Stealth Pilot writes:
on the contrary it is a hell of a lot of fun. just how long do you think it stays 43 C when you are flying for real? Most of the flight, at moderate altitudes, or at least it stays too hot for most of the flight. My baron has an "air conditioning" switch, but it's not clear whether or not this is the real thing, since the real thing requires a compressor. |
"Mxsmanic" wrote in message
... Stealth Pilot writes: on the contrary it is a hell of a lot of fun. just how long do you think it stays 43 C when you are flying for real? Most of the flight, at moderate altitudes, or at least it stays too hot for most of the flight. My baron has an "air conditioning" switch, but it's not clear whether or not this is the real thing, since the real thing requires a compressor. The "real thing" doesn't necessarily require a compressor. |
Mike writes:
The "real thing" doesn't necessarily require a compressor. So how does it work? |
... Mike writes: The "real thing" doesn't necessarily require a compressor. So how does it work? Some older planes had a non-compressor based system that required water. I assume it was some sort of evaporative cooling setup. I lived in El Paso, Texas where the temps routinely got above 43° C and I had an evaporative cooler in my home that worked just fine. You can also buy aftermarket systems that use ice. |
Mike writes:
Some older planes had a non-compressor based system that required water. I assume it was some sort of evaporative cooling setup. I lived in El Paso, Texas where the temps routinely got above 43° C and I had an evaporative cooler in my home that worked just fine. That would be a swamp cooler rather than true air conditioning. It would work in an aircraft if the humidity were low enough, but the weight of the necessary water sounds like a major drawback. You can also buy aftermarket systems that use ice. Still not true A/C, but better than nothing. I suppose adding a compressor to an engine would raise all sorts of issues with certification, testing, performance, etc. |
In article PTV9k.157$K%2.34@trnddc02, "Mike"
wrote: "Mxsmanic" wrote in message ... Mike writes: The "real thing" doesn't necessarily require a compressor. So how does it work? Some older planes had a non-compressor based system that required water. I assume it was some sort of evaporative cooling setup. I lived in El Paso, Texas where the temps routinely got above 43° C and I had an evaporative cooler in my home that worked just fine. You can also buy aftermarket systems that use ice. There are also state-change systems that just need a heat source to drive them, like Dometic kerosene refrigerators. Not very useful for aircraft use, granted. |
On Jun 29, 7:23 pm, Steve Hix
wrote: In article PTV9k.157$K%2.34@trnddc02, "Mike" wrote: "Mxsmanic" wrote in message .. . Mike writes: The "real thing" doesn't necessarily require a compressor. So how does it work? Some older planes had a non-compressor based system that required water. I assume it was some sort of evaporative cooling setup. I lived in El Paso, Texas where the temps routinely got above 43° C and I had an evaporative cooler in my home that worked just fine. You can also buy aftermarket systems that use ice. There are also state-change systems that just need a heat source to drive them, like Dometic kerosene refrigerators. Not very useful for aircraft use, granted. Turbine engined airplanes don't have AC compressors. They bleed some compressed air from the compressor stage of the engine, run that through an exchanger to cool it, then drop its pressure, which lowers its temperature a whole bunch. Mixing this really cold air with hot bleed air provides whatever temperature the pilot wants. A piston engine with a larger turbocharger could use some of the same effect but it would be less effective since the pressures are lower. Dan |
wrote in message ... On Jun 29, 7:23 pm, Steve Hix wrote: In article PTV9k.157$K%2.34@trnddc02, "Mike" wrote There are also state-change systems that just need a heat source to drive them, like Dometic kerosene refrigerators. Not very useful for aircraft use, granted. Turbine engined airplanes don't have AC compressors. They bleed some compressed air from the compressor stage of the engine, run that through an exchanger to cool it, then drop its pressure, which lowers its temperature a whole bunch. Mixing this really cold air with hot bleed air provides whatever temperature the pilot wants. A piston engine with a larger turbocharger could use some of the same effect but it would be less effective since the pressures are lower. Dan Well...some turbine powered airplanes have AC compressors. The one I flew had one, we used it to pre-cool the cabin and up to 18,000 feet. We also used it as a de-humidifier when going into humid areas so the windshield would not fog up. -- *H. Allen Smith* WACO - We are all here, because we are not all there. |
| Thread Tools | |
| Display Modes | |
| Deadlines to remember | Gilan | Home Built | 5 | July 5th 06 10:28 PM |
| Remember to tip your ... pilot? | Brien K. Meehan | Piloting | 10 | February 4th 06 04:25 PM |
| Remember when? | Billposter | Naval Aviation | 21 | August 22nd 05 10:22 PM |
| Tasha. Anyone remember her? | Mike Anselmo | Naval Aviation | 2 | February 15th 04 04:28 PM |
| And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... | Roy | Piloting | 4 | July 12th 03 05:03 PM |
