Here's a demo of the TrackIR and explains how it works:
http://www.youtube.com/watch?v=_AO0F5sLdVM --Noel P.S. Condor doesn't fully support "6 degrees of freedom" like they talk about. But it does support looking up, down, left, and right. |
sisu1a wrote:
On May 4, 6:57 am, Tony Verhulst wrote: Bill Daniels wrote: ... There's a whole hobby of building realistic cockpits to go with this simulator. Would those hobbyists have web sites? Tony V Here's one for starters: (major link reconstruction needed; not a glider cockpit, but...) http://images.google.com/imgres?imgu...icial%26sa%3DG My club has an L23 fuselage wreck and we're in the planning stage of chopping off all abaft the rear cockpit, hooking the controls up to Condor (or something similar) and projecting local scenery on screens around the cockpit. Something like Cambridge (UK) has done. Tony V. http://soargbsc.com |
Hey, Paul
If you get that pitot/static airdata air pump thingy working, I'd like to hear about it. It would be a really great way to learn to use a new vario/flight computer. Bill D "sisu1a" wrote in message ... On May 4, 6:57 am, Tony Verhulst wrote: Bill Daniels wrote: ... There's a whole hobby of building realistic cockpits to go with this simulator. Would those hobbyists have web sites? Tony V Here's one for starters: (major link reconstruction needed; not a glider cockpit, but...) http://images.google.com/imgres?imgu...icial%26sa%3DG I have been working on a related project, to use one's own sailplane as a cockpit for a simulator, with one's own instruments/controls. What I am designing is a piece of hardware that will generate the associated dynamic/static/TE/and capacity pressure values that would exist during "in flight" conditions (Condor outputs standard sim signals which could easily be translated into their associated pressure values). These pressures can be fed to an actual instrument panel, making the instruments read correct for their given simulated condition quite effectively. Since Condor also outputs NEMA data, flight computers/nav hardware can also be active. This will be used in conjunction with little (sugar cube sized) independent self powered pizeo gyros with bluetooth (or some other sort of RF) transmitting capabilities that would each be placed on the extremities of all the cockpit controls. The transmitted signals would all be received by a device that would be converting the gyro's movements into standard simulator control inputs that would be fed back into Condor for your flight inputs. To make clear my project goals in case it's still vague: I want to be able to use my own glider with it's controls and instruments to fly on the simulator. This wold be achieved by pulling the plane into the "drive in theater" (a screen on a large wall with a projector set up) and connect the pneumatic interface to my plane's pneumatic system and put the pizeo gyros described above on their respective controls. Go through a calibration sequence to define the full movements of the controls, buckle in and begin checklist...Once this is closer to being finished I will also work on the feedback issue, which I already have several ideas. This glider in this setup could easily be changed to another ship so long as flight data for it exists on Condor (very easy if it already has a Winter quick pneumatic disconnect plug...) If anyone that reads this finds it intriguing and would like to help, pm me. Paul |
On May 4, 3:44 pm, "Bill Daniels" bildan@comcast-dot-net wrote:
Hey, Paul If you get that pitot/static airdata air pump thingy working, I'd like to hear about it. It would be a really great way to learn to use a new vario/flight computer. Hi Bill, I joined the Condor group and posted my thoughts on the subject in a little more detail on the cockpit builder's forum (then had to update my post after reading your original post on the subject...) On the Condor forum I saw your original inquiry as to an interface device to turn sim signals into the correct pressures (to enable the use real pneumatic instruments for a sim/etc) seemed to be abandoned due to 'perceived' difficulties in achieving the correct pressures since they were dubbed too small to be precisely controlled. I do not see this as a problem, but an asset. Rather than the pump idea (which does seem problematic) my proposed system is based on C-N-C controlled (via ball screw lead) plungers. Since the values are rather small, rather small components are required to build it. It is actually quite easy to make extremely small and precise pressure changes with a plunger, and with a pressure transducer feedback loop will remain exactly on desired target. I fully agree that this would be a great way to test out new instruments and such in addition to being a damn fun sim tool! If coupled to Condor, (or other soaring sims with NEMA outputs?) even complicated flight computers could be tricked into going through all their functions, although some may also require tricking the compass as well (a C-N-C controlled steel bar to generate a "false north" in axis around heading sensor if so equipped?). I'll definitely share when I have more to tell. Paul Hanson |
IFR simulators | Tony | Owning | 8 | October 27th 03 08:42 PM |
IFR simulators | Richard Kaplan | Instrument Flight Rules | 3 | July 24th 03 03:53 AM |
