Hi,
OK, too much noise here, let's just refrain from replying to personal attacks shall we. Anyway, speed is the magnitude of the velocity vector. In a constant speed turn, speed is (obviously) constant, but the velocity is continuously changing. This is by definition. It doesn't matter how you or anyone else uses these terms. Speed is just a number, Velocity is speed plus a 'direction' variable. Since acceleration is the rate of change of velocity (dv/dt), the above mentioned aircraft in the constant speed turn is accelerating. Hilton |
yeah but you got creamed in this thread! :-? :/ :')
![]() WingFlaps expressed precisely : Stefan was doing quite well actually, |
On Apr 25, 7:11 am, WingFlaps wrote:
"In physics...The scalar absolute value (magnitude) of velocity is speed." Cheers But it's relative to space, not the earth, as I posted earlier. Earth pulls straight down, nothing more. Do this, as we have done many times: Go out and fly on a day when the upper winds are at 30 or 40 knots and get under the hood, do 30 degree banked turns, maintaining a constant altitude and power setting, and see if the airspeed changes. Got to be done over flat land, BTW. Any orographic lift will screw up the altitude. You won't see any performance changes, but the airplane's flight path over the ground sure isn't circular. Try 45 degree banked turns. Try it in a glide. See if you can prove me wrong. Dan |
On Apr 26, 5:45*am, wrote:
On Apr 25, 7:11 am, WingFlaps wrote: "In physics...The scalar absolute value (magnitude) of velocity is speed." Cheers * * * *But it's relative to space, not the earth, as I posted earlier. Earth pulls straight down, nothing more. Do this, as we have done many times: Go out and fly on a day when the upper winds are at 30 or 40 knots and get under the hood, do 30 degree banked turns, maintaining a constant altitude and power setting, and see if the airspeed changes. Got to be done over flat land, BTW. Any orographic lift will screw up the altitude. You won't see any performance changes, but the airplane's flight path over the ground sure isn't circular. Try 45 degree banked turns. Try it in a glide. See if you can prove me wrong. WTF? I wasn't talking about speed over the ground... |
On Fri, 25 Apr 2008 12:59:19 -0700 (PDT), WingFlaps wrote:
WTF? http://www.youtube.com/watch?v=F48eTMgqF2w -- -----BEGIN PGP SIGNATURE----- Version: PGP 8.0.2 iQA/AwUBR/qGPRv8knkS0DI6EQLqQQCfYI/+jhW28/0AaBVgq58mnuYYo2AAnRMP r/ChOzrJkKnGHZcngwRffPMG =2EPt -----END PGP SIGNATURE----- |
lancair crash scapoose, OR | gatt | Piloting | 10 | October 26th 06 03:34 PM |
Lancair IV | Dico Reyers | Owning | 6 | October 19th 04 11:47 PM |
Lancair 320 ram air? | ROBIN FLY | Home Built | 17 | January 7th 04 11:54 PM |
Lancair 320/360 kit wanted!!! | Erik W | Owning | 0 | October 3rd 03 10:17 PM |
Lancair IVP | Peter Gottlieb | Home Built | 2 | August 22nd 03 03:51 AM |
