On Jun 9, 10:28*pm, Tina wrote:
Lost and Found Found: To the village that has lost its idiot: we've found him. Ya, 'I'm building an airplane and want to know who the trim works. Also how do I weld it?' ![]() -Robert |
Some students want the first approach, some may want the second - it's
probably 95% to 5%. If you assume they all want the more detailed explanation for everything, you will have frustrated students who either think that flying is too complicated for them to learn, or who quit because they are bored. When I took driver's ed in high school they didn't explain the inner workings of a carburetor, nor did they need to in order for me to be able to learn how to drive. Knowing how a carburetor works and having the ability to tear one down and put it back together again does not make me a better driver. You want to know every detail - fine. You just need to find an instructor who is willing and able to do that for you. As you know, not all of them are nor do they need to be in order to be able to teach you to fly and fly well. I suspect you dispute that fact, but history has already proven you wrong. "Le Chaud Lapin" wrote It is the instructor's choice to determine how deep s/he should delve into the mechanics of flight. One instructor might say, "Move trim wheel up or down to relieve pressure on yoke." Another might say, "Trim wheel is connected to a trim tab on elevator, often located on one side of elevator only, and air moving across elevator results in aerodynamic force vector on tab that acts on elevator to position elevator so that point of equilibrium is reached, and such force being sufficient that you no longer need the yoke to position the elevator. As you can imagine, speed and orientation of aircraft will have some effect on force...and therefore position of elevator. Also, if only one tab, force applies asymetrically to aircraft...etc." |
On Jun 10, 5:04*am, "BDS" wrote:
Some students want the first approach, some may want the second - it's probably 95% to 5%. *If you assume they all want the more detailed explanation for everything, you will have frustrated students who either think that flying is too complicated for them to learn, or who quit because they are bored. There were two extreme examples in my ground school (but not in my class). One had failed written once already, and they other said one day, "Forget learning...if you want to pass the exam, this is best tool you can use: gave me link to web site. It has most of the questions in easy-to-memorize format." I asked them why not just learn what they need to know, at least enough to get a 70...and they both frowned as if I has asked them to learn to change diapers. When I took driver's ed in high school they didn't explain the inner workings of a carburetor, nor did they need to in order for me to be able to learn how to drive. *Knowing how a carburetor works and having the ability to tear one down and put it back together again does not make me a better driver. True. I wouldn't expect explanation of GPS in ground school, or Pascal's principle, etc, but which many situations like this, it doesn't hurt to know. You want to know every detail - fine. *You just need to find an instructor who is willing and able to do that for you. *As you know, not all of them are nor do they need to be in order to be able to teach you to fly and fly well. *I suspect you dispute that fact, but history has already proven you wrong. No, I do not dispute this. I have learned that flying is like many other things. It is very possible to get by using mostly manipulation of that which is presented to you. -Le Chaud Lapin- |
"BDS" wrote in message
... Some students want the first approach, some may want the second - it's probably 95% to 5%. If you assume they all want the more detailed explanation for everything, you will have frustrated students who either think that flying is too complicated for them to learn, or who quit because they are bored. When I took driver's ed in high school they didn't explain the inner workings of a carburetor, nor did they need to in order for me to be able to learn how to drive. Knowing how a carburetor works and having the ability to tear one down and put it back together again does not make me a better driver. You want to know every detail - fine. You just need to find an instructor who is willing and able to do that for you. As you know, not all of them are nor do they need to be in order to be able to teach you to fly and fly well. I suspect you dispute that fact, but history has already proven you wrong. In general, I agree with you--one certainly didn't need to know the inner workings of the carburetor. However, it could be very usefull to understand what the throttle (accelerator) return spring did! That sort of information is in the POH for any aircraft certified under Part 23. OTOH, the answers to the original question posted by the OP might be included over the course of an airframe mechanic's curriculum--or might not. Peter |
Le Chaud Lapin wrote:
MSFS was the means by which I discovered the mechanism. If I had learned in actual aircraft, the question still would have been relevant. -Le Chaud Lapin- You never learned of trim until MSFS and you are going to design an airplane. Fabulous! |
On Jun 9, 1:19*pm, Gig 601Xl Builder
wrote: Le Chaud Lapin wrote: MSFS was the means by which I discovered the mechanism. If I had learned in actual aircraft, the question still would have been relevant. -Le Chaud Lapin- You never learned of trim until MSFS and you are going to design an airplane. Fabulous! Is it really necessary to understand the particular way it was done in C172 to achieve the same result? The same thing could be achieved using more electronics, less mechanics, and the controls might be entirely different. -Le Chaud Lapin- |
On Jun 9, 1:19 pm, Gig 601Xl Builder wrote: Le Chaud Lapin wrote: MSFS was the means by which I discovered the mechanism. If I had learned in actual aircraft, the question still would have been relevant. -Le Chaud Lapin- You never learned of trim until MSFS and you are going to design an airplane. Fabulous! Is it really necessary to understand the particular way it was done in C172 to achieve the same result? The same thing could be achieved using more electronics, less mechanics, and the controls might be entirely different. -Le Chaud Lapin- Not knowing about trim by someone who thinks they are going to design an airplane is like someone who wants to be an electrician and doesn't understand the difference in AC and DC. It's just another example that you have no business trying to design an aircraft. |
On Jun 9, 3:30*pm, Gig 601Xl Builder
wrote: Not knowing about trim by someone who thinks they are going to design an airplane is like someone who wants to be an electrician and doesn't understand the difference in AC and DC. It's just another example that you have no business trying to design an aircraft. This is a false analogy. It depends on what is meant by "knowing about trim". The purpose of trim is clear, and the objective of trim can be achieved in many ways. It is not necessary to know all the ways that the objective of trim can be achieved in order to implement just one mechanism that achieves the objective. -Le Chaud Lapin- |
On Jun 9, 12:36 pm, Le Chaud Lapin wrote:
On Jun 9, 1:19 pm, Gig 601Xl Builder You never learned of trim until MSFS and you are going to design an airplane. Fabulous! Is it really necessary to understand the particular way it was done in C172 to achieve the same result? The same thing could be achieved using more electronics, less mechanics, and the controls might be entirely different. #1. Learn to fly first. #2. Study the construction of aircraft, best done by taking an aircraft maintenance course. #3. THEN think about designing an airplane. No worthwhile design that I'm aware of has ever been put forward by someone who was unfamiliar with the way things are now and why they are that way, but I have seen designs built by folks who "knew better" than everyone else. One of those, built by a local guy who would take no constructive criticism of his ideas, stalled at circuit altitude and dropped him, hard, on the surface of the earth. He was such a stubborn guy that he got up and walked away, but he neither built nor flew any more airplanes. Needless to say, this design was neither inspected nor approved nor licensed to any standard whatever. Adding electronic controls to something like a trim tab on a lightplane is one of those "better" ideas that has no basis in reality. It adds complexity, which adds failure points and cost and weight, none of which are welcome. It is no more accurate than manual trim. Dan |
F-100 detail | Pjmac35 | Aviation Photos | 0 | July 26th 07 10:29 AM |
Finding "Neutral" Position on Piper Elevator/Trim Tab | [email protected] | Owning | 10 | December 7th 06 01:43 PM |
Detail pops in too late in FS2004 | CatharticF1 | Simulators | 0 | August 27th 03 03:25 AM |
