small disel a/c engine?
Old March 26th 08, 03:59 PM posted to rec.aviation.piloting
Morgans[_2_]
Default small disel a/c engine?
"Tauno Voipio" wrote
At least one of the high-pressure pump failures happened
here for the Cessna of our club. It seems that the pump
had been dry some 5 hours before the failure. The Thielert
manual especially warns running the pump dry, and if so
happens, there should be an inspection of the pump
before the next flight.
I'm not sure what you mean, as in "running the pump dry."
Does it require lubricating oil from the engine, which it was not getting,
or "dry" as in the fuel supply was interrupted?
Jim in NC
Wind limits - small single engine aircraft [email protected] Piloting 30 February 7th 07 07:36 AM
Help ! SMALL Radial engine Chris Wertman Home Built 12 July 18th 05 02:46 PM
Small 4 stroke engine? Ron Wanttaja Home Built 35 July 2nd 05 07:25 PM
What is the single-engine small plane with the best range? Bob Owning 24 February 19th 04 04:15 AM
Help ! SMALL Radial engine Chris Wertman Military Aviation 11 January 4th 04 08:22 AM
