Mylar seals for elevator
Old May 20th 08, 04:17 PM posted to rec.aviation.soaring
Eric Greenwell
Default Mylar seals for elevator
On May 20, 6:39 am, Ed Winchester wrote:
nimbusgb wrote:
On May 20, 2:25 am, "Bob Salvo" wrote:
It seems to me that Mylar may only be necessary on the top of the
stab/elevator, since the top surface is the high pressure side. Has anyone
tried this?
The top side is the low pressure side Bob!
I don't think so, as the tail of just about every airplane or glider has
a download. That's how they achieve stability. So it's backward at the
tail, the top surface is indeed the high-pressure side.
Just to add to this "pressure" discussion, my elevator has a shape
similar to the trailing edge of my wing. The top-side is convex, and
the bottom-side is concave. Wouldn't that be a clue as to where the
high and low pressure areas are? I would think the convex side is the
low-pressure side, which is on top.
It's an airworthiness requirement that the glider will tend to pull out
of a dive. So, typically, the concave side is on the bottom to provide
increasing back pressure on the stick as speed increases (sort of like a
trim tab). In his 1989 article on increasing performance, Peter Masak
talked about reducing drag by filling in this bottom concavity. No
mention of the expected drag savings, but lots of words about flutter
concerns.
* Updated! "Transponders in Sailplanes"
http://tinyurl.com/y739x4
* New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more
Mylar seals for PIK20D culverflyer Soaring 5 May 19th 04 06:25 PM
Mylar seals installation John W Soaring 2 May 5th 04 09:03 PM
mylar seals wing to flap/ Aileron culverflyer Soaring 2 May 5th 04 02:52 PM
ZZ Mylar seals Mike Soaring 3 March 29th 04 03:45 PM
mylar seals D.A.L Soaring 1 February 23rd 04 07:15 PM
