USB HUB and Windows XP
Old June 17th 08, 12:09 AM posted to rec.aviation.simulators
wan2fly99
Default USB HUB and Windows XP
I am using a six hub hardware to plug all my goflight hardware
One of the hardware does not work. Whn I plug it in to the PC iteslf
it works
I believe that the USB port in the hub doesn't work. another fellow
also mentioned check to see if Windows XP has a limkit on the number
of USB ports you can use Is there a restriciton else I will have to
buy a new hubworks
Ads
Old July 1st 08, 06:44 PM posted to rec.aviation.simulators
RandyL[_2_]
Is your 6-way USB hub an external one? And if it is an external one, does
your USB hub have its own power supply? Each USB port on your hub draws a
certain amount of current. But the entire USB port on your computer is only
rated for a maximum amount of current. If your hub is not self-powered (has
its own power supply) then try a USB hub that is self-powered. It sounds as
if the hub is exceeding it's rated current.
Randy L.
"When making an emergency off-field landing at night,
turn on the landing light just prior to touchdown.
If you don't like what you see, then turn off the landing light."
"wan2fly99" wrote in message
it works
buy a new hubworks
windows [email protected] Owning 3 November 26th 05 10:00 PM
Opaque windows is FS9? [email protected] Simulators 1 August 17th 05 10:36 AM
JustURLS - why did it not come with Windows! ? Mark Hyland Military Aviation 0 March 14th 04 06:33 AM
why even have windows, re new Boeing Jet Rob Mohr General Aviation 6 December 31st 03 02:52 PM
Bubble windows? jim rosinski Owning 2 October 7th 03 09:13 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Copyright ©2004-2022 AviationBanter.
