Waynes Rule
Old May 1st 08, 09:01 PM posted to rec.aviation.soaring
toad
Default Waynes Rule
On May 1, 3:38 pm, Tuno wrote:
I forgot to add -- Tuno's Rule assumes there are no conveyer belts
near the balloon.
Is my calender right ? It is May 1st, not April ? Right ?
Todd Smith
Old May 2nd 08, 12:02 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
Matt, go to the yahoo site for more information.
Toad, there is no practical difference, ther result is the same, there is however, considerable mis-understanding on the cause
Jim, top of the class today
Tuno, wrong, sorry. The balloon rises because it is displaced by the denser air around it.
The fact that it is hotter, lighter, smaller, larger or a different color does not influence its rising without the consideration of the denser air around it.
Bouyancy is not new, you are correct there
http://groups.yahoo.com/group/thermal_truth/
bagger
Old May 2nd 08, 07:32 AM posted to rec.aviation.soaring
Tuno
Default Waynes Rule
bagger: tell me -- why is the air around the balloon displacing
it? ... because it doesn't like it, or maybe just feels like it?
Old May 2nd 08, 01:24 PM posted to rec.aviation.soaring
Default Waynes Rule
On May 1, 6:02*pm, bagmaker
bagger
bagmaker
http://en.wikipedia.org/wiki/Buoyancy
Old May 2nd 08, 01:38 PM posted to rec.aviation.soaring
toad
Default Waynes Rule
Yes it is "LIGHTER" than the air around it, that's what LIGHTER
means.
No the balloon rises because the ambient pressure at the bottom of
the balloon is higher than the ambient pressure at the top. The
difference between these pressure forces is equal to the weight of the
displaced air. If the weight of the balloon is less than that
displaced weight, then the balloon rises. The only way that happens
is if the balloon is LIGHTER than the displaced air.
What did you think that the balloon (or thermals) was supposed to be
LIGHTER than ? Your shoe ? A car
Please read up http://en.wikipedia.org/wiki/Buoyancy before you try
and re-invent physics.
Or better yet, go fly somewhere.
Todd Smith
3S
Old May 2nd 08, 05:47 AM posted to rec.aviation.soaring
Werner Schmidt
Default Waynes Rule
Heallo Tuno, you wrote at 01.05.2008 21:38
near the balloon.
YMMD!
Regards
Werner
Old May 2nd 08, 06:17 AM posted to rec.aviation.soaring
Matt Herron Jr.
Default Waynes Rule
OK Wayne.
I went to your group and read your rule, but I am not finding an
"aha!" here. Your instructors and all the meteorologists you talked
to just left out the obvious (and therefor assumed) fact that it is
all about differentials. differential pressure, differential
temperatures, etc. Your rule like saying that I cannot pull myself up
on a chin-up bar by itself. The bar must push down on the earth at
the same time, and the earth, in turn, must provide an equal and
opposite force, and the center of our masses must be displaced by the
ratio of our masses, etc, etc, etc,
For me the idea that "hot air rises" is a perfectly legitimate and
valid model of what is going on. It helps me get to the subsequent
and more interesting extrapolations that might lead to actionable
knowledge.
Matt
Old May 2nd 08, 04:21 PM posted to rec.aviation.soaring
Default Waynes Rule
On May 1, 12:20*pm, Tuno wrote:
Wayne:
When my friend Burner fills his passenger balloon with hot air and
looses the tether, it rises because the air inside it is less dense
than the air outside it.
Tuno's Rule: A thermal is a hot air balloon without the balloon.
2NO
Jim's rule: When it's too nice a day to sit in the office, go fly.
Nobody's last thought before passing is "I wish I'd spent more time at
the office"
Goin' flying! Seeya!
Old May 2nd 08, 03:03 AM posted to rec.aviation.soaring
user
Default Waynes Rule
Any way you care to look at it is fine. However, if you want to elevate your
case above others, it needs to be a better predictor of outcomes. Gather you
evidence and show us how Wayne's Law will improve our ability to accurately
predict the location, width, height, and strength of thermals. I'm game;
convince me.
"bagmaker" wrote in message
Below is a pre-amble to a new yahoo group I have started to discuss
thermals. I would ask all interested gliding pilots to join in and
learn, or teach.
Ok, we know the shapes, triggers, the sizes, the volumes, the heights,
the strengths, the distances between thermals.
We speculate on rotation, blue holes, convergiences, moisture content,
adiabatic lapse rates, height to spacing ratio's and a dozen other
thing relating to thermals.
We have had countless thermal studies, used blipmaps, radars, sensors
and test flights for nearly a hundred years.
But we base it all on the blind understanding that a thermal rises
simply because it is hotter than the air around it, or, at best, less
dense that the air around it.
This is not true.
We feel a wind gust on the airfield in the morning and we know the day
has "started". Sure enough, a willy-willy or dust-devil appears,
usually triggered by the activity on the grid, swirling off down-wind
between the pie-cart and the tug/glider combination, or perhaps the
winch and the glider.
We know a thermal bubble has just broken loose, the willy-willy is the
under-current eddieing around below it in suction, the breeze filling
the void that the thermal left behind.
This is not true.
We see a bubble in the water beside us as we rise in our scuba gear.
The bubble has eddies below it, turbulence beside and below it. It has
a smooth, rounded top and a flat bottom. This is true, however,it is
not rising by itself, as all seem to think, it is being displaced by
the water.
Thermals are no different or they would break Waynes Rule.
After years of racking my brain on this subject -my passion- and
debating it with freinds, scientests, sceptics and expert alike, I
cannot seem to make people understand what I see as the truth.
Perhaps I am mistaken, I welcome education from my peers in the gliding
community. If I am not, many people in the world will benefit from this
understanding, as the rules will probably apply to heating of just
about everthing.
I am taking liberty calling the theory Waynes Rule, I apologise to the
purists and the great scientists of the past whose work with gravity
and mass I am borrowing the theory from, but for the discussion, its
Waynes Rule.
Wayne Carter
(bagger)
bagmaker
Old May 3rd 08, 09:29 PM posted to rec.aviation.soaring
Eric Greenwell
Default Waynes Rule
the water.
Really? A couple days ago, I saw a dust devil that took dust up 2000
feet in a narrow, spinning column. It didn't look anything like bubble.
The same day, a field fire created a narrow column of smoke topped by a
cloud, but it didn't spin like the dust devil. It didn't look like a
bubble, either.
I suggest that a discussion focusing on a bubble model of thermals is
doomed from the beginning, and to narrow that focus to whether it rises
because it's lighter than the surrounding air or the surrounding air is
heavier than the bubble will yield even less understanding thermals.
But, perhaps I misunderstand the goal of the proposal.
* Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4
* New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more
Age 60 Rule is now Age 65 Rule Kingfish Piloting 44 December 21st 07 11:31 AM
TSA rule, what does this mean? Robert M. Gary Piloting 27 April 21st 07 02:54 AM
New TSA Rule NW_PILOT Piloting 18 October 27th 04 12:35 AM
New TSA Rule G.R. Patterson III Piloting 0 October 23rd 04 04:12 PM
51% rule Robert Bates Home Built 12 August 1st 03 09:06 PM
