![]() "Jake McGuire" wrote in message om... "Kevin Brooks" wrote in message et... Well, if you don't even *have* a gun, that is not going to be a problem, is it? Of course, neither will the CCT (or its supported ground combat element) get the CAS effort they want either... As to the value of the guns, it is interesting to note that one of the comments that came out of the Anaconda participants was, "Every light division needs a supporting *squadron* of AC-130's." Pie in the sky statement that may be, it points out the value those ground folks placed upon aerial gunfire support. It points out the value that the ground troops placed on AC-130 support. Which is naturally much more effective than fighter strafing support, as the AC-130 has more, larger guns, on trainable mounts, with dedicated gunners, and a very long loiter capability. This is not the same as a fighter that can make two or three 20mm strafing passes before he's out of ammunition. Well, you kind of snipped away the related bit about the scenario where you are well within danger-close and under a significant MANPADS threat during daytime, which sort of eliminates the AC-130 from the running. The point was that the groundpounders found the guns a better starting point for CAS during that operation than PGM's. Are you claiming that the 10th LID and 101st AASLT DIV folks did not like getting that 20mm strafe support they received from the F-15E's and F-16's that day? OFCS, the separation range mentioned in a couple of the reports (one from a participating Viper pilot and one from a CCT guy on the ground) was *seventy-five meters*. Do you want any kind of bomb going off that close to *your* patrol if there is another method entailing less risk of fratricide available to be tried first? I wouldn't. There is a good point buried in here - namely that minimum friendly-target distance is an important figure-of-merit for CAS weaponry. It might also be true that the M61 is the best existing fighter-mounted weapon by that standard. It is hardly buried, if you bothered to read the previous messages in the thread--it (being within danger-close range) has been a key point. Your mistake is to assume that this is always going to be the case. The Small Diameter Bomb and the Advanced Precision Kill Weapons System both address this issue, and address it very well. And if they don't do a good enough job, then it's always possible to develop something better. Your mistake is drawing the wrong conclusions based upon different platform requirements, for starters. APKWS is a Hydra-based (or Hellfire based) solution (neither is scheduled for USAF use), and just like the option of using a gun pod, requires specific load out. In other words if your existing CAS support package does not have it onboard when they show up, or are routed in based upon urgent need, and the separation between forces precludes use of larger PGM's, the ground guys are out of luck. OTOH, if they have their trusty internal cannon the ground guys will get at least some form of support. SDB is admittedly going to have a smaller danger close margin than the current minimum 500 pounders, but even a 200-250 pound bomb is going to have a danger close margin that exceeds 75 meters. So if we have (God forbid) another Anaconda situation (and you know as well as I do that there *will* be someday another force inserted somewhere that will find the enemy in an unexpected place, in unexpected strength, and find itself fighting for survival), and our CAS stack is made up of Typhoons and STOVL F-35's sans guns, you think that is OK? Depends on what weapons they're carrying. If they have a pair of 2000 pound JDAMs each, probably not. If they've each got 12 SDBs and 38 laser-guided 70mm rockets, then that's a very different story. And in that case, having STOVL in the case of the JSF or another 15 minutes on station or another 4 SDBs in the case of the Eurofighter are both probably more valuable than the three or four strafing runs you get from a gun. Hydra is a rotary delivered weapon, and unless they change their plans to make it a fixed wing package it is a non-player in the conventional CAS arena (we are not talking helos here). SDB is still going to have a danger close margin. So you are back to the question of whether or not you want to remain flexible enough to provide gunfire support when the situation precludes use of the bigger stuff. Since the gun also serves as a secondary air-to-air weapon, IMO retaining it for the foreseeable future is a wise move. Brooks -jake |
In message , Kevin
Brooks writes "Paul J. Adam" wrote in message ... Risky, perhaps. Indicative of serious pressure on the EP budget, certainly. Personally I'd be a little less inclined to abandon a capability that was actually built in, but it is more expensive than it seems to maintain (it's not just guns, or even ammunition, but the training burden) The training burden? For gosh sakes, you already have to have armorers, Trained gun-fitters and repair teams, and the logistic pipeline to support them, cost money. and I doubt that including a periodic requirement for the pilots to do some range work would be that great a burden--it is after all what they do during peacetime. Try costing up the aircraft, the range, the targets (whether air-to-air or air-to-ground), the equipment to provide useful feedback and training (because 'pulled trigger, gun made loud noise, came home, landed' is not useful training) and it adds up with alarming rapidity. How much of a CAS stack existed that far from the nearest airbase? Apparently a pretty decent one including F-15E's, F-16's, and A-10's as well, from what I have read of the reports on Anaconda. I'd heard the A-10s got pulled early due to hot/high problems, and given the frequent sniping at the F-16's range I'm surprised to hear it doing significant long-range loiter. How effective were the anecdotal strafing runs? It's a tough problem to judge. For sure nobody's going to stand up and say "the CAS birds came in and strafed, but it didn't seem to do much good against the scattered and dispersed enemy we were fighting" - when someone takes a risk to help you, you _don't_ go public saying they endangered themsevles for little result. Actually, one senior US Army commander *did* sort of hammer the CAS effort after-the-fact, though not specifically directed at the strafe operations. Some of his comments were valid, and some were likely as not an attempt to shovel off blame that he should have borne on his own shoulders. As to effect, the reports I read varied, with some indicating that in some instances they ended up having to resort to using PGM's a lot closer than they originally cared to in order to finally destroy the target (and in at least one case that almost literally "blew up in their face", so to speak, yielding a quick, "you almost got us with that last bomb" from the CCT). I recall two reports indicated that the strafes were on target and at least suppressed the bad guys (and sometimes suppression is the best you can hope for). According to http://www.csis.org/burke/hd/reports...irwar_exec.pdf