On May 16, 12:46*pm, Brian wrote:
Take a glider at approach speed about 5 feet off the runway in steady state (at least for a glider) level flight with all drag devices retracted.. If you deploy the spoilers and do not change attitude the glider will drop onto runway, speed will change very little. if you deploy airbrakes the glider will slow and settle to the runway. If you deploy flaps the glider will balloon up. Maintaining a constant attitude in the test you describe will require a pitch control input and that input controls what happens to the glider as the devices are deployed. To put it another way, maintaining pitch attitude is an arbitrary choice. You could have specified constant sink rate, constant glide path, constant airspeed, etc etc. That close to the ground my intent is to control sink rate and the controls interact to achieve that. In my experience deploying my top surface devices with stick free results in nose down pitch, increased sink rate, and airspeed remains essentially constant. Who can define the name of the device that causes that? Andy |
snip
Maintaining a constant attitude in the test you describe will require a pitch control input and that input controls what happens to the glider as the devices are deployed. *To put it another way, maintaining pitch attitude is an arbitrary choice. *You could have specified constant sink rate, constant glide path, constant airspeed, etc etc. *That close to the ground my intent is to control sink rate and the controls interact to achieve that. In my experience deploying my top surface devices with stick free results in nose down pitch, increased sink rate, and airspeed remains essentially constant. Who can define the name of the device that causes that? Andy Yes, I specified constant attitude simply because I can obviously stop the descent by pitching back up. I was just trying to Isolate the effects of the various drag devices which as you point out is simlar no matter what the initial steady state is. One other feature I have noticed on Spoilers is they tend to be ON/OFF as opposed to Airbrakes that tend to be more proportional. I.E. in my example if you slowly apply the Spoilers at a certain point the glider will just drop. Where as the Airbrakes will tend to gradually become more effective. Brian |
Bill Daniels wrote:
Both common sense and aerodynamics say that if the G-meter says 1.0 then lift = weight. Applying 'spoilers' doesn't change that. Spoilers do not 'reduce lift' if the G-meter continues to say 1.0 - they increase drag. The general formula is lift = weight x G There is a nuance he opening the spoilers on most gliders does diminish the lift of the wing section near the spoilers. To compensate, the outer panels have to carry more of the weight of the glider. You can clearly see this on an ASW 20 or open class ship, when the wings bend up noticeably after the spoilers are open. So, in a steady state condition, the lift is *decreased* over a significant fraction of the wing, but the overall lift remains the same. The reverse is true for flaps used for glidepath control: the lift in the flapped section is increased. I can see this clearly on my ASH 26 E, because now the outer panels are bent down slightly when landing flaps are selected. So, in a steady state condition, the lift is *increased* over a significant fraction of the wing, but the overall lift remains the same. Now, I'd say a true divebrake is what some fighters have: a panel(s) that pop out of the fuselage, so they only add drag, and don't affect the lift of the wing. Maybe we should consider our retractable landing gear our "divebrake". Of course, we glider pilots are a sloppy bunch and lump divebrakes in with spoilers, and airbrakes. We pretty much stick with calling flaps, well, flaps. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On May 16, 4:34 pm, Eric Greenwell wrote:
Bill Daniels wrote: Both common sense and aerodynamics say that if the G-meter says 1.0 then lift = weight. Applying 'spoilers' doesn't change that. Spoilers do not 'reduce lift' if the G-meter continues to say 1.0 - they increase drag. The general formula is lift = weight x G There is a nuance he opening the spoilers on most gliders does diminish the lift of the wing section near the spoilers. To compensate, the outer panels have to carry more of the weight of the glider. You can clearly see this on an ASW 20 or open class ship, when the wings bend up noticeably after the spoilers are open. So, in a steady state condition, the lift is *decreased* over a significant fraction of the wing, but the overall lift remains the same. The reverse is true for flaps used for glidepath control: the lift in the flapped section is increased. I can see this clearly on my ASH 26 E, because now the outer panels are bent down slightly when landing flaps are selected. So, in a steady state condition, the lift is *increased* over a significant fraction of the wing, but the overall lift remains the same. Now, I'd say a true divebrake is what some fighters have: a panel(s) that pop out of the fuselage, so they only add drag, and don't affect the lift of the wing. Maybe we should consider our retractable landing gear our "divebrake". Of course, we glider pilots are a sloppy bunch and lump divebrakes in with spoilers, and airbrakes. We pretty much stick with calling flaps, well, flaps. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly An aerodynamicist would say that a spoiler changes the lift vs angle- of-attach curve of a wing section. It will also change the drag curve of that wing section. I don't think there are universally accepted definitions of these terms. A side note, just about any kind of device on the wing will affect both lift and drag, but depending on the location and type, will affect lift and drag in different proportions. This can lead to confusion of the terms. Todd Smith 3S |
"Spoilers differ from airbrakes in that airbrakes are designed to increase
drag while making little change to lift, while spoilers greatly reduce lift while making only a moderate increase in drag." what does the typical sailplane have? Spoilers or airbrakes? - John "67" DeRosa A spoiler would be a flap on the top of the wing front hinged forward of the COP (centre-of-pressure) such that the when it opens at the free end the airflow across the wing is spoiled (and hence the lifting action decreased) but not directly blocked (or braked). A brake would be a paddle that operates at a right angle to the airflow and directly blocks the airflow - effectively slowing the movement of the wing relative to the airflow. Sort of visualise the difference between a wing (spoiler) on a racing car creating downpressure and throwing a dirty great parachute out the back to assist braking? Jim. |
