SHOUT LOUDER
;-)) At 19:23 26 May 2008, Bill Daniels wrote: "Ralph Jones" wrote in message .. . On Sun, 25 May 2008 17:57:22 -0700 (PDT), Brad wrote: My buddies tell me my handheld is too painfull to listen to anymore. I would put in a panel mount, but since I have a mostly carbon aircraft, where should I put the antenna? Too late to install it in the rudder, or is there a solution that would allow me to install one in the rudder?? I think the main issue with the handheld, is line-of-sight from the antenna to who I am talking to, it works fine when the aircraft is pointing towards them, or they are on the side of the glider the radio is on, but as I turn (while thermalling) I am told the transmissions cut out. I've seen a few ships that had a small whip antenna mounted on the gear door. With the gear down, of course, the antenna was horizontal, and if mounted close to the hinge line, it was high enough not to get ground damage on most fields. But that won't work if you trailer your ship with the gear up... rj Hmm, well, if you mounted a BNC thru-bulkhead connector on the gear door, and the antenna had a mating BNC connector, it could br removed for trailering. That said, antenna wires have a LOT of drag so maybe a rubber duckie.... Bill D |
| Thread Tools | |
| Display Modes | |
| Aviation Dilemma 101 - How much trust in a 10 day forecast?? | Kyle Boatright | Piloting | 25 | July 22nd 06 01:52 PM |
| More on Fuel Management - and an Ethical Dilemma | Greg Farris | Instrument Flight Rules | 46 | July 22nd 05 07:38 PM |
| More on Fuel Management - and an Ethical Dilemma | Greg Farris | Piloting | 47 | July 22nd 05 07:38 PM |
| Briefing Dilemma | Kyle Boatright | Piloting | 15 | February 7th 05 08:10 PM |
| Small dilemma...YES, this is true.... | Halen19717 | Piloting | 12 | December 2nd 04 02:12 PM |
