On Sat, 22 Nov 2008 17:29:37 -0500, Michael Horowitz
wrote: On Sun, 01 Jun 2008 22:05:40 +0800, Stealth Pilot wrote: Stealth - Can you think of any way to tint the turp/oil mix? when it comes time to remove it, it would help if I could see that I got it all off (assuming I use a solvent of some type) - Mike just use any brightly coloured powdered dye. what you have in the linseed oil/turps mix is a poor mans varnish without any of the modern additives. a finely crushed bricklayer's iron oxide red would probably be suitable. but ummmm. isnt the surface a dark rusted colour anyway. when you come to prepare for the final finishing you will be bead blasting the thing with ballottini (glass beads) and these should take the linseed off in a trice. the surface will become a light gunmetal gray colour (unless your air supply isnt dry) I'm pretty sure a wipe of MEK would do it as well, maybe even neat turps but dont agonise over it now wait until the final bead blast. I actually dont know what happened to the fuselage I coated. it is on the other side of australia now. Stealth Pilot |
On Sun, 23 Nov 2008 20:41:51 +0900, Stealth Pilot
wrote: On Sat, 22 Nov 2008 17:29:37 -0500, Michael Horowitz wrote: On Sun, 01 Jun 2008 22:05:40 +0800, Stealth Pilot wrote: but ummmm. isnt the surface a dark rusted colour anyway. Stealth Pilot Stealth - recall that what I'm doing is sandblasting/wirebrushing a small section at a time and coming back to it a month later to do another small section. The turp/oil mix is to protect the surface until the whole fuselage is blasted/brushed at which time I'll remove the turp/oil mix and apply (probably) two part epoxy. So to answer your query, after blasting/brushing, no, it will be frosty steel color - Mike |
On Sun, 23 Nov 2008 07:47:33 -0500, Michael Horowitz
wrote: On Sun, 23 Nov 2008 20:41:51 +0900, Stealth Pilot wrote: On Sat, 22 Nov 2008 17:29:37 -0500, Michael Horowitz wrote: On Sun, 01 Jun 2008 22:05:40 +0800, Stealth Pilot wrote: but ummmm. isnt the surface a dark rusted colour anyway. Stealth Pilot Stealth - recall that what I'm doing is sandblasting/wirebrushing a small section at a time and coming back to it a month later to do another small section. The turp/oil mix is to protect the surface until the whole fuselage is blasted/brushed at which time I'll remove the turp/oil mix and apply (probably) two part epoxy. So to answer your query, after blasting/brushing, no, it will be frosty steel color - Mike Use a light wash of cheap rust paint. Aluminum TremClad will wash off with thinners or gasoline even after several years.Colours are not much better. Mix it with your Turps/linseed if you like |
Stealth - recall that what I'm doing is sandblasting/wirebrushing a small section at a time and coming back to it a month later to do another small section. The turp/oil mix is to protect the surface until the whole fuselage is blasted/brushed at which time I'll remove the turp/oil mix and apply (probably) two part epoxy. So to answer your query, after blasting/brushing, no, it will be frosty steel color - Mike If you're blasting a small section at a time, why don't you just prime it as you go along, then touch it up when it's done? The paint will stick a lot better to freshly blasted metal and you'll save yourself a lot of work. -- John Kimmel I think it will be quiet around here now. So long. |
![]() "Stealth Pilot" wrote I actually dont know what happened to the fuselage I coated. it is on the other side of australia now. Sounds like you need to go on a walkabout, and see how it's doin, mate! ducking and grinning -- Jim in NC |
Looking for a fuselage | Jay Honeck | Home Built | 79 | March 7th 05 01:42 PM |
Bare Bones X-C | Cub Driver | Piloting | 3 | August 3rd 04 09:17 AM |
Brand New Bell 47 Spider Still Packed in Cosmoline ---- What's It Worth? | Larry Smith | Rotorcraft | 1 | December 25th 03 12:45 PM |
Preserved Asso 500 engines - pictures | Vicente Vazquez | Restoration | 0 | November 21st 03 07:20 PM |