the US flew 17,500 combat sorties over Afghanistan, of which you've heard of several failed strafes ('danger close' sorties where the gun passes failed to stop the enemy, leading to 'even more dangerously close' use of other munitions) and two cases where the enemy was 'suppressed'. Guesstimate two aircraft in each case for eight sorties with a 50% success rate. It's not an enormously convincing argument that the existing gun armament is a potent and essential CAS tool, is it? Either the gun needs to be made significantly more effective in order to increase its lethality and utilisation... or it needs replacing with something better able to provide _effective_ close fire to troops in combat. Burdening most of your tactical air fleet with a thousand pounds of ballast that's used on 0.05% of combat sorties is As well as getting into ricochet hazard, bringing up problems of target fixation, all to employ a very limited weapon system. (Actual effectiveness data is hard to come by for strafing, except that many aircraft doing it seem to have shot themselves dry... suggests they ran out of ammunition before their guns killed all the targets) Well, if you don't even *have* a gun, that is not going to be a problem, is it? And you describe above how in at least one case, strafing failed to deter the enemy and heavier weapons had to be resorted to. Similarly, one drag on developing a weapon for danger-close CAS is the airy claim that "that's what the gun is for" when its effectiveness is patchy (some reports of 'suppression' when it was used, but others where the enemy declined to be deterred) Of course, neither will the CCT (or its supported ground combat element) get the CAS effort they want either... As to the value of the guns, it is interesting to note that one of the comments that came out of the Anaconda participants was, "Every light division needs a supporting *squadron* of AC-130's." Pie in the sky statement that may be, it points out the value those ground folks placed upon aerial gunfire support. Imagine a scenario where the bad guy has a better MANPADS capability and you are stuck in a similar (daytime) situation--which would you rather commit to making strafing runs to suppress the bad guys, fast-movers or that AC-130? If you are as concerned about risk as you claim, you know what the answer to that one is. Sounds like there's a need for a similar weight and accuracy of fire as the AC-130 can deliver, but with the survivability of a fast jet. In your scenario, neither aircraft is particularly suitable: if the AC-130 can't survive the SAM threat, repeated passes by fast movers will also get them speared by those improved MANPADS (especially since they're delivering a lot less firepower and so *need* to make multiple passes through the weapon envelope of an alerted enemy... this is what is technically known as a Really Bad Idea). Where's the evidence of serious effectiveness to compensate? "This was available, it was used, therefore it must be hugely lethal and vitally necessary" is a shaky proposition. Better than, "This was not available, so it could not be used, and we lost a lot of guys", IMO. So where's the evidence for that? Alternatively, you may want to investigate more capable options for "really close support", with particular attention to target acquisition and IFF (it's awkward to accidentally strafe your own side, or to make a low pass but not be able to find the dust-coloured dust-covered targets on the dusty mountainside) rather than insist that a given weapon system is now and forever a fixture. OFCS, the separation range mentioned in a couple of the reports (one from a participating Viper pilot and one from a CCT guy on the ground) was *seventy-five meters*. Do you want any kind of bomb going off that close to *your* patrol if there is another method entailing less risk of fratricide available to be tried first? I wouldn't. And the only options are 20mm cannon or 2000lb bombs? Think again. If this is a genuine and frequent need, neither weapon is appropriate. What is the real requirement, what is the real target, and is a M61 Gatling really the best solution? How about a different gun? How about a different type of munition? Is air-launched weaponry really the best option for danger-close or should some other option be pursued? For gosh sakes, Paul, we are talking a real world example where the M61 was their best hope, at least initially. No, we're talking about current and future procurement. Unless you plan your only combat to be action replays, then you need to learn what worked and what didn't; decide what lessons are valid and which were special cases; and then plan for the future so you do more of what worked, less of what didn't work and learn from the Lessons Identified. Remember, we (or at least I) am not talking about ripping guns out of existing aircraft and plating over the ports; the issue is what to procure in the future. So if we have (God forbid) another Anaconda situation (and you know as well as I do that there *will* be someday another force inserted somewhere that will find the enemy in an unexpected place, in unexpected strength, and find itself fighting for survival), and our CAS stack is made up of Typhoons and STOVL F-35's sans guns, you think that is OK? About as acceptable as declaring that there's no particular problem that a few strafing passes won't completely solve. What happens when the Bad Guys have a SA-11 parked out of sight? That's serious trouble for anything flying within ten miles... bye-bye CAS unless someone's willing to take some risks. Taking risks is inherent to military operations. METT-T rules, and the commanders get paid to weigh those risks versus gains. If you are claiming otherwise, then thank goodness our fathers who fought in WWII did not take that view. I'm not the one claiming four situations in 17,500 sorties demonstrates a completely untouchable situation, Kevin. Taking out an aircraft's gun is a risk (that somewhere in the future, horrible things will happen for the lack of a strafing pass) but also an opportunity (that's a thousand pounds more disposable load to use, and training time freed up - now how to best use it?) If there's a marginal capability (like danger-close CAS), does the gun actually add much to it? Does it happen often enough to justify the very real costs? Is there a better solution available or capable of development? Is it an unacceptable risk? Well, according to some... but then you get into the mutual contradictions of "guns are essential weapons" and "it's not worth developing anything better". And it was my grandfather who fought in WW2, only his war started even earlier than usual: he got a two-day head start on British and French troops. The idea is to stay out of as much avoidable predictable grief as possible, and MANPADs and light AAA are known and hugely proliferated. They're also most effective against an opponent flying a predictable straight-line path... like a strafing run. No, they are even more lethal to that guy flying the AC-130, Who has the option of operating above the light AAA, though