Ram air
Old June 6th 08, 03:47 PM posted to rec.aviation.piloting,alt.alien.vampire.flonk.flonk.flonk,alt.usenet.kooks
cavedweller
Default Ram air
On Jun 6, 10:21 am, Bertie the Bunyip wrote:
cavedweller wrote in news:ecad1ae9-5348-4dfc-b881-
On Jun 5, 11:21 am, Bertie the Bunyip wrote:
Actually, "Foo" came from Smokey Stover, and was a corruption of the
french "feux" ( Smokey was a fireman) He called himself a "Foo fighter"
and juxtaposed with the term UFO (which at the beginning of it's life
just meant anything that pilots couldn't identify and had nothing to do
with little gray men) a UFO became a foo fighter to USAAC pilots in WW2.
While I'm sure the Forward Observation Officer thing is also true,
Smokey Stover was really popular at the time and was the source of a
large number of slang words used during the war.
I always loved his car!
Bertie
Notary Sojac (from memory...not Googled)
Oh yeah! Have no idea what that meant! I looked up his website a few years
back for some reason. He had loads of weird sayings that probably meant
something or another to older guys of the WW2 generation. He almost
certainly decorated a few airplanes in WW2 as well..
Bertie
There IS a Wiki article. Bring back Pogo, too.
Old June 6th 08, 04:08 PM posted to rec.aviation.piloting,alt.alien.vampire.flonk.flonk.flonk,alt.usenet.kooks
Bertie the Bunyip[_25_]
Default Ram air
the french "feux" ( Smokey was a fireman) He called himself a "Foo
fighter" and juxtaposed with the term UFO (which at the beginning
of it's life just meant anything that pilots couldn't identify and
had nothing to do with little gray men) a UFO became a foo fighter
to USAAC pilots in WW2. While I'm sure the Forward Observation
Officer thing is also true, Smokey Stover was really popular at
the time and was the source of a large number of slang words used
during the war. I always loved his car!
Bertie
years back for some reason. He had loads of weird sayings that
probably meant something or another to older guys of the WW2
generation. He almost certainly decorated a few airplanes in WW2 as
well..
Bertie
Pogo, I never got into. It was one of the few, along with Mary Worth and
Mandrake, I skipped. B.C, the Wizard of Id, Moon Mullins, Dick Tracy. It
was, by far, always the most intelligent part of any newspaper..
Old June 5th 08, 05:37 PM posted to rec.aviation.piloting,alt.alien.vampire.flonk.flonk.flonk
mixed nuts
Default Ram air
Stealth Pilot wrote:
On Tue, 03 Jun 2008 13:17:17 -0400, mixed nuts
On Mon, 02 Jun 2008 19:51:47 -0400, dave hillstrom
On Mon, 2 Jun 2008 14:12:26 -0700 (PDT), Tony
Ram air is only as useful the allowing air to get to your carburater
faster but is not necessarily used. When your piston is on its intake
stroke(vaccum) your combustion chamber can only draw in enough air
that is in conjuction to the chambers volume and all other air that is
present after the compression stroke is exported to engines smog
devices and is recirculated only AFTER being filtered. All engines
come off the assembly lines, be it an airplane motor or a vehicle
motor, to draw the amount of air that it needs to run at opptimum
performance. Ram Air is a myth and don't try to throw "turbo" into
the conversation because turbo is recircualted exhaust and still has
unburnt fuel in the fumes.
I think you are quite wrong. Ram air in fact gives us a half inch or
so more manifold pressure, and that increases the total weight of the
air-fuel mixture in the cylinder. Reduce your 'it doesn't matter
argument to an extreme to see how it fails.
