Mylar seals for elevator
Old May 22nd 08, 05:57 PM posted to rec.aviation.soaring
Darryl Ramm
Default Mylar seals for elevator
On May 21, 6:00 pm, Rick Walters wrote:
At 19:09 21 May 2008, Darryl Ramm wrote:On May 20, 12:14 pm, JJ Sinclair wrote:
On May 20, 7:41 am, Andreas Maurer wrote:
Darryl,
The ship was a Ventus A and the bail out occured while flying out of
Uvalde.
The glider received very little damage. Apparently the gear was down and
the gear "cage" took most of the impact. I owned it for a while but it
has
been passed on to someone else. It has not flown since the accident.
Ron Tabery had a similar problem in NZ flying his N3. He landed OK but
with very marginal elevator control. A good item to put on a checklist.
Rick Walters
Hi JJ
Is it true that the ship later floated back, falling leaf style, by
itself to earth with some significant damage but was later repaired?
Darryl
I always wondered as well about something that happened to me. I was
flying my DG-303 out of Parowan and I landed and then noticed shreds
of the top surface elevator transition tape handing from the
tailplane. The underlying mylar was perfectly OK. so I just cleaned
off and reapplied the transition tape. All I recall that happened on
that flight was I was rained on a little in some virga - and there
were some very small hail pellets. I was up to 18,000' on that flight
and with full ballast, but never really fast. There was not a mark
elsewhere and the aileron transition tapes were fine. The transition
tapes were in mint condition, the glider never spent time tied down in
the sun etc. I though it was strange and asked around and an ASW-27
had exactly the same thing happen to his glider as well on the same
day and if I recall correctly had also flown through some virga/light
rain.
So is this a known thing - maybe small hail pellets will take off the
transition tape? Why only the elevator tape?
Darryl
Mylar seals for PIK20D culverflyer Soaring 5 May 19th 04 06:25 PM
Mylar seals installation John W Soaring 2 May 5th 04 09:03 PM
mylar seals wing to flap/ Aileron culverflyer Soaring 2 May 5th 04 02:52 PM
ZZ Mylar seals Mike Soaring 3 March 29th 04 03:45 PM
mylar seals D.A.L Soaring 1 February 23rd 04 07:15 PM