MANPADS are a problem there too. or to those guys flying the cargo helos in to haul all those mortar and arty rounds that you would prefer we use exclusively. Given that the mortars should be one to two miles back at least (for 81mm tubes, more for 120s) and artillery five to ten miles, that is one _hell_ of a light AA gun or man-portable SAM that can detect and hit a cargo flight at that distance while in contact with friendly troops and under artillery fire. It's a *lot* easier to acquire and shoot at the Big Loud Plane that just flew overhead. If the enemy air defences are _that_ good, you're definitely not wanting to fly strafing passes. Keeping a capability to strafe is worthwhile, but permanently giving up a half-ton of useful payload while wearing a "Shoot Me!" sign is perhaps not the best solution to the problem. I'd imagine had you been with those guys from the 10th LID who were so happy to get those strafing runs you'd have a slightly different view of the value of retaining that capability, as distasteful as having to resort to its use may be. But the air-combat equivalent for a bayonet would be something on the line of permanently issuing a halberd or bill, or at least a Bloody Big Sword to every soldier and insisting it be carried everywhere they take a rifle: it might be useful for those occasions where troops find themselves at arm's length from the enemy, but it displaces a significant amount of beans, bullets or batteries from the basic combat load. A worthwhile tradeoff, or would the troops be better off with more of their main armament? Not if their main armamnet was incapable of handling the situation that arose. That is the differnce, when viewed against the Anaconda model. In at least one case the main armament had to be used anyway, danger-close be damned. Had you taken up that M61 space and crammed a few new radios, or another few pounds of fuel onboard, it would still not have allowed those CAS aircraft to do what they were *there* to do, which was support the troops engaged, no matter how close the separation of the two combatants. With the M61's they did that. In four cases, with patchy results at best. How about improving ground-to-air comms to shorten the targeting cycle? More fuel, meaning more loiter time per aircraft, for more responsive support? Both reduce the time needed from call-for-fire to delivery; meaning instead of 'suppressing' the enemy with strafing passes, they can be engaged with destructive weapons because they've had less time to close. Or more payload, for a new munition that's got both short danger-close and high lethality on target? Again, you're not talking "a few pounds", you're talking about half a ton: some wags would have you believe you could double an F-16's payload that way. ("Wall-to-wall bombs today, boys, I'm carrying BOTH Mark 82s!") The AH-64s got badly hammered (seven of eight badly damaged and IIRC five were so shot up they never flew again...), and again IIRC the A-10 was pulled out early on because it struggled to cope with the hot-and-high conditions. Those AH-64's were indeed getting hammered--but because they hung around and continued to press home repeated gun runs against the critical targets. How many AH-64 crews were lost? None. How many missions did they fly the next day? None. How much ordnance did they deliver? None. How many lives did they save on the ground? We'll never know. And how many helicopters were available to fly sorties the next day, and the day after, and how many men could have died as a result? Or, what was cancelled because the air support they needed for backup suddenly wasn't there? Losing a half-squadron of AH-64s in a single incident suggests that there's a serious capability gap, not that the existing systems are just fine. Similarly, 88% attrition is _not_ sustainable. The question is not "did they want strafe" but "did they want effective fire support even at close range"? Not the same thing, not at all. They wanted fire that would not also kill them in the bargain, which is why they repeatedly *requested* strafe, again and again. In some cases they later resorted to using LGB's, with the curious methos of walking them in as if they were conventional rounds, from what I could decypher. And yet they still continued to request gun runs...wonder why? Because those were the only two options available to them, and neither sound satisfactory: the LGBs worryingly lethal over too large an area, the gun runs inadequately lethal. I doubt you'll find a soldier there who insisted on the support fire coming from a given asset or weapon now and forever... provided it was available and turned Bad Guys into Dead Guys (or at least Hiding Guys) without creating blue-on-blue then it will be considered Good.. Yep, and what was available that day (or days, as IIRC this lasted well into the next day) was CAS, and what those soldiers kept asking for from the CAS was guns, at least in the early stages. Tells me they liked the guns. Tells me they need another option available to them. Trouble is, when you've got an internal gun you've eaten up weight: tending to, if you're using guns you're stuck with what you've fitted. Remember, we're not discussing a major frontline capability here, but an emergency reversion. Can you justify _more_ guns when you have one built into the airframe anyway and crews expensively trained in its use? It is not that important an issue. The fact is that all of the incoming aircraft we will be fighting with in the foreseeable future, minus the STOVL version of the F-35, have guns included in their armament suites. I say great, keep 'em and keep that flexibility they give us. It must be wonderful having that much budget. Then explain the STOVL JSF, which opted for a gun pod rather than an internal solution despite CAS being high on its priority list. From what I gather that was dictated by the addition of the STOVL capability, which necessitates making room for the lift fan, etc. But the STOVL version is more, not less, likely to be performing CAS. How then can the gun be optional, if it's so effective and essential? If the US can claim it's never run short of tanking assets in-theatre, I'll call them liars, because they're the only force to achieve that. And unless the tankers are flying low orbits over the firefights, breaking off to refuel still means "not on station". More fuel means more time between those absences. Those absences are kind of meaningless if the alternative is another couple of circuits with an arament suite that does not allow you to serve the customers down below, aren't they? Yet again, armament suites are not fixed forever. I doubt the groundpounder down below who is in a situation where his options are such that he wants a strafe/can't risk even a PGM is going to be very relieved by the knowledge that his CAS stack can do a few more circles without being able to actually handle his request. Having the enemy "suppressed" for a pass or two is not a great return on investment either. Neither is having to use those PGMs even closer than the original "too close" because the gun