Bertie the Bunyip writes:
And i fly instruments almost every day. How do you fly instruments that don't work? |
Dave Doe writes:
IIRC, they could have used the GPS for airspeed (IIRC, the airspeed indicator partly worked (they got an airspeed active out of it!) - and probably thought it was correct - during flight it was all over the place IIRC. And the radar altimeter would have been working just fine. Several navs would have been good, VOR, DME, ILS etc. Shaker of course too! The GPS would only give ground speed, not airspeed, but that would be better than nothing. The RA would only be useful below 2500 feet AGL. But the other stuff would be working. Anyone remember some more details? Aeroperu had a problem with this. |
Dave Doe wrote in
. nz: In article , says... Dave Doe writes: IIRC, they could have used the GPS for airspeed (IIRC, the airspeed indicator partly worked (they got an airspeed active out of it!) - and probably thought it was correct - during flight it was all over the place IIRC. And the radar altimeter would have been working just fine. Several navs would have been good, VOR, DME, ILS etc. Shaker of course too! The GPS would only give ground speed, not airspeed, but that would be better than nothing. The RA would only be useful below 2500 feet AGL. But the other stuff would be working. The other poster got it right methinks, pretty sure it was a 757. re your reply... * ground speed would be just fine, even in a 30kt wind aloft - compared to an airspeed indicator going all over the place. * they'd just taken off, so the radar altimeter's going to provide some very useful info. Anyone remember some more details? Aeroperu had a problem with this. As the other poster mentioned, he thought it was 'down south' too - should be a database entry for it somewhere. There is an entry in the NTSB data base, but all it does is refer to the DGTA in Peru and gives a telephone number and fax number. The entry can be found at http://www.ntsb.gov/ntsb/brief.asp?e...08X06864&key=1 -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
![]() "Dave Doe" wrote Who remembers the crash in the States where an aircraft engineer had left the pitot and or static air vents taped up. Crashed into the sea I think - all dead. Duncan I believe this was South or Latin America, and the plane came back from getting washed??? Ports still covered to prevent water infiltration. Was it a B757 maybe??? |
DC-3 parts to give away | Robert Little | Restoration | 2 | November 23rd 06 03:30 AM |
Who can give a checkout? | Mark S Conway | General Aviation | 2 | May 9th 05 12:15 AM |
Winch give-away | KP | Soaring | 6 | January 11th 05 08:04 PM |
Did you ever give up on an IR? | No Such User | Piloting | 24 | November 26th 03 02:45 PM |
FS 2004 give away | Ozzie M | Simulators | 0 | November 23rd 03 03:50 PM |
