g l i d e r s t u d wrote:
I am not convinced that a flapped glider will land in a much smaller field than non flapped glider. I owned a Discus2, and I landed it out...more times than I would like to discuss in this forum. I am not going to go into field landing techniques, but I could land very low energy, nose high, and stop in amazingly short fields, without hitting the nose on the ground. When taking the glider to the hanger I would touchdown before the beginning of the hanger and pull around the corner. total rolling distance is under 130ft in light wind conditions. Are you sure about that? The Road & Track Road Test Summary shows that 130' is the typical emergency stopping distance of most cars from 60 mph (52 knots). The Porsche Carrera GT, for example, stops in 124'. I would like to see you stop that D2 as quickly as a Porsche! How many times do you pick a field with that little distance? I cleaned my brake regularly to keep it in good working order. I know own a flapped glider. Would I go back sure. However I like 25.5meters and anything under is just no fun. So looking at the gliders that you listed. What fits your wallet? What fits your body? What looks sexy (to you)? What finish is in good condition (unless you like sanding and painting)? They are all good gliders, if not they would be sitting on the market cheap...but there is not much sitting on the market, and it is not cheap. On the trailer topic. Nimbus 3 in Pfieffer trailer vs last generation Cobra trailer....time difference to rig is about 3min. You could get rid of that with a trailer ramp jack. |
I am not convinced that a flapped glider will land in a much smaller field than non flapped glider. I owned a Discus2, and I landed it out...more times than I would like to discuss in this forum. I am not going to go into field landing techniques, but I could land very low energy, nose high, and stop in amazingly short fields, without hitting the nose on the ground. When taking the glider to the hanger I would touchdown before the beginning of the hanger and pull around the corner. total rolling distance is under 130ft in light wind conditions. How many times do you pick a field with that little distance? I cleaned my brake regularly to keep it in good working order. In my experience, the big advantage of certain flapped gliders (those with 40+ degree landing position, or incorporating trailing edge dive brakes like the Ventus A/B) isn't the reduction in stopping distance. It's the fact that I can make very steep approaches into short obstructed fields without a significant increase in airspeed. This allows taking full advantage of whatever stopping distance is available. Non-flapped gliders require a shallower approach, which is a problem if there are wires, trees, or a hillside in the way... Marc |
Easy decision..................I fly an Aps-13 in just these
conditions and kick ass! Brad |
On Wed, 16 Apr 2008 17:50:24 -0700 (PDT), "noel.wade"
wrote: So the question for you flapped pilots is: Would you be pushing your speed up enough in this situation to actually be using your flaps? Noel, flaps only increase your highspeed performance. The better the weather, the more advantage a flapped glider will have. The index values show this pretty well: A flapped glider has up to 7 percent more prformance than a standard class glider, meaning that your cruise speed is going to be 7 percent faster at best. Judge yourself if you really need this... ![]() Bye Andreas |
On Apr 16, 8:50*pm, "noel.wade" wrote:
Thanks All, On the flaps vs. no-flaps argument, I guess it would be best to use a hypothetical situation: Imagine you have cloudbases that are 3000' to 4000' AGL. Terrain is somewhat mountainous, but the cloudbases rise with the terrain (20 miles east of the airport you might have 7000' - 8000' MSL bases over a 5000' MSL mountain). The lift is maxing out between 4 knots and 6 knots, with a lot of 2 to 3 knotters mixed in. The Cu are 4 - 6 miles apart. Winds are 5 - 10 knots, with the best soaring areas downwind from your home field (so you face a mild upwind glide home). Your total "window" for soaring is a 5 hour period during the day when conditions are going to be generating lift. The lift is workable from 1000' AGL to cloudbase, but staying within 1500' of cloubase seems much more comfortable. This is a pretty typical "decent" soaring day in Western Washington. So the question for you flapped pilots is: *Would you be pushing your speed up enough in this situation to actually be using your flaps? ...Assume you're trying to do good cross-country flying - not super- agressive contest-like flying, but also not just puttering around within 15 miles of the airport either. Thanks! --Noel Hi Noel, As others are pointing out, forget about the "glide performance" or speed issues between two similar vintage glass ships with and without flaps. I fly in similar conditions at a club where we have probably 30 glass birds of mixed vintages and performance. There is a very direct correlation between the impressive flights and impressive pilots; there is almost no correlation between impressive flights and flaps. Since you've already absorbed the importance of trailers and automatic hookups etc, the one thing I would consider in the flaps/no-flaps debate is the off-field landing capabilities. So, the better question to be asking yourself is whether you are going to be "pushing" a bit such that you are making a few more off-field landings each year. In other words, are you going to become a more aggressive XC pilot. As Eric Greenwell mentions, there's probably nothing out there that beats an early model 20 with landing flaps for shoe-horning into tight fields. By comparison, my old LS-4, though very forgiving, couldn't quite get into as small of a field as a 20, plus it suffered from the achiles heel of LS gliders - a puny undercarriage. One other huge factor is instruments. If ship "a" has a modern panel (say a Cambridge 302 plus PDA, good pneumatics, a Becker or Filser radio) while ship "b" has older stuff (say an M-Nav, questionable TE compensation, and an old Terra radio), the better panel will almost certainly add more to your XC performance, not to mention the resale value of the glider. Finally, if you really want to "do the numbers", a 5% increase in performance for a flight that would have taken 4 hours means you save maybe 12 minutes.... Is that really going to mean a significant difference in the ability to achieve long distance XC flights? I doubt it. My 0.02. Erik Mann LS8-18 (P3) |
Nobody mentioned the obvious yet: If you're not after pure performance,
the "feel" of a glider will be far more important than 5% performance. Some pilots just like flaps, others just hate them. You may prefer "the feel" of one glider, an other pilot may prefer "the feel" of a different glider. Go fly both and decide which one you prefer. |
Bearing and Course, differences? | Allen Smith | Piloting | 27 | September 2nd 07 03:28 PM |
Rep vs. Dem Differences | Jim Weir | Piloting | 212 | September 8th 04 04:02 PM |
Aluminum differences | Lou Parker | Home Built | 16 | August 25th 04 06:48 PM |
ASW 20, ASW 20B, ASW 20C DIFFERENCES | Ventus B | Soaring | 8 | July 18th 04 10:28 AM |
Differences between Garmin 295 and 196? | carlos | Owning | 17 | January 29th 04 08:55 PM |