runs didn't do the job. How much flying time does that get you, loitering in a notional 'CAS stack'? It does NOT matter if that CAS asset can't conduct the kind of attack you need! So you don't have the right weapons for the job? (20mm lacks effectiveness, current PGMs too generous in their danger zones) Bear in mind you're making force-wide assertions on the basis of 0.05% of the offensive air sorties here. I'd suggest that if your CAS effort is so short of usable ordnance, or so badly co-ordinated and equipped, that you're depending on guns... you've also got something badly wrong. You just don't get it, do you? "**** happens" in combat, and flexibility is what allows you to adjust. having that aerial gun option is a tool for flexibility. http://www.af.mil/news/May2002/n20020529_0868.shtml +++++ Combat controller recalls Operation Anaconda by Tech. Sgt. Ginger Schreitmueller Air Force Special Operations Command Public Affairs "I had an aircraft overhead carrying 500-pound bombs, but the 'bad guys' were too close to our position to drop that much ammo without risking our lives. I waved the pilot off the bomb run. I had him come around and strafe the area with guns," said the sergeant. The aircraft made a low and hard sweep over the entrenched area, popping off rounds at the enemy troops. "You could see the snow flying off the ground near the bunker and I knew he was hitting it," said Brown. The aircraft made several more passes at the enemy before indicating he was out of ammo. Despite the thousands of rounds pitting the area, the al-Qaida forces kept firing. "I kept yelling across the area at the platoon leader about our options to eliminate the bunker,â said Brown. âWe coordinated on what we needed to do to 'frag' out the enemy and blow the bunker. We knew the bad guys were still hiding in the bunker. We were already two hours into the fight and it was only going to get worse if we couldn't take down their position." Using his close air support training and skills, Brown targeted the spot using precision bombs. The need was urgent as additional al-Qaida troops were pulling up the mountaintop toward the U.S. team. "If we couldn't kill the bunker, we were going to be surrounded,â said Brown. âWe knew that we had enemy soldiers hiding in the terrain to our (right). Effectively, they were moving in on us and we had nowhere to go." The danger-close call proved effective, as the bombs skidded across the side of the mountain just in time and collapsed the bunker. "The noise was just like it sounds in the movies," said Brown. "You could smell the burning pine off the trees and see the snow kicking off the ground." snip But with the bunker out of action and the enemy forces moving up toward the Americans, Brown turned his attention to the rock and tree cluster on the other side of the landing zone. "Since I couldn't use target designators, I needed some marking to be able to talk the bombs onto target," said Brown. "I used a small tree I referred to as the bonsai tree as a reference point." Brown cleared a fighter pilot to drop bombs. When the smoke cleared the tree was now just a stick in the ground, he said. Enemy resistance waned and Brown took a breath." +++++ Doesn't sound like the 'flexibility' of having a gun helped much, except to waste time; and they lost seven men in that firefight. There's an identified need for a more effective danger-close weapon, but the gun doesn't seem to be it. Another account of that battle from SSgt Vance at http://globalspecops.com/sts.html includes the following two excerpts: +++++ "I told the combat controller to have the F-15s to strafe the bunker and have them come in from our right to our left. The CCT repeated what I said. He was smart enough that I did not have to tell him too much detail of what to say on the radio. We used the position of the helicopter to give clock directions. He had basic knowledge of CAS so I could tell him to have the fighters do gun runs on an area from which direction and he would get on the radio and make it happen. The first F-15 pass was really close and I was uncomfortable because I could not tell if the guns were pointing at my team or the enemy bunker so I told the CCT to abort it. I told him to have them come in more from behind us, so I could tell they were not pointing at us. I told him to clear them and the rounds hit right by the bunker. I told him to have them do that over and over again. I think the gun runs were made by both F-15s and F-16s. For the first 10-15 minutes, the CCT thought I was the team leader. He yelled to me 'team leader' when the team leader was sitting next to him. At this point, the team member who was injured in the leg and could not move easily was facing one way. Another Sgt. and I were pulling security on the bunker. The Platoon Leader and I tried to determine where would be a good landing zone. The fighters did some more gun runs and the enemy was still jumping up shooting at us." snip "I asked the medic 'if we hang out here, how many guys are going to die?" The medic said at least two, maybe three. I reported to Controller 'it is a cold PZ and we are going to lose three if we wait. Just as I said it was a cold PZ, we were shot at. However, we could have made it cold by the time they got the helicopters in there. It was just every once and while the enemy would take pop shots at us. If we had CAS on station dropping bombs, we could have gotten out of there at that time. I told CCT to drop bombs down in the valley and on the small hill every now and again. Every time the plane showed up and you could hear them, we weren't being shot at. Just having the planes nearby kept the enemy away. Continuously dropping bombs discouraged them from coming after us. So every now and again, we would drop bombs on them with B52s, B-1s, those were the last aircraft we had. I cannot remember which one." +++++ Again, not a ringing endorsement of the strafing runs... -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
... In message , Kevin Brooks writes "Paul J. Adam" wrote in message ... Risky, perhaps. Indicative of serious pressure on the EP budget, certainly. Personally I'd be a little less inclined to abandon a capability that was actually built in, but it is more expensive than it seems to maintain (it's not just guns, or even ammunition, but the training burden) The training burden? For gosh sakes, you already have to have armorers, Trained gun-fitters and repair teams, and the logistic pipeline to support them, cost money. But you are claiming we would retain the gun pods--don't they already then have to maintain these skills? and I doubt that including a periodic requirement for the pilots to do some range work would be that great a burden--it is after all what they do during peacetime. Try costing up the aircraft, They have to bore holes in the sky anyway--having them chunk up hours on the range instead of doing touch-and-go's seems to be of little impact. Keep in mind that the strafe mission is not their highest priority training event. the range, The range would undoubtedly be a multi-use facility (i.e., unlikely to have a range dedicated to strafe only), so that is no argument. the targets (whether air-to-air or air-to-ground), Yeah, putting up a target panel of fabric must be extremely expensive... the equipment to provide useful feedback and training (because 'pulled trigger, gun made loud noise, came home, landed' is not useful training) and it adds up with alarming rapidity. Gee, they have to grade all kinds of exercises already--I'd suspect a bit of gun camera footage of the strafe pass would be acceptable. How much of a CAS stack existed that far from the nearest airbase? Apparently a pretty decent one including F-15E's, F-16's, and A-10's as well, from what I have read of the reports on Anaconda. I'd heard the A-10s got pulled early due to hot/high problems, and given the frequent sniping at the F-16's range I'm surprised to hear it doing significant long-range loiter. The 354th FW *did* do "significant long-range loiter" during that operation with their F-16's, so that argument is meaningless. How effective were the anecdotal strafing runs? It's a tough problem to judge. For sure nobody's going to stand up and say "the CAS birds came in and strafed, but it didn't seem to do much good against the scattered and dispersed enemy we were fighting" - when someone takes a risk to help you, you _don't_ go public saying they endangered themsevles for little result. Actually, one senior US Army commander *did* sort of hammer the CAS effort after-the-fact, though not specifically directed at the strafe operations. Some of his comments were valid, and some were likely as not an attempt to shovel off blame that he should have borne on his own shoulders. As to effect, the reports I read varied, with some indicating that in some instances they ended up having to resort to using PGM's a lot closer than they originally cared to in order to finally destroy the target (and in at least one case that almost literally "blew up in their face", so to speak, yielding a quick, "you almost got us with that last bomb" from the CCT). I recall two reports indicated that the strafes were on target and at least suppressed the bad guys (and sometimes suppression is the best you can hope for). According to http://www.csis.org/burke/hd/reports...irwar_exec.pdf the US flew 17,500 combat sorties over Afghanistan, of which you've heard of several failed strafes ('danger close' sorties where the gun passes failed to stop the enemy, leading to 'even more dangerously close' use of other munitions) and two cases where the enemy was 'suppressed'. Guesstimate two aircraft in each case for eight sorties with a 50% success rate. Failed to stop the enemy? How much suppression did they achieve? And here you go with your McNamaresque number crunching again... war cannot always be resolved into neat little statistical piles. Witness the recognition lately of the fact that the old attrition models for simulations are just plain inaccurate as all get out. It's not an enormously convincing argument that the existing gun armament is a potent and essential CAS tool, is it? Your strawman. I have said from the beginning that it is a last resort, only-when-nothing-else-should-be-tried-first tool, and as such preserves flexibility for the system beyond that which exists sans guns. But hey, you tell me what the groundpounder who finds himself with a nasty situation located in that 25-to-500 meter danger-close gap in CAS coverage that results when no gun is available is supposed to do. Either the gun needs to be made significantly more effective in order to increase its lethality and utilisation... or it needs replacing with something better able to provide _effective_ close fire to troops in combat. But this is, by my own admission, a "niche" capability that probably does not merit much more resource dedication than it has already received. A nice-to-have capability for use when none of the other tools are initially suitable or acceptable. Burdening most of your tactical air fleet with a thousand pounds of ballast that's used on 0.05% of combat sorties is I guess the USAF is utterly clueless then, as they seem to disagree with you. I'd note that a fair portion of your own RAF was apparently not happy with the loss of the gun from the Typhoon. Do you know something none of these folks do? As well as getting into ricochet hazard, bringing up problems of target fixation, all to employ a very limited weapon system. (Actual effectiveness data is hard to come by for strafing, except that many aircraft doing it seem to have shot themselves dry... suggests they ran out of ammunition before their guns killed all the targets) Well, if you don't even *have* a gun, that is not going to be a problem, is it? And you describe above how in at least one case, strafing failed to deter the enemy and heavier weapons had to be resorted to. You are really having a problem with the idea that the ground commander would prefer to work *up* the risk ladder, don't you? Not jumping in and placing his ground troops at maximum risk from the outset? Odd, since you were so risk adverse when it came to allowing the CAS assets down into the weeds to make these sort of attacks. Similarly, one drag on developing a weapon for danger-close CAS is the airy claim that "that's what the gun is for" when its effectiveness is patchy (some reports of 'suppression' when it was used, but others where the enemy declined to be deterred) Gee, if it really sucked so much, why did those CCT's keep calling for strafe as opposed to bombs in the first place? Of course, neither will the CCT (or its supported ground combat element) get the CAS effort they want either... As to the value of the guns, it is interesting to note that one of the comments that came out of the Anaconda participants was, "Every light division needs a supporting *squadron* of AC-130's." Pie in the sky statement that may be, it points out the value those ground folks placed upon aerial gunfire support. Imagine a scenario where the bad guy has a better MANPADS capability and you are stuck in a similar (daytime) situation--which would you rather commit to making strafing runs to suppress the bad guys, fast-movers or that AC-130? If you are as concerned about risk as you claim, you know what the answer to that one is. Sounds like there's a need for a similar weight and accuracy of fire as the AC-130 can deliver, but with the survivability of a fast jet. In your scenario, neither aircraft is particularly suitable: if the AC-130 can't survive the SAM threat, repeated passes by fast movers will also get them speared by those improved MANPADS (especially since they're delivering a lot less firepower and so *need* to make multiple passes through the weapon envelope of an alerted enemy... this is what is technically known as a Really Bad Idea). Really Worse Idea is not being able to deliver support when the risk is assessed and accepted. Where's the evidence of serious effectiveness to compensate? "This was available, it was used, therefore it must be hugely lethal and vitally necessary" is a shaky proposition. Better than, "This was not