doing this.
Bertie
He should (if he doesn't) work for the IRS in the Sanctimonious
Buttmunchers Secftion.
Crikey, what a ******!
Larry "Never use a word where a paragraph will do" Dighera
Old March 16th 08, 04:41 AM posted to rec.aviation.piloting
Anyone know why landings for night currency have to be to a full stop?
http://ecfr.gpoaccess.gov/cgi/t/text...d=477ffe5f8e7b....
controls; and
device that is--
and
required).
Doesn't seem to answer your OP, aye?
Old March 15th 08, 01:40 PM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
"Ron Garret" wrote in message
Because that's what in CFR part blah blah blah...
If you are trying to make sense of the regulations, well, good luck...
Geoff
Old March 15th 08, 09:46 PM posted to rec.aviation.piloting
On Mar 15, 8:40 am, "Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way
Geoff
Nah, he just wanted to give Larry a chance to air out his tonsils in
the spirit of Christian brotherhood.
Old March 15th 08, 01:51 PM posted to rec.aviation.piloting
Tina
What is the definition of a takeoff and landing anyway? On a long
runway in a 172 one could land on the numbers, get below flying
speed, add throttle and lift off and repeat that sequence a number of
times in a single pass. Is each such touch and go an FAA recognized
landing and take off?
rg
Old March 15th 08, 02:18 PM posted to rec.aviation.piloting
Larry Dighera
On Sat, 15 Mar 2008 06:51:32 -0700 (PDT), Tina
It seems the FAA intentionally omitted those terms from the
Pilot/Controller Glossary:
http://www.faa.gov/airports_airtraff.../PCG/index.htm
Old March 15th 08, 02:22 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Larry Dighera wrote in
A netkkkop AND a conspirawhacko. YOu're a man of many talents, there,
Larry.
Bertie
Old March 15th 08, 09:48 PM posted to rec.aviation.piloting
Larry.
Bertie
Define "man" and "talents" please Herr Bunyip.
Grazie.
Richard
(I believe using either and esp. both in the same sentence to describe
anything to do with Mr. D to be an example of faulty thinking).
Old joke on night landings Danny Dot Piloting 0 November 14th 06 08:41 PM
Touch and Goes versus Full Stop Taxi Backs Kevin Dunlevy Piloting 81 September 18th 05 09:26 PM
First Stop Syria, Next Stop Iran [email protected] Naval Aviation 6 July 22nd 05 09:58 PM
Radio protocol regarding full stops on full stop only nights Ben Hallert Piloting 33 February 9th 05 07:52 PM
Night landings vs. day landings Gerald Sylvester Piloting 15 February 12th 04 06:38 AM
