Adding an airplane rating to private pilot glider
Old April 8th 08, 03:15 PM posted to rec.aviation.soaring
Default Adding an airplane rating to private pilot glider
On Apr 7, 6:53*pm, J a c k wrote:
Doug,
Stick with it, you'll find a reason in just a few more hours: there are
dozens of them. Don't ever think you've seen it all in aviation.
Jack
Jack,
Of course I haven't seen it all. I'm sure I'll be presented with a
good reason to do a go around. Hopefully though it won't be because I
didn't fly the pattern properly.
Doug
Old April 12th 08, 12:55 AM posted to rec.aviation.soaring
If you enter the pattern at
the correct height and speed, you should have no reason to do a go
around.
I wonder out loud if teaching power pilots they have that option
creates more problems than if they were taught to land the plane the
first time around like "We" are.
Remember, a glider can touchdown to stop in 250 feet or less.
An airplane is often 1000 feet or more.
Think: What-if a glider is stopped on the runway...
I certainly want the power pilot to go around and miss me!
Or an animal, or another aircraft or a car, or...
The power pilot just botches the cross-wind, or starts
a PIO.
I still assert that (generally) glider pilots who transition to
power are better than power-only pilots. :-)
Best regards,
Jer/ "Flight instruction and mountain flying are my vocations!"
Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO
CELL 970 231-6325 EMAIL jer'at'frii.com http://users.frii.net/jer/
C-206, CFII Airplane&Glider, FAA-DEN Aviation Safety Counselor
CAP-CO Mission&Aircraft CheckPilot BM218 HAM N0FZD 263 Young Eagles!
Old April 15th 08, 03:13 PM posted to rec.aviation.soaring
Mike Gaskins[_2_]
On Apr 7, 3:24 pm, "
You don't want to force a landing when you're not comfortable with
it. As a power pilot (who is looking into but doesn't yet have a
glider rating), most of my go arounds were early in my student pilot
phase. Sometimes after turning final I'd realize that I was just too
high (too low can almost always be patched up - just give it a lil
more power to maintain altitude coming in), and I wasn't yet
comfortable with doing a slip to fix it.
So, when you're 1/3 of the way down the runway and still 300 feet up,
it's just safer to just go around and try the setup again. For me (and
I'd guess most people), they get far less frequent over time.
Particularly troublesome for me as a student pilot was that different
power levels are required for simulated normal, short, and soft field
landings. Given the different power levels they all required that I
turn base at different distances past the numbers. It can take some
time to get used to that.
Mike
sport airplane from private glider Andy[_1_] Soaring 5 November 28th 07 01:29 AM
FA: 1-Day-Left: 5 AVIATION BOOKS: JEPPS, Instrument Rating, IFR, Private Pilot Maneuvers, Pocket Simulator, etc. Jeff[_6_] Aviation Marketplace 0 October 20th 07 02:05 PM
FA: 5 AVIATION BOOKS: Instrument Rating, IFR, Private Pilot Maneuvers, Pocket Simulator, JEPPS, etc. Brent Aviation Marketplace 0 October 8th 07 03:28 AM
endorsements for private pilot glider rating Joel Taylor Soaring 2 October 2nd 03 06:44 AM
Private Pilot Glider Rating Requirements John Soaring 8 August 21st 03 01:09 AM
