#81
On Sun, 29 Jun 2008 17:38:54 +0200, Mxsmanic
wrote: Stealth Pilot writes: on the contrary it is a hell of a lot of fun. just how long do you think it stays 43 C when you are flying for real? Most of the flight, at moderate altitudes, or at least it stays too hot for most of the flight. My baron has an "air conditioning" switch, but it's not clear whether or not this is the real thing, since the real thing requires a compressor. you truely are an idiot. I fly across the nullabor plain in summer with temperatures on the ground near 45 degrees celcius, my aircraft has no cooling or airconditioning whatsoever and yet I fly in temperatures between 0 degrees and 5 degrees absolutely reliably. can your little brain figure out how I do it. every pilot here can do it. Stealth Pilot |
#82
On Sun, 29 Jun 2008 16:17:47 -0500, Michael Ash
wrote: In rec.aviation.student Mxsmanic wrote: muff528 writes: If that's as high as your airplane will go you probably should get another airplane. At least don't fly around out west where the hills are higher than that. Sometimes even the ground is higher than that! :-) I try to avoid the mountains when flying a small plane. There are some extensive flat areas in the American west, but it is true that sometimes to get between two points it's hard to avoid the mountains, short of crossing half the continent to go around them. Even if the aircraft has the requisite ceiling, carrying oxygen for everyone is awkward and will not inspire confidence in passengers. You don't legally need oxygen for the passengers until 15,000ft, and even the "it's a good idea even though it's not required" range probably isn't until 10,000ft or so. If you start out at sea level, those will get you into nice cool air. At the risk of turning this thread into something useful, does anyone have any recommendations as to when it's a good idea to give oxygen to passengers? I'm not talking about the legal requirements, but just when it's the smart thing to do. For example, as the pilot I like to start my oxygen at about 10,000ft even though it's not required until quite a bit higher. But then again, it doesn't really matter too much if my passengers have mildly impaired judgement during the flight, even though I'd really want to avoid that myself. This is really an academic question since I don't plan to take anybody that high to begin with, but I'm curious. mike it depends entirely on your level of blood oxygenation. go and buy yourself a little device that clips over your finger called a 'Pulse Oximeter'. you can get little battery powered ones. they shine two lasers of different frequencies through your tissue and infer the oxygenation from the ratio of the attenuation. they are quite accurate. if your blood oxygenation drops below 95% you can start up the oygen. the commercial aviation standard of 8,000ft is based on the onset of difficulty that an obese person will have. obesity means increased tissue to perfuse, compared to a normal weight person, with just the same lung surface area. obesity brings on hypoxia earlier. Stealth Pilot |
#83
In rec.aviation.student Steve Hix wrote:
In article , Michael Ash wrote: Do I correctly understand that you would be happy with monitoring for symptoms during the flight and making the decision then? I don't want to do this as the pilot, but only because judgement is one of the first things to go. For passengers this seems to be entirely reasonable. For passengers, mostly. I've done some testing previously, and have determined that up to at least 11,500' there're no noticeable effects for me. (Modulo fatigue, recovery from illness, etc.) The initial checks I did with another pilot, my instructor at the time, and he brought oxygen along. Over the past several decades, I've been tested for VO2max, and I'm on the high side of the population. I used to cycle competitively, which was initially the reason to check, after that just curiousity. Has to be careful choice of grandparents; I've lived essentially at sea level for my whole life (California coastal, mostly). My son smokes; him I'd want to check if we cross the Sierra Nevada or points east. Thanks for the additional details, very interesting. It's particularly interesting that you say you're on the high side of the population and yet you still seem to come in well below the FAA requirements for passenger oxygen. I guess this is one case where they don't err heavily on the side of caution. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
#84
"Mxsmanic" wrote in message
... What are the main things I have to give special consideration to when preparing to fly in very hot weather (43° C)? If you don't know the answer to this question, you should not be flying. If you are playing with MSFS (as I suspect) you should ask this question on a group that has members familiar with how Microsoft simulates atmospheric conditions. HTH |
#85
Michael Ash wrote: In rec.aviation.student Steve Hix wrote: In article , Michael Ash wrote: Do I correctly understand that you would be happy with monitoring for symptoms during the flight and making the decision then? I don't want to do this as the pilot, but only because judgement is one of the first things to go. For passengers this seems to be entirely reasonable. For passengers, mostly. I've done some testing previously, and have determined that up to at least 11,500' there're no noticeable effects for me. (Modulo fatigue, recovery from illness, etc.) The initial checks I did with another pilot, my instructor at the time, and he brought oxygen along. Over the past several decades, I've been tested for VO2max, and I'm on the high side of the population. I used to cycle competitively, which was initially the reason to check, after that just curiousity. Has to be careful choice of grandparents; I've lived essentially at sea level for my whole life (California coastal, mostly). My son smokes; him I'd want to check if we cross the Sierra Nevada or points east. Thanks for the additional details, very interesting. It's particularly interesting that you say you're on the high side of the population and yet you still seem to come in well below the FAA requirements for passenger oxygen. ?? Something got scrambled in translation... If it wasn't clear, I didn't resort to oxygen, we just had it along on the flight, just in case. I've never used supplementary oxygen, but the highest density altitude I've experienced was Mt. Whitney at about 14,500'. It's not exactly comparable, but it was a one-day up and back hike. I guess this is one case where they don't err heavily on the side of caution. I think they still do, certainly judging from my altitude-intolerant friend. |
#86
Steve Foley writes:
If you don't know the answer to this question, you should not be flying. Most people don't fly in extremely hot weather. |
#87
Mxsmanic wrote in
: Steve Foley writes: If you don't know the answer to this question, you should not be flying. Most people don't fly in extremely hot weather. Yes, they do,, cretin. Bertie |
#88
In rec.aviation.piloting Mxsmanic wrote:
Steve Foley writes: If you don't know the answer to this question, you should not be flying. Most people don't fly in extremely hot weather. If by "most people" you mean the majority of the people in the world, you are correct. If by "most people" you mean the people who live in warm climates don't fly in hot weather, you are wrong. -- Jim Pennino Remove .spam.sux to reply. |
#89
#90
| Thread Tools | |
| Display Modes | |
| Deadlines to remember | Gilan | Home Built | 5 | July 5th 06 10:28 PM |
| Remember to tip your ... pilot? | Brien K. Meehan | Piloting | 10 | February 4th 06 04:25 PM |
| Remember when? | Billposter | Naval Aviation | 21 | August 22nd 05 10:22 PM |
| Tasha. Anyone remember her? | Mike Anselmo | Naval Aviation | 2 | February 15th 04 04:28 PM |
| And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... | Roy | Piloting | 4 | July 12th 03 05:03 PM |
