Brad wrote:
Hi Marc, Your DG-600 had flaperons, as does my Apis...............they go down only 12 degrees, great for thermalling, but not so great for steep approaches. So when we are talking about flapped gliders, do gliders with un-mixed flaperons count when the topic of steep approaches is discussed? No, that's why I mentioned 40+ degrees. The trailing edge flap/brakes on my Ventus B and the 40 degree flaps on my ASW-20B made short obstructed fields seem easy. The 600 and LAK-17A were little better than standard class ships in that area, however, both kicked into warp in negative flap... Marc On Apr 17, 7:08 pm, Marc Ramsey wrote: g l i d e r s t u d wrote: I am not convinced that a flapped glider will land in a much smaller field than non flapped glider. I owned a Discus2, and I landed it out...more times than I would like to discuss in this forum. I am not going to go into field landing techniques, but I could land very low energy, nose high, and stop in amazingly short fields, without hitting the nose on the ground. When taking the glider to the hanger I would touchdown before the beginning of the hanger and pull around the corner. total rolling distance is under 130ft in light wind conditions. How many times do you pick a field with that little distance? I cleaned my brake regularly to keep it in good working order. In my experience, the big advantage of certain flapped gliders (those with 40+ degree landing position, or incorporating trailing edge dive brakes like the Ventus A/B) isn't the reduction in stopping distance. It's the fact that I can make very steep approaches into short obstructed fields without a significant increase in airspeed. This allows taking full advantage of whatever stopping distance is available. Non-flapped gliders require a shallower approach, which is a problem if there are wires, trees, or a hillside in the way... Marc |
Marc in a feild landing you would touch down at 60mph?
I would NOT touch down at 60mph (I must have had one of those special unflapped gliders that stalled less than 60)? I did say low energy and nose high. Im not a math guy but isnt energy=velocity squared? Sadly my Discus 2 went to FL so I cant show you.....maybe it was the Maughmer winglets.... Now I am stuck with my big heavy glider that has flaps. |
Marc in a feild landing you would touch down at 60mph? I would NOT touch down at 60mph (I must have had one of those special unflapped gliders that stalled less than 60)? I did say low energy and nose high. Im not a math guy but isnt energy=velocity squared? Sadly my Discus 2 went to FL so I cant show you.....maybe it was the Maughmer winglets.... Now I am stuck with my big heavy glider that has flaps. What speed do you land at in order to stop in 130 feet? |
Marc in a feild landing you would touch down at 60mph? I would NOT touch down at 60mph (I must have had one of those special unflapped gliders that stalled less than 60)? I did say low energy and nose high. Im not a math guy but isnt energy=velocity squared? Sadly my Discus 2 went to FL so I cant show you.....maybe it was the Maughmer winglets.... Now I am stuck with my big heavy glider that has flaps. My point was simply that 40 degree flaps or trailing edge dive brakes produce a tremendous amount of drag, more than spoilers will. Enough drag that you'll barely accelerate with the nose down 30 or even 40 degrees. Try that coming over our tall western trees with most standard class gliders and you'll float halfway down a 400 ft patch before you bleed off enough speed to make that nice low energy landing. And, yes, I often touch down at over 60 mph (TAS). At a 6000 to 8000 foot density altitude in mountainous terrain, you know perfectly well you shouldn't be going much slower. Now, your present glider obviously doesn't have the benefit of nice draggy landing flaps. Try a 27, 20, Ventus A/B, HP, etc., if you want to experience the real thing... Marc |
Bearing and Course, differences? | Allen Smith | Piloting | 27 | September 2nd 07 03:28 PM |
Rep vs. Dem Differences | Jim Weir | Piloting | 212 | September 8th 04 04:02 PM |
Aluminum differences | Lou Parker | Home Built | 16 | August 25th 04 06:48 PM |
ASW 20, ASW 20B, ASW 20C DIFFERENCES | Ventus B | Soaring | 8 | July 18th 04 10:28 AM |
Differences between Garmin 295 and 196? | carlos | Owning | 17 | January 29th 04 08:55 PM |