available, so it could not be used, and we lost a lot of guys", IMO. So where's the evidence for that? The same place as your evidence that the gun is worthless--a product of the argument. If you don't have a gun, and the bad guys are in so tight that you *can't* resort to a bomb, then you are effectively saying CAS is out of the picture, so any increased losses could be attributed to that, at least in part. Alternatively, you may want to investigate more capable options for "really close support", with particular attention to target acquisition and IFF (it's awkward to accidentally strafe your own side, or to make a low pass but not be able to find the dust-coloured dust-covered targets on the dusty mountainside) rather than insist that a given weapon system is now and forever a fixture. OFCS, the separation range mentioned in a couple of the reports (one from a participating Viper pilot and one from a CCT guy on the ground) was *seventy-five meters*. Do you want any kind of bomb going off that close to *your* patrol if there is another method entailing less risk of fratricide available to be tried first? I wouldn't. And the only options are 20mm cannon or 2000lb bombs? Think again. If this is a genuine and frequent need, neither weapon is appropriate. Nobody said "frequent". I have noted before that you seem ready to place combat into the "nice neat box" category, where all things happen according to plan, and there is a playbook for handling the proceedings. That just is not the way it happens. Which is why flexibility is important. And I hate to say it, but I think your empathy is a bit lacking--if it *were* you hugging the dirt up close and personal and well within the danger close margin for bombs, and you had the option of starting with guns and then working up through higher risk alternatives, I suspect you'd do that as opposed to starting with the more risky "big bang". It is a bit easier to say you wouldn't when you are not facing that dilemma. What is the real requirement, what is the real target, and is a M61 Gatling really the best solution? How about a different gun? How about a different type of munition? Is air-launched weaponry really the best option for danger-close or should some other option be pursued? For gosh sakes, Paul, we are talking a real world example where the M61 was their best hope, at least initially. No, we're talking about current and future procurement. We have been using Anaconda as the point of discussion-the M61 was used in that role by both USAF and (IIRC) USN aircraft during that operation. Unless you plan your only combat to be action replays, then you need to learn what worked and what didn't; decide what lessons are valid and which were special cases; and then plan for the future so you do more of what worked, less of what didn't work and learn from the Lessons Identified. Well, since it looks like the 25mm is going to be our next major gun caliber for the fast movers, maybe that will satisfy some of your concern. Remember, we (or at least I) am not talking about ripping guns out of existing aircraft and plating over the ports; the issue is what to procure in the future. So if we have (God forbid) another Anaconda situation (and you know as well as I do that there *will* be someday another force inserted somewhere that will find the enemy in an unexpected place, in unexpected strength, and find itself fighting for survival), and our CAS stack is made up of Typhoons and STOVL F-35's sans guns, you think that is OK? About as acceptable as declaring that there's no particular problem that a few strafing passes won't completely solve. Why would you claim that? I did not say any such thing. What I have been saying is that when the ground guys find themselves in such a knife fight and CAS is available, it is sure nice for that CAS to be able to contribute to the fight. If it is successful in suppressing the bad guys (and I imagine that it usually will at least be able to achieve short-term suppression), it affords the troops a chance to either break contact or to maneuver into a better situation. If it fails, then you have to do what SSG Brown did and call in the heavier ordnance, accepting that you are placing your troops at greater risk. I can't understand what you find disagreeable about allowing those ground troops to escalate the risk level as needed, as opposed to having to accept that greater risk of fratricide from the outset if you have no gun capability. What happens when the Bad Guys have a SA-11 parked out of sight? That's serious trouble for anything flying within ten miles... bye-bye CAS unless someone's willing to take some risks. Taking risks is inherent to military operations. METT-T rules, and the commanders get paid to weigh those risks versus gains. If you are claiming otherwise, then thank goodness our fathers who fought in WWII did not take that view. I'm not the one claiming four situations in 17,500 sorties demonstrates a completely untouchable situation, Kevin. Neither am I; I shy away from such meaningless statistics. I recognize that strafe is the least preferable manner of delivering effective CAS. I also recognize that there is a lot of ground radiating out from between 25 meters and (let's assume for the SDB which will shortly be in the inventory) maybe 20 meters, and retaining the ability to conduct immediate CAS requests against such targets may very well mean the difference between success/failure for the mission or life/death for the troops. Finally, I recognize that the best laid plans can go to hell before you even cross the LD, so "Semper Gumby" can be said to be the epitome of military slogans, and the gun contributes to that. Taking out an aircraft's gun is a risk (that somewhere in the future, horrible things will happen for the lack of a strafing pass) but also an opportunity (that's a thousand pounds more disposable load to use, and training time freed up - now how to best use it?) If there's a marginal capability (like danger-close CAS), does the gun actually add much to it? Does it happen often enough to justify the very real costs? Is there a better solution available or capable of development? Is it an unacceptable risk? Well, according to some... but then you get into the mutual contradictions of "guns are essential weapons" and "it's not worth developing anything better". And it was my grandfather who fought in WW2, only his war started even earlier than usual: he got a two-day head start on British and French troops. The idea is to stay out of as much avoidable predictable grief as possible, and MANPADs and light AAA are known and hugely proliferated. They're also most effective against an opponent flying a predictable straight-line path... like a strafing run. No, they are even more lethal to that guy flying the AC-130, Who has the option of operating above the light AAA, though MANPADS are a problem there too. It does not matter how high he is operating-we don't like using the gunships for daylight operations. Khafji put paid to that approach. or to those guys flying the cargo helos in to haul all those mortar and arty