#71
Michael Ash wrote: In rec.aviation.student Steve Hix wrote: In article , Michael Ash wrote: At the risk of turning this thread into something useful, Heaven forfend! does anyone have any recommendations as to when it's a good idea to give oxygen to passengers? I'm not talking about the legal requirements, but just when it's the smart thing to do. For example, as the pilot I like to start my oxygen at about 10,000ft even though it's not required until quite a bit higher. But then again, it doesn't really matter too much if my passengers have mildly impaired judgement during the flight, even though I'd really want to avoid that myself. This is really an academic question since I don't plan to take anybody that high to begin with, but I'm curious. Depends on the person, really. Good point! I have a friend who begins to exhibit severe headaches and some cyanosis (his lips and fingernails start to go purple) above about 8000'. He's been warned to be very cautious about higher elevations, as he's probably a prime candidate for mountain sickness. So much for his dreams of trekking the Himalayas. That's a bit extreme, but it's worth watching for if you have a passenger who's never been at altitude before. Heavy smokers, or anyone with compromised cardiopulmonary function should be cautious, probably. Do I correctly understand that you would be happy with monitoring for symptoms during the flight and making the decision then? I don't want to do this as the pilot, but only because judgement is one of the first things to go. For passengers this seems to be entirely reasonable. For passengers, mostly. I've done some testing previously, and have determined that up to at least 11,500' there're no noticeable effects for me. (Modulo fatigue, recovery from illness, etc.) The initial checks I did with another pilot, my instructor at the time, and he brought oxygen along. Over the past several decades, I've been tested for VO2max, and I'm on the high side of the population. I used to cycle competitively, which was initially the reason to check, after that just curiousity. Has to be careful choice of grandparents; I've lived essentially at sea level for my whole life (California coastal, mostly). My son smokes; him I'd want to check if we cross the Sierra Nevada or points east. |
#72
In article PTV9k.157$K%2.34@trnddc02, "Mike"
wrote: "Mxsmanic" wrote in message ... Mike writes: The "real thing" doesn't necessarily require a compressor. So how does it work? Some older planes had a non-compressor based system that required water. I assume it was some sort of evaporative cooling setup. I lived in El Paso, Texas where the temps routinely got above 43° C and I had an evaporative cooler in my home that worked just fine. You can also buy aftermarket systems that use ice. There are also state-change systems that just need a heat source to drive them, like Dometic kerosene refrigerators. Not very useful for aircraft use, granted. |
#73
"Mxsmanic" wrote in message ... muff528 writes: I would extend that thought to include *any* plane :-) High-performance aircraft that can fly well above mountain ranges shouldn't be a problem. Well, wouldn't that be considered "avoiding the mountains"? TP |
#74
muff528 writes:
Well, wouldn't that be considered "avoiding the mountains"? Potentially, yes. |
#75
On Jun 29, 7:23 pm, Steve Hix
wrote: In article PTV9k.157$K%2.34@trnddc02, "Mike" wrote: "Mxsmanic" wrote in message .. . Mike writes: The "real thing" doesn't necessarily require a compressor. So how does it work? Some older planes had a non-compressor based system that required water. I assume it was some sort of evaporative cooling setup. I lived in El Paso, Texas where the temps routinely got above 43° C and I had an evaporative cooler in my home that worked just fine. You can also buy aftermarket systems that use ice. There are also state-change systems that just need a heat source to drive them, like Dometic kerosene refrigerators. Not very useful for aircraft use, granted. Turbine engined airplanes don't have AC compressors. They bleed some compressed air from the compressor stage of the engine, run that through an exchanger to cool it, then drop its pressure, which lowers its temperature a whole bunch. Mixing this really cold air with hot bleed air provides whatever temperature the pilot wants. A piston engine with a larger turbocharger could use some of the same effect but it would be less effective since the pressures are lower. Dan |
#76
#77
In article RgX9k.272$bn3.204@trnddc07,
"muff528" wrote: "Mxsmanic" wrote in message ... muff528 writes: I would extend that thought to include *any* plane :-) High-performance aircraft that can fly well above mountain ranges shouldn't be a problem. Well, wouldn't that be considered "avoiding the mountains"? Only for those thinking in 3D terms. |
#78
Nomen Nescio wrote in
: -----BEGIN PGP SIGNED MESSAGE----- From: Mxsmanic I know, but I prefer not to wait until the law requires it to take precautions. Some people show signs of hypoxia at half that altitude. Why take the risk? Un-F**kin'- Believable! An I the only one picturing the dip****, sitting in front of his computer, shoving a tube up his nose at an "altimeter" reading of 7000 ft? -----BEGIN PGP SIGNATURE----- Version: N/A iQCVAwUBSGhJu5MoscYxZNI5AQGSUQP/TTxpYKPSk0Y1F+v1AqhGet8cZahLiJ5I lE9DD1LQ08E1y2DNaR/kUrpQzcZxAq5AdoRgf7xdleGnf1O1JeAXW0a8oSY0zQGJ mxrw8J1cNPSbHJ/Uz7Qz5DUMdzxRowSegKEntP2fHwoNm41N7yP2gQVhepa3a/wk VCoUwsx8ktE= =VCXH -----END PGP SIGNATURE----- No, you are not alone in your picture. You just left out that he has the other end up his ass so he can fart and pretent he is getting O2. |
#79
wrote in message ... On Jun 29, 7:23 pm, Steve Hix wrote: In article PTV9k.157$K%2.34@trnddc02, "Mike" wrote There are also state-change systems that just need a heat source to drive them, like Dometic kerosene refrigerators. Not very useful for aircraft use, granted. Turbine engined airplanes don't have AC compressors. They bleed some compressed air from the compressor stage of the engine, run that through an exchanger to cool it, then drop its pressure, which lowers its temperature a whole bunch. Mixing this really cold air with hot bleed air provides whatever temperature the pilot wants. A piston engine with a larger turbocharger could use some of the same effect but it would be less effective since the pressures are lower. Dan Well...some turbine powered airplanes have AC compressors. The one I flew had one, we used it to pre-cool the cabin and up to 18,000 feet. We also used it as a de-humidifier when going into humid areas so the windshield would not fog up. -- *H. Allen Smith* WACO - We are all here, because we are not all there. |
#80
| Thread Tools | |
| Display Modes | |
| Deadlines to remember | Gilan | Home Built | 5 | July 5th 06 10:28 PM |
| Remember to tip your ... pilot? | Brien K. Meehan | Piloting | 10 | February 4th 06 04:25 PM |
| Remember when? | Billposter | Naval Aviation | 21 | August 22nd 05 10:22 PM |
| Tasha. Anyone remember her? | Mike Anselmo | Naval Aviation | 2 | February 15th 04 04:28 PM |
| And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... | Roy | Piloting | 4 | July 12th 03 05:03 PM |
