What Radio Should I Pick????
Old May 30th 08, 08:08 PM posted to rec.aviation.owning
Jim Stewart
Default What Radio Should I Pick????
Charles Talleyrand wrote:
I have a KX-170 that's *sometimes* just not working right in my VFR
Cessna 150.
For the same price (about $1,300) I could get either
A McCoy MAC-1700 as a slide in replacement for the 170b
-or-
An Icom 200 as an additional radio (with the flaky KX170b as backup).
You can get an A210 for $1100 at Pacific Coast Avionics.
I have one and I love it. 2 channel receive, one button
121.5, built in 2 place intercom and an absolutely wonderful
big bright display.
Any recommendations?
-Charles Talleyrand
P.S. I did look into www.kx170.com. But he does not give yellow tags
with his repair and chooses not to be certified, so I don't think I
can go that way.
Old May 31st 08, 02:16 PM posted to rec.aviation.owning
Dave[_5_]
Cessna 150.
* -or-
-Charles Talleyrand
P.S. *I did look intowww.kx170.com. *But he does not give yellow tags
can go that way.
There is a guy who advertises a flat-rate exchange for KX170s on eBay
for $199. He has a current listing - check it out (he is user
stainless004). I don't think he is the same as www.kx170.com, but
can't be sure (the link didn't work for me).
Like others have said, make sure you don't have a contact problem with
the mounting tray first. I would take the radio out and spray it's
connector and the receptacle in the tray with contact cleaner as a
first step (been there, done that).
Dave
Old May 31st 08, 03:48 PM posted to rec.aviation.owning
Denny
The TKM MX-170B slide in replacement for KX-170 is hands down the
winner... I've got a pair and and they work like gangbusters...
denny
Old June 1st 08, 05:38 AM posted to rec.aviation.owning
Dave S
Cessna 150.
-or-
-Charles Talleyrand
can go that way.
Email me privately... ignore the spam blocker - I will get it within 24
hours anyways.
I've got a 170 sitting in the hangar thats unused and will remain
unused, and was going back on Ebay when i got around to it.
I've xmitted with it once with a bench and temp antenna.
I got it for less than 400, will let it go for same (I will get the
exact price). If you want it.
Also have a KY 196 sitting in there (essentially a flip flop 170 com
only no nav - uses the same harness/rack.
Are you ABSOLUTELY sure the problem is the radio, and not a loose wire
in the harness/rack? A slide in replacement will function intermittently
if the problem is the rack and not the box.
Dave
KEFD
Houston area, Texas
Old June 1st 08, 05:49 AM posted to rec.aviation.owning
Dave S
Cessna 150.
-or-
-Charles Talleyrand
can go that way.
hours anyways.
Dave
KEFD
Houston area, Texas
I was mistaken...
the radios are..
King KX 175B Nav/Com 14V US $460.00
King KY 195B Dual Com TSO 14V US $255.00
Those were my costs on ebay several years ago before shipping. Will part
with for same price plus shipping of your choice. Stale yellow tags on
both. Have transmitted and rec'd with both (com only, havent checked
nav) on a bench with a mag mount antenna.
Sorry for the inaccuracy above in the original post. If you need a
guarantee, I can perhaps ask Jay, 601, Robert Gary or one of the other
long time regulars here to be an intermediary and hold a check until you
know it works for you.
Of course, this is simply replacing your old box with another old box,
rather than upgrading.
If you are upgrading, all I can say is the Icom is not a bad deal at
all... I'm not disappointed with their Ham gear at all, and havent heard
anything bad about their aviation gear.
Dave
Old June 2nd 08, 04:18 PM posted to rec.aviation.owning
RST Engineering
That has got to be the most foolish reason I've ever heard for not getting a
radio repaired. If you want a new radio, just say you want a new radio.
The only thing a yellow tag is good for is a rather small and ineffective
fire starter.
"It is the mark of an educated mind to be able to entertain a thought
without accepting it."
--Aristotle
can go that way.
Old June 2nd 08, 04:26 PM posted to rec.aviation.owning
Howard
Perhaps
But what are the regulatory/legal implications of say flying IFR with a
"repaired" but not yellow tagged Nav/Com?
Howard
"RST Engineering" wrote in message
a radio repaired. If you want a new radio, just say you want a new radio.
fire starter.
--Aristotle
can go that way.
Old June 2nd 08, 04:39 PM posted to rec.aviation.owning
RST Engineering
None whatsoever.
--Aristotle
"Howard" wrote in message
Perhaps
Howard
Old June 3rd 08, 08:22 PM posted to rec.aviation.owning
Newps
Howard wrote:
Perhaps
The installing mechanic is always the one who determines whether a radio
is airworthy or not. Always. A yellow tag literally means nothing.
pick your poison on tow [email protected] Soaring 8 April 1st 06 07:42 AM
Chuck Slusarczyk please pick up the white courtesy phone... Richard Lamb Home Built 8 February 13th 06 12:58 PM
Where to pick up passengers at HPN? Roberto Waltman Piloting 8 August 22nd 04 05:52 PM
Thanks for your opinions - Going to pick up plane tomorrow!! Larryskydives Owning 0 February 13th 04 04:44 AM
Air Force asking some NCOs to pick new fields Otis Willie Military Aviation 0 January 27th 04 12:57 AM
