Getting confused with ATC order...Violation?
Old April 4th 08, 04:53 PM posted to rec.aviation.piloting
Steven P. McNicoll[_2_]
Default Getting confused with ATC order...Violation?
On Apr 4, 7:55 am, C J Campbell
They do die in real airplanes, though, and the FAA has held that a
pilot who reads back an erroneous clearance is still required to fly
the one given him by ATC, even if ATC doesn't correct him.
The FAA hasn't held that at all.
Old April 5th 08, 03:25 AM posted to rec.aviation.piloting
C J Campbell[_1_]
On 2008-04-04 08:53:46 -0700, "Steven P. McNicoll"
Sorry. You are right. It was the NTSB in the Merrell case, 1999.
Waddling Eagle
World Famous Flight Instructor
Old April 4th 08, 06:14 PM posted to rec.aviation.piloting
Mxsmanic
C J Campbell writes:
But that is a physical impossibility. If the pilot heard 110 instead of 210
because of static, and he reads back and flies 110, and ATC doesn't correct
him, how is the pilot to magically know what ATC really said and magically fly
that?
Where did the FAA hold this?
Old April 4th 08, 06:22 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 04 Apr 2008 19:14:23 +0200, Mxsmanic
that?
Ask, "Say again."
Old April 5th 08, 12:39 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Mxsmanic wrote in
news
of 210 because of static, and he reads back and flies 110, and ATC
doesn't correct him, how is the pilot to magically know what ATC
really said and magically fly that?
That's because you'r enot a pilot, you're an idiot.
When advice is needed on how to make a good burger out of dumpster
scraps, we'll call you.
Bertie
Old April 4th 08, 04:10 AM posted to rec.aviation.piloting
Benjamin Dover
Mxsmanic wrote in
RubberWatch writes:
I am a student pilot. I was out flying solo today and was instructed
by ATC to fly a heading of 210. I thought he said 110 and I flew on
that heading.
Did you read back the heading? If you read back 110 and he said
nothing, you're okay, since he should have corrected you. If you read
back 210 and then flew 110, that's potentially a problem (although
probably not in this case, since you fixed it). If you didn't read
back the heading, that also can potentially be a problem because the
burden is upon you to fly the correct heading if you didn't read it
back.
If you had ever flown a real airplane Anthony, you would know what a
moron you are. Ooops, I forgot, you've never flown a real airplane. All
you do is set the autopilot in your simulator and stroke your joystick
while watching the monitor.
Old April 4th 08, 05:02 AM posted to rec.aviation.piloting
BT
excellent.. more advice from a simulator operator..
"Mxsmanic" wrote in message
RubberWatch writes:
that heading.
Did you read back the heading? If you read back 110 and he said nothing,
you're okay, since he should have corrected you. If you read back 210 and
then flew 110, that's potentially a problem (although probably not in this
case, since you fixed it). If you didn't read back the heading, that also
can
potentially be a problem because the burden is upon you to fly the correct
heading if you didn't read it back.
Old April 4th 08, 10:49 AM posted to rec.aviation.piloting
Mortimer Schnerd, RN[_2_]
He's still here?
mschnerdatcarolina.rr.com
Old April 4th 08, 06:15 PM posted to rec.aviation.piloting
Mxsmanic
BT writes:
Which part do you disagree with?
Do you think VFR pilots should not read back instructions from ATC?
Do you think VFR pilots should fly what ATC wants instead of what they heard
in ATC's instructions? If so, how are they to know what ATC really wants if
they misheard the instructions and they don't read them back, or if they read
them back and ATC fails to correct them? How do you do that?
Old April 4th 08, 06:32 PM posted to rec.aviation.piloting
Benjamin Dover
Mxsmanic wrote in
BT writes:
heard in ATC's instructions? If so, how are they to know what ATC
really wants if they misheard the instructions and they don't read
them back, or if they read them back and ATC fails to correct them?
How do you do that?
Wow, you really don't know **** about flying. What a moron you are.
Confused re transponders and ADS-B Andrew Gideon Piloting 6 June 27th 06 01:49 AM
Another ADIZ violation? Dan Foster Piloting 5 January 4th 06 02:25 AM
Confused about great circle navigation xerj Piloting 7 July 10th 04 05:38 PM
No wonder I'm confused:) John0714 Soaring 0 May 1st 04 07:02 PM
