![]() "David Lesher" wrote in message ... "Simon Robbins" writes: Rather than lack of oxygen, I imagine it would be that the lower air pressure simply means the rotor is unable to achieve lift without an unacceptable increase in rotor speed, which would likely overstress the engines and gearbox. I've wondered what keeps you from building a high-altitude version. I envison big fat blades and an engine design for thin air. Or is there some other issue I'm not seeing? Lack of demand most likely. Not a lot of places to land on mountains that tall. |
On Tue, 18 Nov 2003 00:10:26 +0000 (UTC), David Lesher
wrote: "Simon Robbins" writes: Rather than lack of oxygen, I imagine it would be that the lower air pressure simply means the rotor is unable to achieve lift without an unacceptable increase in rotor speed, which would likely overstress the engines and gearbox. I've wondered what keeps you from building a high-altitude version. I envison big fat blades and an engine design for thin air. Or is there some other issue I'm not seeing? Density altitude is a crucial factor in high-altitude helicopter operations. In a helicopter, the higher you go the more power is needed. But due to density altitude, the rotor system and engine(s) are less efficient at higher elevations, and the engines develop less power. A helicopter may be able to fly at high altitude but may not be able to hover, and even in level flight might need to use full throttle, and if it lands it may not be able to take off. Also, most helicopters don't routinely carry oxygen systems. The current altitude record for a small helicopter is: FAI Class E1b - Altitude Without Payload - takeoff weight 500-1000 Kg International: 40,820 ft; 12,442 m. Jean Boulet (France) Alouette SA 315-001 Lama Artouste IIIB 735 KW engine Istres, France June 21, 1972 John Hairell ) |
FAI Class E1b - Altitude Without Payload - takeoff weight 500-1000 Kg International: 40,820 ft; 12,442 m. Jean Boulet (France) Alouette SA 315-001 Lama Artouste IIIB 735 KW engine Istres, France June 21, 1972 John Hairell ) Well then, poor "Pedro", a stock H-43 didn't do too badly in 1959 at somewhere near 10,000 m., wooden blades a'flappin'! Old Chief Lynn |
John Hairell wrote in message . ..
snip Coming into the thread a bit late. The current altitude record for a small helicopter is: FAI Class E1b - Altitude Without Payload - takeoff weight 500-1000 Kg International: 40,820 ft; 12,442 m. Jean Boulet (France) Alouette SA 315-001 Lama Artouste IIIB 735 KW engine Istres, France June 21, 1972 It should be pointed out that Boulet achieved the helicopter (not just the class) absolute altitude record above by climbing the Lama until it ran out of fuel, and then making the world's longest autorotation descent. Not exactly representative of practical operational capability. But the Lama may still be the best high altitude light utility chopper, even all these years later -- it's still in commercial service in parts of the world that need its hot/high capability, although its operating costs rule it out for more routine work. In addition to the above altitude record, it also holds the (far more useful) record for highest landing and takeoff. In 1969, an SA-315B making demonstration flights for the Indian military, carrying a crew of two and 308 lb. (120 kg)of fuel, landed and took off again at 24,600 ft. (7,500m) in the Indian Himalaya, so lifting a pilot and single patient from the lower end of the Western Cwm of Everest (ca. 21,000 ft) should be (relatively) easy (depending on the density altitude and the winds) for a stripped-down Lama, especially as you can cache fuel at Everest Base Camp (18,000 feet) a mile or two away for the trip back down the valley to the hospital. Unlike the Indian army (for whom it was originally developed; they call it the Cheetah), the Nepalese military doesn't have any Lamas. Getting a Squirrel (Ecureil) up that high is quite a feat, and Col. Madan has rightly been recognized for the rescue. While lift is a problem at such heights, engine limitations (temps, torque) and control issues (loss of tail rotor effectiveness, etc.) are often of equal or greater importance. Even assuming that adequate control in high, gusty mountain winds and sufficient power/lift was available to allow routine operations at such heights, the market for helos that meet these specialized requirements would be extremely small. Unless your army has got a good chance of needing to fight in the Himalayas, Andes or the few other ranges of similar height, such performance isn't routinely necessary, and you generally sacrifice much else (speed, maneuverability, operating costs) to get it. In Afghanistan the U.S. military had such a requirement for the first time, but fortunately the CH/MH-47s (and probably Marine CH-53Es) had the ability to operate at such heights with useful (albeit considerably reduced) payloads. From what I've read the SpecOps MH-47s were transiting at up to 18,000 feet or so (pax would need supplemental O2) to get over the Hindu Kush (one of the Himalayan sub-chains; the highest point in Afghanistan is over 24,000 feet, but they didn't need to go that high) from their base in one of the surrounding 'stans, and then making insertions or extractions at heights in the 10-13,000 foot MSL range. MH-60s were able to get high enough along with a reasonable payload, but not while carrying sufficient fuel to eliminate the need for AARs, given the transit distances involved. Sikorsky S-70 (H-60) altitude versus weight graphs for IGE and OGE hover and service ceiling are available at Sikorsky's website. The Mi-8/17 family (the Mi-24 uses the same powertrain and rotor system) has also developed a reputation for good high altitude performance; the Indian military was apparently carrying supplies and doing troop movements with them at altitudes up to 15,000 feet MSL (density altitudes probably a couple of thousand feet higher) during the Kargil fighting in 1999. BTW, AFAIK the highest piston-engined helo rescue was by a civil Hiller UH-12E on Mt. McKinley back in the early '60s (IIRR). Two climbers were brought down (singly) from 18,000 ft. +, and IIRC the UH-12 in question had a normally aspirated engine rather than a turbocharged one (the latter may not have even been in production yet, but I forget). Guy |
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 07:28 PM |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
Low and high altitude airways | David Megginson | Instrument Flight Rules | 7 | September 9th 03 01:18 AM |
High Altitude operations (Turbo charge???) | Andre | Home Built | 68 | July 11th 03 11:59 PM |
