The A/C in question is a 1974 Bellanca 7ECA, re-engined with an O-320
so it's effectively a 7GCAA. It belongs to the Offutt AFB Aero Club and has seen very little use, often sitting for weeks at a time until a week ago when I began taking dual in it 2-3 times a week to get my tailwheel endorsement. The fuel system is not for inverted flight, so no header tank -- two 18-gallon wing tanks with check valves to a single vent on the left, crossflow pipes to the aft fuel manifold under the baggage compartment and crossflow pipes to the forward fuel manifold on the firewall. Caps are non-vented and the gaskets are like new. This A/C is drawing 3-4 times as much fuel from the left tank as from the right and it's not crossflowing on the ground, even overnight. We've made right patterns as well as lefts -- makes no difference. We haven't done any extended S&L flight, just 11 NM to Plattsmouth, NE for pattern work. The club's A&P has blown out the feed and vent lines and got a good blast into the right tank from both. We're getting a free flow of clean gas out of all four drains. So what's our next move? Anybody had this problem? |
On Wed, 7 May 2008 11:17:24 -0700 (PDT), quietguy
wrote in : The fuel system is not for inverted flight, so no header tank -- two 18-gallon wing tanks with check valves to a single vent on the left, crossflow pipes to the aft fuel manifold under the baggage compartment and crossflow pipes to the forward fuel manifold on the firewall. Caps are non-vented and the gaskets are like new. This A/C is drawing 3-4 times as much fuel from the left tank as from the right and it's not crossflowing on the ground, even overnight. We've made right patterns as well as lefts -- makes no difference. We haven't done any extended S&L flight, just 11 NM to Plattsmouth, NE for pattern work. The club's A&P has blown out the feed and vent lines and got a good blast into the right tank from both. We're getting a free flow of clean gas out of all four drains. I'm not able to accurately visualize the fuel system piping from your description, but has the A&P checked for a stuck check valve in the vent piping? |
On May 8, 6:17*am, quietguy wrote:
This A/C is drawing 3-4 times as much fuel from the left tank as from the right and it's not crossflowing on the ground, even overnight. The lack of crossfeed sounds like the cross feed system is the problem. Is the crossfeed supplied by the fuel selector being set at both or a separate cross feed pipe? If you've had water sit in a line for a long time some corrosion may have gunked up the line from the right tank -I've seen that in ally pipes connected to a valve with steel and brass parts. Cheers |
On May 7, 3:39 pm, WingFlaps wrote:
The lack of crossfeed sounds like the cross feed system is the problem. Is the crossfeed supplied by the fuel selector being set at both or a separate cross feed pipe? If you've had water sit in a line for a long time some corrosion may have gunked up the line from the right tank -I've seen that in ally pipes connected to a valve with steel and brass parts. There is no "crossfeed" system in a Citabria, but it will crossflow through the line tees, Crossfeed systems are found in multis. There are two tanks, each having two outlets, one near the front and one near the rear. The two front lines run down the structural tubing below the front spar and meet at a tee above the shutoff valve. The two rear lines run back and down behind the cabin and tee together at the bottom of the airplane, and a single line runs from there forward to join up with the teed-together front lines. The fuel proceeds through that point through the shutoff and thence to the strainer. The vent is located under the left wing, and is plumbed into the outboard end of the left tank. The inboard end of the left tank has a vent fitting that is connected across the top of the cockpit to the right tank with no check valve between, so that the right tank is vented to the left and the left is vented outside. Everything will work well as long as the fuel caps aren't leaking or have been mistakenly replaced with vented caps, which will screw up the tank pressures and cause uneven flow. The OP says that all vent and fuel lines were blown clear and were flowing OK. Yet the thing won't feed evenly or crossflow even overnight, which has me puzzled mightily. We have a 7ECA and a 7GCBC, both with this simple system, and the only hassle I've ever had with either was an uneven flow problem in the ECA caused by a vented cap that a previous owner had installed on the RH tank, and in the GCBC when the LH cap gasket split and sucked lots of fuel overboard. I would suspect, at the least, that in the OP's airplane some of the short lengths of rubber hose that join the various bits of tubing are collapsed internally, allowing air to blow through when checking and leaving the impression the the lines are clear, but collapse and restrict the flow the rest of the time. Those hoses should be replaced every five years to avoid the deterioration that comes with age and especially with Mogas. The hose will look fine on the outside but the inner liner can swell shut and restrict the flow. Asthmatic hoses. Dan |
On May 7, 9:03*pm, wrote:
a very informative post I'll go over it with the club's A&P tomorrow and post the findings when we've gotten to the bottom of this. Thanks! |
"Maxwell" luv2^fly99@cox.^net wrote in news:1WBUj.5949$1M1.633
@newsfe23.lga: "Bertie the Bunyip" wrote in message ... quietguy wrote in news:b8a07cf2-f01e-4dba- 9793- : The A/C in question is a 1974 Bellanca 7ECA, re-engined with an O- 320 so it's effectively a 7GCAA. It belongs to the Offutt AFB Aero Club and has seen very little use, often sitting for weeks at a time until a week ago when I began taking dual in it 2-3 times a week to get my tailwheel endorsement. The fuel system is not for inverted flight, so no header tank -- two 18-gallon wing tanks with check valves to a single vent on the left, crossflow pipes to the aft fuel manifold under the baggage compartment and crossflow pipes to the forward fuel manifold on the firewall. Caps are non-vented and the gaskets are like new. This A/C is drawing 3-4 times as much fuel from the left tank as from the right and it's not crossflowing on the ground, even overnight. We've made right patterns as well as lefts -- makes no difference. We haven't done any extended S&L flight, just 11 NM to Plattsmouth, NE for pattern work. The club's A&P has blown out the feed and vent lines and got a good blast into the right tank from both. We're getting a free flow of clean gas out of all four drains. So what's our next move? Anybody had this problem? seen minor fed variations, but not like this. I have th emanuals out at the hangar and access to a good AI tomorrow night, so I'll ask him. He's rebuilt mine so he should know. Bertie Of coarse you can Bertie Buttlipp, cuz you know everything, you know everyone, you've done everything. Not everythingk just more than you, wannave boi. BTW, you know the answer? Didn't think so. Bertie |
"Bertie the Bunyip" wrote in message ... OK, talked to my guy. He had several suggestions. One is to drain it all dry and then blow some air (carefully!) into the right tank and see if you can hear it coming across into the left tank by listening at the filler cap. Possible problems he came up with were a crushed or swollen fuel line downstream of where you tested previously, or, he thought more likely, incorrect placement of the little plastic fuel vent deflector and/or the location of the fuel vent itself. There are specs for the location of these if you look in the manuals. But for the fact that the fuel doesn't migrate when parked, I would have said this is definitely your problem For instance, Cessnas with bent or incorrectly positioned vents are chronically out of balance. Bertie Oh yeah, that's a lot of help. Where did you find this wanna boi, Wikipedia? |
| Citabria Fuel-Flow Problem | quietguy | Piloting | 45 | May 24th 08 02:41 PM |
| Fuel Flow and Peak EGT | Kobra | Owning | 21 | May 2nd 07 03:02 AM |
| fuel flow on the cheap | pittss1c | Home Built | 3 | May 7th 06 11:12 PM |
| V8 fuel flow | Robert Bates | Home Built | 34 | January 24th 05 04:41 AM |
| Fuel Flow Monitoring | EDR | Owning | 4 | October 18th 03 04:10 AM |
