Auto Engine Conversion Video
Old May 3rd 08, 11:19 PM posted to rec.aviation.homebuilt
stol
Default Auto Engine Conversion Video
On May 3, 8:31*am, Jerry Springer wrote:
stol wrote:
Ok guys. make some popcorn, get a cold beverage, prop up your feet and
get ready to be bored. :)).
I will try to answer Jims questions as best that I can.
My main protocol during this whole process was and still is.. First. I
want safety and durability. second comes weight and a close third is
cost. Keeping it in those confines has served me well and kept me
alive,,, so far G
As I recall you posted on the RV-list one time that your airplane
was over weight and scary to fly?
Jerry
All I state is the facts. My plane is heavier then the factory 801
simply because it has more options on it. I NEVER said it was
overweight................... As for scary, if I posted that during
the first few hours of my test flights in my plane then, yeah, I was
for sure leary of the outcome. That experience has made me a better
pilot and hopefully a better person. When you test fly an overpowered,
one of a kind aircraft you will understand, until then just chill out
and enjoy what some of us do to advance aviation..
Tailwinds..
Ben Haas
N801BH
Old May 4th 08, 02:19 AM posted to rec.aviation.homebuilt
Peter Dohm
"stol" wrote in message
Tailwinds..
Ben Haas
N801BH
-----new post begins-----OE didn't do it again-------
Actually, most homebuilts are slightly "chubby" and a longer equipment list
is one of the three most common reasons--the other two being slightly larger
engines and fancier interior and exterior finishes.
In any case, the term "overweight" would be preposterous since you would
seem to have sufficient authority to reduce the usefull load, document the
performance (and strength if appropriate) to a higher maximum weight, or any
combination of your own choosing.
Peter
Old May 4th 08, 05:13 AM posted to rec.aviation.homebuilt
stol
All I state is the facts. *My plane is heavier then the factory 801
overweight................... *As for scary, if I posted that during
the first few hours of my test flights in my plane then, yeah, *I was
Tailwinds..
Ben Haas
N801BH
Peter
I plea guilty to all three of the charges...
Ben ( Serving a life sentence of aviation) Haas
New Video Auto Tow 3,300 ft plus Aerobatics John Cagle Soaring 3 March 19th 08 02:02 AM
Auto-conversion adapter plate Ernest Christley Home Built 3 June 29th 05 06:19 AM
Auto-Engine Conversion Oil Cooler D.W. Taylor Home Built 0 April 29th 05 05:30 AM
Auto conversion cost post Richard Riley Home Built 13 December 28th 03 12:52 PM
C172 Penn Yan 180 HP Engine Conversion John Roncallo Owning 4 October 20th 03 06:42 PM