As for turbos, the turbine is powered by the exhaust gasses coming
from the engine, the exhaust gas itself is not reintroduced into the
cylinders. The turbine itself could be powered by an electric motor,
for that matter. That was the model for my tongue in cheek comment
about using a shop vac to increase manifold pressure.
will you marry me?
dave the term is not foo and bar.
foo *is* a term from another war and another airforce
but the term you've so successfully stuffed up is fubar
fubar is a vietnam era acronym of F***ed up beyond all recognition.
your sig line is a snafu
(situation normal all F***ed up)
Yore 'rong. foo and bar are metasyntactic variables. They aren't
acronyms (they're metasyntactic variables).
Like being the John and Jane Doe of computer engineering - placeholders.
Fubar predates WWII.
dont agree.
foo for instance is a quite infamous cartoon of a guy peeping over a
fence with the line 'foo was here'
foo is the 'forward observation officer' the guy who used to tootle
over the lines in an auster or a cub spotting for artillery and
fighters. verrah verrah british ol' chap. verrah verrah courageous
flying too boot.
You really have no choice in this matter. foo and bar have a formal
place in computer science and appear regularly in a large number of
RFCs as well as in the scientific literature. If you, or anywon else
choose to us these terms in any other context, feel free to do so but,
unless yore a computer geek describing algorithms in pseudo-code and
contributing new and more wonderful metasyntactic variables to the
pool (see reesent psot sigs by won Daev Hillstorm) don't go peeing on
our carpet.
nuts
Old June 5th 08, 05:38 PM posted to rec.aviation.piloting,alt.alien.vampire.flonk.flonk.flonk
Default Ram air
Stealth Pilot wrote in
carburater faster but is not necessarily used. When your piston is
on its intake stroke(vaccum) your combustion chamber can only draw
in enough air that is in conjuction to the chambers volume and all
other air that is present after the compression stroke is exported
to engines smog devices and is recirculated only AFTER being
filtered. All engines come off the assembly lines, be it an
airplane motor or a vehicle motor, to draw the amount of air that
it needs to run at opptimum performance. Ram Air is a myth and
don't try to throw "turbo" into the conversation because turbo is
recircualted exhaust and still has unburnt fuel in the fumes.
or so more manifold pressure, and that increases the total weight
of the air-fuel mixture in the cylinder. Reduce your 'it doesn't
matter argument to an extreme to see how it fails.
motor, for that matter. That was the model for my tongue in cheek
comment about using a shop vac to increase manifold pressure.
will you marry me?
placeholders.
dont agree.
BY the way, the Foo was here thing was a corruption of th eorignal
Kilroy was here. no idea where that started, but it was everywhere for
years. Foo was here was a minor variation.
Bertie
Old June 6th 08, 11:17 AM posted to rec.aviation.piloting,alt.alien.vampire.flonk.flonk.flonk
Stealth Pilot[_2_]
Default Ram air
On Thu, 5 Jun 2008 16:38:44 +0000 (UTC), Bertie the Bunyip
will you marry me?
placeholders.
dont agree.
Bertie
they are fascinating pieces of folk history so when I find one out it
sticks in the memory.
Kilroy was a government guy pressed into the task of inspecting the
quality of the hastily built cargo ships the americans turned out for
the shipping task to england. he had no way of remembering where he
had previously inspected so he developed the habit of chalking 'Kilroy
was here" to remind himself of sections he had already inspected. the
internal sections were eventually welded into the structure.
weeks later when torpedo damage was being repaired the workers would
cut away sealed parts and find the mysterious chalk marks "Kilroy was
here". the endearing puzzle being how did they get there in sealed
sections?
the mystery was explained a few years ago in a news radio segment
where someone actually tracked down the guy and got him to explain the
riddle.
Stealth ( liberty ships?) Pilot
Old June 6th 08, 03:10 PM posted to rec.aviation.piloting,alt.alien.vampire.flonk.flonk.flonk
Default Ram air
sections?
riddle.
I always wondered where that came from. You'd still see it as graffiti as
late as the 70s. i suppose years form now people will be explaining the
origins of "where's the beef" to the bewilderment of the youngsters who
won't be able to understand why anyone would eat something infected with e-
coli and BSE..
Bertie
