Mxsmanic , IFR sensations, and some other stuff
Old May 23rd 08, 01:46 AM posted to rec.aviation.piloting
Default Mxsmanic , IFR sensations, and some other stuff
On May 22, 5:36 pm, Some Other Guy wrote:
BDS wrote:
There is an interesting article in Flying magazine by Peter Garrison that
talks about lift theory.
I thought that one of the most interesting points he made was that the
lift force generated by an airfoil is greater at the optimum angle of
attack than would be the force imparted to it if you were to move it
through the air perpendicular to the air flow at the same speed.
I first experienced this as a kid, sticking my hand out the car window with
the thumb as a leading edge, forming a crude airfoil.
When at the right shape and angle of attack, the lift is amazingly strong.
I always found it remarkable that when my hand was completely
perpendicular to the wind, the force didn't seem as strong.
Definitely a visceral lesson in lifting versus stalling.
I have a copy of that article here. Very, very good. The
coefficient of lift, as he described it, was a ratio related to the
lift generated by a unit area of wing compared to the flat-plate drag
created by the same unit area perpendicular to the airflow. The Wright
brothers did this in their wind tunnel, so they were able to develop
efficient airfoils. A common airfoil (NACA 23012, IIRC) has a max lift
coefficient of 1.8 , which means that it generates 1.8 times the lift
as the drag of the perpendicular surface of the same area.
He made things really clear when he pointed out that this is why
boats and ships no longer use paddlewheels. The wheel will produce
forward thrust equivalent to the power required to force the paddle
back through the water, while the propeller (they call it a "screw")
will produce much more forward thrust for the same torque required by
the paddlewheel.
So it's a process to cause the air to exert a force in a
direction perpendicular to the airflow. It fools the air, if you like,
which is why we call it an "air foil." A foil is a device to deceive.
Bernoulli is right, and so is Newton. There's a pressure
difference because of the difference in airspeeds between top and
bottom, and there's a movement of air downward to which there's an
upward reaction. The equal-transit time theory is bogus, since the
airfoil is much more efficient than that theory would imply. See this
page:
http://www.av8n.com/how/htm/airfoils.html
And, again, Mxmanic has declared, for about the 12th time, that
positive AOA is necessary for lift. If this was so, and it isn't, and
he has been shown many times that it isn't, then airfoils like the
Clark Y wouldn't generate lift at AOAs as low as -4 degrees. That's
negative 4 degrees, airfoil chord pointing downward. A graph can be
found a third of the way down this page: http://lpmpjogja.diknas.go.id/kc/a/air/airplane.htm
That page also deals properly with both Newton and Bernoulli.
Dan
Old May 23rd 08, 10:56 AM posted to rec.aviation.piloting
More_Flaps
On May 23, 12:46*pm, wrote:
* * * So it's a process to cause the air to exert a force in a
Nonsense, the derivation is from a blade or leaf.
Cheers
Old May 23rd 08, 03:21 PM posted to rec.aviation.piloting
Tina
Foiled again!
Cheers
Old May 23rd 08, 02:52 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
wrote in
Garrison that talks about lift theory.
the lift force generated by an airfoil is greater at the optimum
angle of attack than would be the force imparted to it if you were
to move it through the air perpendicular to the air flow at the
same speed.
window with the thumb as a leading edge, forming a crude airfoil.
strong. I always found it remarkable that when my hand was completely
the paddlewheel.
Actually it's a synonym for blade.
page:
Good link but I think he kind of munged up the lift/drag thing as being
seperate entities, when they're inextricably linked. IOW you create lift
and drag is a by product. Not to say, BTW, that the correlation is
rigid!
Bertie
Old May 23rd 08, 03:48 PM posted to rec.aviation.piloting
Maxwell[_2_]
"Bertie the Bunyip" wrote in message
rigid!
Bertie
Where did you read that dumb ass, ya got a link?
Old May 23rd 08, 04:41 PM posted to rec.aviation.piloting,alt.usenet.kooks
Bertie the Bunyip[_25_]
"Maxwell" luv2^fly99@cox.^net wrote in news:aPAZj.2623$7k1.2040
@newsfe24.lga:
being
lift
rigid!
Bertie
Nope, I know it.
Bertie
Old May 23rd 08, 03:59 PM posted to rec.aviation.piloting
On May 23, 7:52 am, Bertie the Bunyip wrote:
wrote i
Not quite. From the Merriam-Webster Dictionary:
Foil:
1 obsolete : trample
2 a: to prevent from attaining an end : defeat always able to foil
her enemies b: to bring to naught : thwart (foiled the plot)
synonyms: see frustrate.
So my "deceive" is much less accurate than "frustrate."
Your definiton matches one of the the Cambridge Dictionary's
definitions:
foil (SWORD) gatiful
noun [C]
a thin light sword used in the sport of fencing
Dan
Old May 23rd 08, 04:53 PM posted to rec.aviation.piloting
wrote in news:380a3b72-e9e1-4b9f-86a5-
wrote i
Foil:
That definition isn't relevant to this application, though.
definitions:
noun [C]
More relevant, I suppose, but that definition is dervied from leaf or blade
as well. Foil as in thwart and foil as in blade have two completely
different origins, from waht I've been able to find...
http://www.thefreedictionary.com/foil
So I'd say arfoil was not used becasue of it's ability to frustrate air (
engineers just don't think like that, they seek harmony) but more because
of their resemblance to a leaf or blade.
Actually, the one in that link that stands out is the architectural one.
Bertie
Old May 23rd 08, 08:40 PM posted to rec.aviation.piloting
More_Flaps
wrote i
* * Foil:
* * * So my "deceive" is much less accurate than "frustrate."
* * * *Your definiton matches one of the the Cambridge Dictionary's
definitions:
If you look a bit further in the MW disctionary you will see both
blade and keaf. But the key is to use a proper dictionary like the
OED. Your definition of foil is a verb, not a noun and an aerofoil or
air foil is a noun.
Cheers
Old May 24th 08, 03:11 PM posted to rec.aviation.piloting
Maxwell[_2_]
rigid!
Bertie
Posted by a forger.
Apology re mxsmanic terry Piloting 96 February 16th 08 05:17 PM
I saw Mxsmanic on TV Clear Prop Piloting 8 February 14th 07 01:18 AM
Mxsmanic gwengler Piloting 30 January 11th 07 03:42 AM
Getting rid of MXSMANIC [email protected] Piloting 33 December 8th 06 11:26 PM
Feeling aircraft sensations Ramapriya Piloting 17 January 12th 06 10:15 AM