On May 16, 12:59*pm, "jonathan"
PLEASE.REMOVE.THIS.PREFIX.jonathan.go...@ntlworld .com wrote: Sort of visualise the difference between a wing (spoiler) on a racing car creating downpressure and throwing a dirty great parachute out the back to assist braking? Jim. Oh, boy - where to begin? First: In the automobile world, the difference between a "spoiler" and a "wing" is very important. A wing is a device that allows air to flow over both top and bottom surfaces, and is typically used to create down-force (just like the horizontal tail on your glider). A spoiler actually has the leading edge fixed to the auto in such a way that air flows over the top surface only. It, too, creates down- force, but it also creates a lot more drag than a wing. Second: Technically "spoilers" are supposed to be there to change the airflow over the _wing_. By "spoiling" the airflow such that it cannot follow the curves of the airfoil, it changes the glide-path and/ or drag of the aircraft. "Airbrakes" are technically a device _anywhere_ on the aircraft that increases drag. Now here's where most people fall down: They want to categorize every device as one or the other type. But the plain truth is that most devices on sailplanes do BOTH. Have fun debating spoilers and airbrakes! I don't think this one will ever be fully settled... --Noel |
noel.wade wrote:
On May 16, 12:59 pm, "jonathan" PLEASE.REMOVE.THIS.PREFIX.jonathan.go...@ntlworld .com wrote: Sort of visualise the difference between a wing (spoiler) on a racing car creating downpressure and throwing a dirty great parachute out the back to assist braking? Jim. Oh, boy - where to begin? First: In the automobile world, the difference between a "spoiler" and a "wing" is very important. A wing is a device that allows air to flow over both top and bottom surfaces, and is typically used to create down-force (just like the horizontal tail on your glider). A spoiler actually has the leading edge fixed to the auto in such a way that air flows over the top surface only. It, too, creates down- force, but it also creates a lot more drag than a wing. Second: Technically "spoilers" are supposed to be there to change the airflow over the _wing_. By "spoiling" the airflow such that it cannot follow the curves of the airfoil, it changes the glide-path and/ or drag of the aircraft. "Airbrakes" are technically a device _anywhere_ on the aircraft that increases drag. Now here's where most people fall down: They want to categorize every device as one or the other type. But the plain truth is that most devices on sailplanes do BOTH. Have fun debating spoilers and airbrakes! I don't think this one will ever be fully settled... I think it's fair to say that the debate is of little significance, but much concern. ;-) Shawn |
I'd continue to use them interchangeably until we have a glider with
independent controls for spoilers and airbrakes. However, if you like precision, I'd opt for spoilers. I can't recall having seen a modern glider that didn't have upper surface spoilers when equipped with lower surface airbrakes. If during a positive control check the pilot corrects your call of "spoilers," look under the wing for the extra control surface. "ContestID67" wrote in message ... I spotted the following statement in Wikipedia. http://en.wikipedia.org/wiki/Spoiler_%28aeronautics%29 http://en.wikipedia.org/wiki/Air_brake_%28aircraft%29 "Spoilers differ from airbrakes in that airbrakes are designed to increase drag while making little change to lift, while spoilers greatly reduce lift while making only a moderate increase in drag." I had always used the terms spoilers and airbrakes interchangeable. This statement makes it seem like they are not. So what does the typical sailplane have? Spoilers or airbrakes? - John "67" DeRosa |
user wrote:
I'd continue to use them interchangeably ..... If during a positive control check the pilot corrects your call of "spoilers," look under the wing for the extra control surface. Yes, I've seen at least 2 books (FAA Glider Flying Handbook and Russell Holtz's Glider Pilot's Handbook of Aeronautical Knowledge)where the writer claimed that if the ..um.. "device".. extended top surface only it was a spoiler and if it extended from both survaces it was an air brake. Seems dubious to me. Tony V LS6-b "6N" |
Way back when ... there were terminal velocity dive brakes on gliders. (I
believe another term was DFS dive brakes, but am not sure about that). These brakes would hold the glider below VNe in a vertical dive. At some point, as air foils became thinner, manufacturers agreed that the air brakes would be designed to hold the glider below VNe at a 45 deg. descent angle. I believe this was sanctioned by JAR, IGC, or some such. Spoilers will place no limit on speed and cannot be used in a steep or High Parasitic Drag Approach, whereas airbrakes can be. No one has mentioned an important difference between flaps and airbrakes (whether spoilers, divebrakes, airbrakes, or your term of choice). This difference is the effect had on closing them after having established a stabilized descent under their use. Retracting the airbrakes causes the stall speed to be lowered and the glide angle to improve. If you are low and slow, retracting improves EVERYTHING. If you are low and slow and retract flaps, stall speed goes UP and you might find yourself in the woods, creek, fence, or whatever is short of the touchdown point. At 13:53 17 May 2008, Tony Verhulst wrote: >user wrote: >> I'd continue to use them interchangeably ..... > > If during a positive control check the pilot corrects your call >> of "spoilers," look under the wing for the extra control surface. > >Yes, I've seen at least 2 books (FAA Glider Flying Handbook and Russell >Holtz's Glider Pilot's Handbook of Aeronautical Knowledge)where the >writer claimed that if the ..um.. "device".. extended top surface only >it was a spoiler and if it extended from both survaces it was an air >brake. Seems dubious to me. > >Tony V LS6-b "6N" > |
Spoilers, no spoilers? | Amine | Piloting | 39 | February 14th 08 02:37 AM |
spoilers vs. ailerons | [email protected] | Piloting | 36 | August 8th 05 11:24 AM |
Airbrakes Pop Out at 115 kts | ContestID67 | Soaring | 13 | May 10th 05 01:50 PM |
ASW19b best descent rate on approach (full airbrakes) | Robert Sharpe | Soaring | 1 | April 30th 05 11:41 AM |
L-13 Spoilers | Scott | Soaring | 2 | August 27th 03 06:08 AM |