rounds that you would prefer we use exclusively. Given that the mortars should be one to two miles back at least (for 81mm tubes, more for 120s) and artillery five to ten miles, that is one _hell_ of a light AA gun or man-portable SAM that can detect and hit a cargo flight at that distance while in contact with friendly troops and under artillery fire. It's a *lot* easier to acquire and shoot at the Big Loud Plane that just flew overhead. Here is where your "should be" falls apart on the rocks of reality. During Anaconda the troops found themselves engaged a lot earlier, and a lot more heavily, than they predicted-that is war, with all of its uncertainty. So, I 'd assume (though I have not read anything to corroborate this) that the plan was to have the mortars set up somewhere near the initial LZ's to cover the troops movement to contact. By making contact a lot earlier than anticipated, that put the mortars up near the close fight, and made the resupply mission rather hazardous. Tube arty in this case was another matter-Hagenbach, the MG in charge, has to shoulder the load for failing to have a firebase set up within range, but he apparently did not anticipate getting into a knifefight that precluded the use of the usual CAS delivered bombs from the outset. Which is why those CCT's ended up begging for strafing runs, again and again. If the enemy air defences are _that_ good, you're definitely not wanting to fly strafing passes. Keeping a capability to strafe is worthwhile, but permanently giving up a half-ton of useful payload while wearing a "Shoot Me!" sign is perhaps not the best solution to the problem. I'd imagine had you been with those guys from the 10th LID who were so happy to get those strafing runs you'd have a slightly different view of the value of retaining that capability, as distasteful as having to resort to its use may be. But the air-combat equivalent for a bayonet would be something on the line of permanently issuing a halberd or bill, or at least a Bloody Big Sword to every soldier and insisting it be carried everywhere they take a rifle: it might be useful for those occasions where troops find themselves at arm's length from the enemy, but it displaces a significant amount of beans, bullets or batteries from the basic combat load. A worthwhile tradeoff, or would the troops be better off with more of their main armament? Not if their main armamnet was incapable of handling the situation that arose. That is the difference, when viewed against the Anaconda model. In at least one case the main armament had to be used anyway, danger-close be damned. ONLY as a last resort. Common sense dictates that you don't start off treating a simple puncture wound to your hand by amputating the arm at the elbow, though that option may be exercised later if the mere cleaning and bandaging of the wound does not prevent blood poisoning. Likewise, those CCT 's did not jump directly to the risky use of bombs in a danger close situation until they had exhausted their other less risky options. Had you taken up that M61 space and crammed a few new radios, or another few pounds of fuel onboard, it would still not have allowed those CAS aircraft to do what they were *there* to do, which was support the troops engaged, no matter how close the separation of the two combatants. With the M61's they did that. In four cases, with patchy results at best. They DID it, which is more than they could have done had they lacked those guns. Fratricide is a nasty thing, and we apparently came rather close to a disastrous frat incident with one of those bombs-that is why those CCT' s wanted to use the strafe first. How about improving ground-to-air comms to shorten the targeting cycle? More fuel, meaning more loiter time per aircraft, for more responsive support? Both reduce the time needed from call-for-fire to delivery; meaning instead of 'suppressing' the enemy with strafing passes, they can be engaged with destructive weapons because they've had less time to close. Or more payload, for a new munition that's got both short danger-close and high lethality on target Huh? They "closed" almost instantaneously in this event, from what I have read. There was no detection of the bad guys in strength at 1000 meters followed by maneuver to within danger-close limits-for gosh sakes, they would have just pasted the guys with CAS delivered PGM's at the outset if they had known they were there. Again, you're not talking "a few pounds", you're talking about half a ton: some wags would have you believe you could double an F-16's payload that way. ("Wall-to-wall bombs today, boys, I'm carrying BOTH Mark 82s!") The AH-64s got badly hammered (seven of eight badly damaged and IIRC five were so shot up they never flew again...), and again IIRC the A-10 was pulled out early on because it struggled to cope with the hot-and-high conditions. Those AH-64's were indeed getting hammered--but because they hung around and continued to press home repeated gun runs against the critical targets. How many AH-64 crews were lost? None. How many missions did they fly the next day? None. How much ordnance did they deliver? None. And they hung around because the guys on the ground were in deep do-do and needed that support right then, not tomorrow. Tomorrow is meaningless if you are likely to die today. How many lives did they save on the ground? We'll never know. And how many helicopters were available to fly sorties the next day, and the day after, and how many men could have died as a result? Or, what was cancelled because the air support they needed for backup suddenly wasn't there? They were able to bring in replacement helos: IIRC some USMC AH-1W's showed up to handle the attack helo role subsequent to having those Apaches get shot up. Losing a half-squadron of AH-64s in a single incident suggests that there's a serious capability gap, not that the existing systems are just fine. Similarly, 88% attrition is _not_ sustainable. Any source for that number? ISTR reading that most of those helos were back up within the week (I only recall one being a write off at the time)? The question is not "did they want strafe" but "did they want effective fire support even at close range"? Not the same thing, not at all. They wanted fire that would not also kill them in the bargain, which is why they repeatedly *requested* strafe, again and again. In some cases they later resorted to using LGB's, with the curious methos of walking them in as if they were conventional rounds, from what I could decypher. And yet they still continued to request gun runs...wonder why? Because those were the only two options available to them, and neither sound satisfactory: the LGBs worryingly lethal over too large an area, the gun runs inadequately lethal. And they requested the gun runs in preference to the bombs-case closed. I doubt you'll find a soldier there who insisted on the support fire coming from a given asset or weapon now and forever... provided it was available and turned Bad Guys into Dead Guys (or at least Hiding Guys) without creating blue-on-blue then it will be