On Apr 27, 11:22 pm, "Morgans" wrote:
wrote Unless that engine is really tight (pretty much zero ring leakage) he'll end up with backpressure in the crankcase and will blow the front crank seal out, losing oil at a good clip I agree. How come airplane engines don't have PCV valves, plumbed back into the intake manifold, like cars? You could even use an oil separator, before the gas enters the manifold, if too much oil was worried to be a problem. An arrangement like that would solve the oily discharge on the belly, I would think. Might even keep the intake valves lubricated a little bit! g I wonder what the answer is, and why that solution would be a problem. I'm sure it has been tried, since it seems there is truly nothing new under the sun, when it comes to airplanes. -- Jim in NC No PCV because the aircraft engine runs at high manifold pressures most of the time, so there's too little differential (read "manifold vacuum" to suck a PCV valve open and adequately purge the gases. On an auto, when the throttle is fairly open, the PCV valve pretty much closes. The valve has to be there to stop flashback in case the engine backfires; the flame would ignite the gases in the crankcase. Boom, big ugly mess and a major CG shift. In the auto, the gases will, at full throttle or nearly so, back up through the crankcase intake filter and into the air cleaner and get cleaned up that way. The filters act as flame arrestors. When the engine gets old, there's too much blowby and lots of it exits this way, and its moisture freezes up the crankcase intake filter in colder weather. BTDT. It could be done, with some different plumbing, which adds weight, expense, and certification hassles. When the EPA or whoever decides that airplanes need all the antipollution stuff that cars have, we'll see it on airplanes and our useful loads will drop considerably. Dan |
"Morgans" wrote in message
... How come airplane engines don't have PCV valves, plumbed back into the intake manifold, like cars? You could even use an oil separator, before the gas enters the manifold, if too much oil was worried to be a problem. Jim ........... If you've ever seen the oil that collects in an oil/water separator, you wouldn't want it back in an engine. I realize that some of the water in the separator is condensation from the air coming back up the vent from the outside after shutdown, but even so, the watery sludge in the reservoir is really gross. Best to spend a few bucks and a couple of hours building a simple firewall-mounted separator (plans available in old issues of Sport Aviation when they had such things). Wiping the bottom of a fuselage is kind of a Zen thing for me. Takes me back to a simpler time. Rich S. |
... wrote Unless that engine is really tight (pretty much zero ring leakage) he'll end up with backpressure in the crankcase and will blow the front crank seal out, losing oil at a good clip I agree. How come airplane engines don't have PCV valves, plumbed back into the intake manifold, like cars? You could even use an oil separator, before the gas enters the manifold, if too much oil was worried to be a problem. An arrangement like that would solve the oily discharge on the belly, I would think. Might even keep the intake valves lubricated a little bit! g I wonder what the answer is, and why that solution would be a problem. I'm sure it has been tried, since it seems there is truly nothing new under the sun, when it comes to airplanes. A) They don't have to. B) PCV as found on automobiles won't work well at higher loads (no vacuum), but new sytems for large diesel trucks are now coming onto the market to meet emission standards - they have the same lack of vacuum... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
leaning a lycoming engine | airpix | Piloting | 0 | April 19th 06 02:02 PM |
Experimental Lycoming engine clones | Ted | Home Built | 1 | April 15th 06 09:21 PM |
Which overhauled Lycoming 0-360 A4M Engine To Fit In My Archer ? | Roy Page | Owning | 7 | February 2nd 06 02:19 AM |
Lycoming Engine Rebuild Seminar | N523RV | Home Built | 0 | August 18th 05 06:37 PM |
Just venting about my V35's annual/engine replacement | Peter R. | Owning | 11 | November 27th 04 05:40 PM |
