Mxsmanic , IFR sensations, and some other stuff
Old May 23rd 08, 08:59 PM posted to rec.aviation.piloting,rec.aviation.student
Default Mxsmanic , IFR sensations, and some other stuff
On May 22, 1:08 pm, Mxsmanic wrote:
writes:
What about rocket propulsion in a vacuum? How does that work?
Simple action and reaction.
Mmmm...but your action has nothing to react against, there's nothing
to push down on like you said with downwash producing lift for an
airplane wing.
Old May 22nd 08, 02:20 PM posted to rec.aviation.piloting,rec.aviation.student
Stealth Pilot[_2_]
On Wed, 21 May 2008 19:56:35 +0200, Mxsmanic
Stealth Pilot writes:
aeroplanes fly because of lift generated by pressure differences on
the wing surfaces.
Airplanes fly because the wings divert the air through which they pass
downwards, creating a downwash and exerting a force in doing so that engenders
an opposite force that is lift.
... these pressure differences are caused by the shape
of the aerofoil of the wing ...
The air is diverted because the wing has a positve angle of attack. It can be
perfectly flat and it will still generate lift.
downwash occurs after the wing has passed. how does it transmit its
effect to the wing? magnetism?
Old May 22nd 08, 06:40 PM posted to rec.aviation.piloting,rec.aviation.student
On May 22, 8:20 am, Stealth Pilot
the wing surfaces.
Sorta. The girl lift fairies push from underneath whilst the boy lift
fairies pull from up top. The obese lift fairies just hang on and
thus produce drag.
Old May 22nd 08, 09:31 PM posted to rec.aviation.piloting,rec.aviation.student
More_Flaps
Sorta. *The girl lift fairies push from underneath whilst the boy lift
fairies pull from up top. *The obese lift fairies just hang on and
thus produce drag.
EXACTLY! *GOD, somebody FINALLY nailed it. *The ones that can't hang on
slam into the elevator and produce downwash.
Noooooooooo! It's the beating of the farie wings that makes downwash!
What do you think anables them to keep the wing up. Really, the
knowledge of simple airyfairey dynamics here is abysmal.
Cheers
Old May 22nd 08, 09:22 PM posted to rec.aviation.piloting,rec.aviation.student
More_Flaps
the wing surfaces.
The air is diverted because the wing has a positve angle of attack. *It can be
thus produce drag.- Hide quoted text -
No, there are no fat faries -fat faries would not be able to fly and
they would die. It's transvestite fairies that produce drag,
Cheers
Old May 22nd 08, 10:00 PM posted to rec.aviation.piloting,rec.aviation.student
george
Must be that built in parasite drag :-)
Old May 22nd 08, 07:13 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Downwash is the result of the wing's passing. The wing accelerates air above
it downwards. That downward movement continues after the wing has passed, and
it is called downwash. It is the acceleration that produces the downwash that
is responsible for lift.
Old May 23rd 08, 12:27 PM posted to rec.aviation.piloting,rec.aviation.student
Stealth Pilot[_2_]
On Thu, 22 May 2008 20:13:44 +0200, Mxsmanic
no.
what pushes the aeroplane up into the air is the pressure differences
at the surface of the wing.
the whole purpose of the rest of it is to create those pressure
differences *at the surface*.
a wingtip vortex is an example of pressure differences not at the
surface and those just cause drag.
keep at it son. one day it is sure to sink in.
Stealth Pilot
Apology re mxsmanic terry Piloting 96 February 16th 08 05:17 PM
I saw Mxsmanic on TV Clear Prop Piloting 8 February 14th 07 01:18 AM
Mxsmanic gwengler Piloting 30 January 11th 07 03:42 AM
Getting rid of MXSMANIC [email protected] Piloting 33 December 8th 06 11:26 PM
Feeling aircraft sensations Ramapriya Piloting 17 January 12th 06 10:15 AM