considered Good.. Yep, and what was available that day (or days, as IIRC this lasted well into the next day) was CAS, and what those soldiers kept asking for from the CAS was guns, at least in the early stages. Tells me they liked the guns. Tells me they need another option available to them. That may be, but I know of no other option that we can count on always being onboard the loadout of the CAS packages. Even if APKWS was adopted by the USAF it would not be an integral weapon. As it stands now we can get some kind of CAS support at the 25 meters-from- friendlies- range from every fast mover CAS aircraft we have-that is called flexibility. Trouble is, when you've got an internal gun you've eaten up weight: tending to, if you're using guns you're stuck with what you've fitted. Remember, we're not discussing a major frontline capability here, but an emergency reversion. Can you justify _more_ guns when you have one built into the airframe anyway and crews expensively trained in its use? It is not that important an issue. The fact is that all of the incoming aircraft we will be fighting with in the foreseeable future, minus the STOVL version of the F-35, have guns included in their armament suites. I say great, keep 'em and keep that flexibility they give us. It must be wonderful having that much budget. It is. And as we discussed earlier, the gun is a marginal part of the total program cost. Which is maybe why most air forces still have them, and why most, if not all, new aircraft orders, excepting that curious RAF Typhoon situation, include them. Then explain the STOVL JSF, which opted for a gun pod rather than an internal solution despite CAS being high on its priority list. From what I gather that was dictated by the addition of the STOVL capability, which necessitates making room for the lift fan, etc. But the STOVL version is more, not less, likely to be performing CAS. How then can the gun be optional, if it's so effective and essential. I did not say it was the most effective weapon-that is you twisting my words (again). I said it affords a greater degree of flexibility, especially in the very close fight, that you lose without the gun, and I believe that flexibility is very important. If the US can claim it's never run short of tanking assets in-theatre, I'll call them liars, because they're the only force to achieve that. And unless the tankers are flying low orbits over the firefights, breaking off to refuel still means "not on station". More fuel means more time between those absences. Those absences are kind of meaningless if the alternative is another couple of circuits with an arament suite that does not allow you to serve the customers down below, aren't they? Yet again, armament suites are not fixed forever. Ever try to specify what loadout you want from the air force side? I doubt the groundpounder down below who is in a situation where his options are such that he wants a strafe/can't risk even a PGM is going to be very relieved by the knowledge that his CAS stack can do a few more circles without being able to actually handle his request. Having the enemy "suppressed" for a pass or two is not a great return on investment either. It is if it allows you to disengage, or if it allows you to maneuver to a position offering better cover, or if it allows you to conduct an assault to dislodge the bad guys. I believe if you asked the average ground guy which he'd prefer to have, the ability to achieve short-term suppression, or the inability to suppress at all, he'd take the former Neither is having to use those PGMs even closer than the original "too close" because the gun runs didn't do the job. How much flying time does that get you, loitering in a notional 'CAS stack'? It does NOT matter if that CAS asset can't conduct the kind of attack you need! So you don't have the right weapons for the job? (20mm lacks effectiveness, current PGMs too generous in their danger zones) Bear in mind you're making force-wide assertions on the basis of 0.05% of the offensive air sorties here. Paging Mr. McNamara. I'd suggest that if your CAS effort is so short of usable ordnance, or so badly co-ordinated and equipped, that you're depending on guns... you've also got something badly wrong. You just don't get it, do you? "**** happens" in combat, and flexibility is what allows you to adjust. having that aerial gun option is a tool for flexibility snip what is undoubtedly the largest citation I have ever encountered Glad to see you found the article, Paul. Too bad you can't understand the basic fact that those ground guys kept asking for strafing attacks because they did not want to escalate their own risk until/unless they had to. Brooks |
snip enormously long diatribe arguing against the effectiveness of a gun
for CAS Again, not a ringing endorsement of the strafing runs... Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk Paul - 20mm is particularly ineffective for the type of CAS in the stories you use to argue your point. Additionally, these were Mud Hen guys who don't train to strafe, and in fact hadn't practiced strafe since they left the RTU. They also didn't press in close enough to decrease the bullet dispersion, which would also allow for an increase in energy when the bullets impacted. I doubt you've seen the HUD footage from that mission, but I can tell you in the valley they were operating in I wouldn't have taken an E model any closer than they did. This is not a slam against the Mud Hen guys, they did great work, but they simply don't train to use the gun like Warthog pilots do. I will venture to say with great certainty if A-10s had been doing the shooting, there wouldn't have been a need for a Maverick or bomb pass follow-up. ATTACK! |
![]() "Paul J. Adam" wrote in message ... In message , Kevin Brooks writes As to air-to-ground use, I believe the resident Strike Eagle driver has already provided a reason for retaining a strafe capability, i.e., recent operations in Afghanistan. During Anaconda the need for up-close-and-personal support (read that as well within the danger-close margin) was reported. You can't *always* use your LGB's or JDAM's, which is why the grunts liked the cannon armed aircraft during that fight. Are there no gun pods? This has always been a capability that can be bolted onto aircraft as necessary. Gun pods are great draggy things that really cut in to performance. If you were designing the capability from scratch, would you insist on the M61? Consider a larger-calibre weapon with more A/G punch like a KCA? Or go for fuel and/or lightness, and hang a podded gun for 'danger close' missions? The problem is that those danger close missions tend to be unpredicted by their nature otherwise we would simply avoid the great majority all together. And in many cases arming up a plane specifically to fly one -say in Qatar- and getting it on station -oh, over Afghanistan- is going to take too long. |
AIM-54 Phoenix missile | Sujay Vijayendra | Military Aviation | 89 | November 3rd 03 09:47 PM |
P-39's, zeros, etc. | old hoodoo | Military Aviation | 12 | July 23rd 03 05:48 AM |
